Choices on air intakes - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: Choices on air intakes
  1. #21
    G20 Guru CarolinaPanthers's Avatar
    Join Date
    Feb 2010
    Location
    New Jersey
    Posts
    1,733
    paradyme - does the obx piping have spots for all 3 hoses to plug into? i know for my ebay piping, i had to make a t connection for the pcv valve hose and the hose that goes somewhere back towards the engine, and i'm wondering if thats the best idea, since my idle dropped really low after installing the intake and now sits at ~500 rpms
    not to thread jack, just discussing the possible side effects of a new intake
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #22
    G20 Guru paradyme's Avatar
    Join Date
    Mar 2002
    Location
    Bloomfield NJ
    Posts
    1,090
    Thumbs up
    Yep, Check out Zooker's progress thread. He has either the official Injen piping or the OBX. His WAI is what mine will look like once installed. As far as adverse affects, Make sure you plug your air sensor back in. You should be good. I had a warm air intake using stock piping or stockOEM intake hose on my last P10 G20. You can always stick with that. Also I'm using the JWT/Stillen POP charger, that the aluminum piece you see inserted in the opening of my velocity stack filter which is for the older aluminum MAF adapter like you see attached to the WAI piping in my pic.
    http://www.g20.net/forum/showthread....=HEADER+GASKET
  4. #23
    Top5DOA
    Join Date
    Feb 2011
    Location
    So.Pasadena CA
    Posts
    1,969
    GGet a Injen CAI for the 98 200sx and it will work on a P11 perfect.
    I have one
  5. #24
    Join Date
    Feb 2010
    Location
    New Jersey
    Posts
    1,733
    thanks paradyme. i think i might go that route if i go back to cai. the extra shitty one i got from ebay didnt quite cut it so now i just use the wai portion
  6. #25
    'Luke' Loek's Avatar
    Join Date
    Oct 2002
    Location
    Venezuela
    Posts
    5,216
    Quote Originally Posted by Dema View Post
    I have one
    Same here.
    P11-144SW, VE, B15 LSD swap, DV9, SS/AS exhaust 2.5'-2.25'. AEM ATE B15-Rad B&A BC-Racing BF-Goodridge Bosch Brembo Bride-Brix-II Cusco D-1 DEI Dietz ES Fastbrakes Flexalite Greddy H&R Injen Innovate JWT Magnaflow NGK Nismo Nology Optima Progress Project-Kics Rays Sachs SCE Sparco SSAC Stillen Taylor Valvoline.
  7. #26
    T3h Sexy Beast trbobrk's Avatar
    Join Date
    Mar 2002
    Location
    Seattle, WA USA
    Posts
    19,710
    Quote Originally Posted by paradyme View Post
    WOW! That's rough Rob, never heard of that?
    K&N says it won't hurt it, but Nissan actually has a technical service bulletin saying if the MAF goes bad the technician should check for an aftermarket filter.
  8. #27
    G20 Newbie Mr Dampachi 415's Avatar
    Join Date
    Feb 2011
    Location
    San Francisco
    Posts
    15
    I have one
    Did u have to do any special modding? or did u just pick one up and it fit perfectly?
  9. #28
    Join Date
    Mar 2002
    Location
    Bloomfield NJ
    Posts
    1,090
    Thumbs up
    If it's a cold air intake you need to cut a whole into your inner wheel well behind your stock battery location. And you'll need to remove your stock intake assembly i.e. intake hose and air filter box. Or you could use the just the upper half of the same INJEN cold air intake and make a warm air intake.
    Quote Originally Posted by Mr Dampachi 415 View Post
  10. #29
    G20 Junior Member
    Join Date
    Oct 2011
    Location
    Georga
    Posts
    51
    you could measure out the dimensions of the filter and order an oilless one from Amsoil. they are a bit pricy but you do not need to oil them at all. I have one on my 03 cobra ...great quality
Posting Permissions
  • You may not post replies
  • You may not edit your posts
