Who's ran Mototron Injectors?
I bought a set and planned on using them on my swap but I just cant seem to figure out how I am going to get them to work. They're really skinny and kind of tall. If anyone has ran them on a regular low port engine can you please post up your setup and anything you did to make them work? IE, what fuel rail, and how they fit into the manifold..
Thanks, jer.
Boosted & Stanced
aftermarket top feed fuel rail for highport. PVC pipe around injectors to prevent it from popping out. Done.
-Norm
Need to rent a SR20 torque plate? PM me.
You have a highport motor though...right? I have a low port. Would a high port rail work on a low port?
Boosted & Stanced
sorry, in that case get one for a lowport, the mounting points are different.
-Norm
G20 Guru
No offense and I only say this from experience, but they are garbage injectors. I'm sure many people have had great experiences with them and they'll be sure to chime in and tell me I'm a douche. But they are trash. I would get rid of them asap and go with a MSD or similar injector.
Once I went to a set rate injector, 72lb MSD's, my car actually ran, decent too.
Good luck.
Gmac
Ive heard both, good and bad, I already sent them to jwt and had them test them and write my map to these injectors. I dont really feel like sending my freakin computer back and spending another 100 without at least trying them. If they blow a big one Ill have to choice but to step up to an msd, but Im gonna at least try them and see. Thanks for the input though.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
