What is a "maf?"
Results 1 to 8 of 8
Thread: What is a "maf?"
  1. #1
    G20 Junior Member
    Join Date
    Jul 2009
    Location
    Chicago
    Posts
    63
    What is a "maf?"
    I read about a problem with the maf in 2000+up models but when I searched this on the forum, I got "maf" results which doesn't tell me what it is.
    Thanks.
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Member bballmanath's Avatar
    Join Date
    Jul 2010
    Location
    Colorado Springs
    Posts
    310
    mass air flow sensor
  4. #3
    tornaDON itinifni's Avatar
    Join Date
    Aug 2006
    Location
    Bumbelch Kansas.
    Posts
    687
    Mass airflow sensor. It's a sensor in your intake piping that measures air going in to your engine. They are a little problematic on some models. Sometimes the ground goes bad in them, causing poor fuel consumption and make the car not run at it's best. The ground problem can be repaired, but if the sensor is bad you will have to replace it.
  5. #4
    G20 Guru Helladank's Avatar
    Join Date
    May 2007
    Location
    Los Angeles
    Posts
    1,187
    You don't take a shit, you leave it. - Miguelito
    ___________________________________ ________________________
  6. #5
    G20 Junior Member
    Join Date
    Jul 2009
    Location
    Chicago
    Posts
    63
    Thanks! I'll read up on this - maybe this is why I don't get the mileage I was expecting from this car.
  7. #6
    Lord Crodz javcrodgz's Avatar
    Join Date
    Apr 2006
    Location
    Tempe, AZ
    Posts
    7,027
    I have one for sale btw, off an '02 Sport.
    ____SR20Deep - Phoenix, AZ / Team Nizmo - AZ Chapter / 1/2 Race AZ G20's_____
    Quote Originally Posted by Dema View Post
    Ahhhh I was convinced droppin demas was a good thing.....
    Quote Originally Posted by trbobrk View Post
    Hi javi.
  8. #7
    G20 Guru merlin's Avatar
    Join Date
    Sep 2005
    Location
    around
    Posts
    2,881
    I responded in your other thread, what sort of MPG's are you getting (You may want to start an MPG's bad thread in the maintenance section to get ideas about all possible solutions)
  9. #8
    G20 Junior Member
    Join Date
    Jul 2009
    Location
    Chicago
    Posts
    63
    I get about 22-24 MPG depending on the weather, mostly stop-and-go driving. I was expecting better but maybe I'm wrong and I haven't measured it lately. Once in awhile, there's also a little surge when I start to go from a fully stopped position. The car has about 98,000 miles on it.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
