Thumping Noise When Applying Brakes - video of noise included
Results 1 to 8 of 8
Thread: Thumping Noise When Applying Brakes - video of noise included
  1. #1
    G20 Newbie
    Join Date
    Nov 2009
    Location
    Boston MA
    Posts
    14
    Here's a video of the noise I heard last night.
    http://img228.imageshack.us/img228/9586/wys.mp4
    Noise occurs when I apply the brakes. It's coming from the front right wheel.
    In the video, I'm already applying the brakes. Noise starts immediately at the beginning of the video and I'm coming to a stop at the end.
    Out of 10 videos this was the only one that captured the noise.
    Rotors = look fine
    Brake pads = I can't tell visually, but probably needs to be replaced.
    I was meaning to visit my mechanic this morning, but I got home late last night so I ended up waking up late.
    Any idea what might be causing this noise? The noise slows down when I slow down. If you are familiar with this noise/problem, how dangerous is it to drive on it?
    Thanks for any advice.
    Happy Thanksgiving everyone.
    Last edited by tissot; Nov 24, 10 at 02:41 PM. Reason: wanted to add more information about the video.
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Guru
    Join Date
    Feb 2007
    Location
    Shrewsbury, MA
    Posts
    1,824
    I would first go buy pads and rotors for ATLEAST the front. I would recommend all around, along with calipers all around. I would dissasemble each wheel and inspect your calipers for frozen pistons, leaky seals...etc. If they all check out OK, slap the pads and rotors on and go...then return the calipers. Replace calipers as necessary.
    Sounds like you are either:
    1. Really low on your brake pads.
    2. Your rotors are warped.
    3. You have atleast 1 frozen caliper.
    That's my guess anyways. Kind of hard to decipher from an audio clip.
  4. #3
    G20 Guru
    Join Date
    Sep 2008
    Location
    Pacnorwest,Utah
    Posts
    1,395
    well if your rotors are warped you will get some pedal vibration. Any of that? Also make sure all your lug nuts are tight.
  5. Remove Advertisements
    G20.net
    Advertisements
  6. #4
    G20 Guru Lemywings's Avatar
    Join Date
    May 2004
    Location
    Vancouver, BC
    Posts
    1,312
    sounds loose lug nuts
  7. #5
    G20 Guru
    Join Date
    Feb 2007
    Location
    Shrewsbury, MA
    Posts
    1,824
    If it were loose lug nuts, it would happen at other times, not just when he applies the brakes. If it happens at other times, all bets are off.
  8. #6
    G20 Guru
    Join Date
    Sep 2008
    Location
    Pacnorwest,Utah
    Posts
    1,395
    i think his wheels flew off and flipped the car,cannot post
  9. #7
    G20 Newbie
    Join Date
    Nov 2009
    Location
    Boston MA
    Posts
    14
    Noise is coming from the rotor/caliper
    I managed to get down to the shop and while riding in the passenger seat while my mechanic was driving, the noise was coming from the rear right wheel.
    DR - I was planning to get all the brakes done, new pads & rotors and replace any seized calipers.
    The caliper in the rear is definitely frozen. Never worked since day one.
    Lug nuts are rusted up, but they're on there tight.
    My question for you guys is what are your thoughts on those ebay rotors and brake pads? They a bit cheap, but not if they're made from inferior grade metal and wear out quick. I don't want to get new pads/rotors installed every 3 months.
    That's the only thing that's held me from getting the brakes done. Not sure what brands to us.
    For the P11 owners, what kind of brake pads, rotors & calipers are you using?
    Also an idea on how long the brake parts stay shiny before they get all rusted up?
    Thanks DaveRacer, P10Der LemyWings for responding.
    I would have responded sooner, but I had to go somewhere. Just got back a little while ago.
    Looks like I'll have to get the rest of the exhaust system done as well.
    Any recommendations for mufflers?
    Happy Turkey Day.
  10. #8
    G20 Guru
    Join Date
    Sep 2008
    Location
    Pacnorwest,Utah
    Posts
    1,395
Posting Permissions
  • You may not post replies
  • You may not edit your posts
