how do you remove lower control arms on a 1996 g20 (P10)
Results 1 to 7 of 7
Thread: how do you remove lower control arms on a 1996 g20 (P10)
  1. #1
    G20 Newbie
    Join Date
    Sep 2010
    Location
    Orlando
    Posts
    11
    i have seen whats involved i just wanna comfirm some stuff. What size is that big bolt? 22mm? and once you take that bolt off is it a pain in the butt removing it cause of the bushing in the back. i was looking for some pics but i wanted know what have some people have done to remove the control arm without damaging it. thanks
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Senior Member GregM's Avatar
    Join Date
    Dec 2007
    Location
    Phoenix, AZ
    Posts
    669
    i think thats the size i used when i did my bushings but i dont remember exactly. if you are not changing the front bushing just take the bracket its bolted to off of the car with the 3 bolts, the ball joint bolt under the spindle, and the 2 bolts holding the plate on the back. if you are not pressing the back bushing off, you will have to hack at it to get it off. fronts are also pressed in so thats why i say just leave the big nut and take the 3 bolts off. i used a cut off wheel to get the back bushing off.
    93.5 G20 - DD
    93 NX2K - Go Kart
  4. #3
    G20 Newbie
    Join Date
    Sep 2010
    Location
    Orlando
    Posts
    11
    ok im just trying to take the control arm from a donor G20 so i want them intact so all i need to do is unscrew the 3 bolts and remove the bolt from the lower ball-joint (thats underneath the spindle) then just pull forward right? just want to confirm and thanks for the info
  5. #4
    Join Date
    Dec 2007
    Location
    Phoenix, AZ
    Posts
    669
    you will also have to take the 2 that hold the back bushing to the body and it will drop right out. so total you will have the ball joint nut, the 3 bolts on the front part of the arm and the 2 that hold the plate on. they are long and have some pressure holding them on so you will probably need an impact or breaker bar to break em loose.
    93.5 G20 - DD
    93 NX2K - Go Kart
  6. #5
    G20 Newbie
    Join Date
    Sep 2010
    Location
    Orlando
    Posts
    11
    ok sweet thanks greg
  7. #6
    Yeah That Just Happened! Dane's Avatar
    Join Date
    Aug 2004
    Location
    Oak Town, Wa
    Posts
    14,167
    They only tough part is separating the ball joint from the spindle.
    Quote Originally Posted by Blackwater32 View Post
    Someone quote me.
    Dane, don't quote me
    WWW.TOP5DOA.NET
  8. #7
    G20 Senior Member serganich's Avatar
    Join Date
    Mar 2007
    Location
    Seattle
    Posts
    829
    ^^ But once you pull big hammer from the trunk and smash the sucker......
    Don't forget you will need to get an alignment done after replacement. I had to.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
