Is my transmission dead?
Results 1 to 6 of 6
Thread: Is my transmission dead?
  1. #1
    G20 Newbie
    Join Date
    Apr 2010
    Location
    Vancouver
    Posts
    29
    Hello all,
    Some of you may recall my post earlier regarding a bad axle which is now fixed. Today, however, I ran into something rather more serious. I went to school today, parked, and went off to grab a coffee. Upon my return some 40 minutes later, I noticed something weird about my clutch pedal. It is softer than usual, but it still moves back and fourth. Next, I tried to start the car and it turned on without any issues, but I cannot engage in any gear. Then I turned the car off to see what is going on. When the car is off, I can move freely between gears, but as soon as I turn it on, I am stuck in neutral again.
    I popped the hood and check all my fluid levels and they were all okay, and I don't see any leaks anywhere. So then I tried again, but started my car in gear with the clutch pedal down. The car bogs down right away and lurches forward.
    I think something is causing my clutch to be stuck on engage and as a result, causing my car to stall whenever I try to start it. What do you guys think could have caused this?
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Senior Member
    Join Date
    Jul 2010
    Location
    MASSA u SHIT
    Posts
    887
    Most likely u blew a spring on the clutch, mine did the same thing
  4. #3
    G20 Newbie
    Join Date
    Apr 2010
    Location
    Vancouver
    Posts
    29
    Quote Originally Posted by liljay781 View Post
    Well, I got the car towed to a shop and they opened up the transmission housing. The culprit? A snapped release fork. The good news is that my clutch itself has only about 10% left, so I can use this chance to replace everything i need to do as well.
    I try to comfort myself saying its better to have the snapped fork first, rather than after replacing the clutch and returning to open it up again.
  5. #4
    G20 Senior Member
    Join Date
    Jul 2010
    Location
    MASSA u SHIT
    Posts
    887
    Completely understood. Now don't go with a cheap clutch or ull b back in there 2 years from now
  6. #5
    G20 Newbie
    Join Date
    Apr 2010
    Location
    Vancouver
    Posts
    29
    Exedy OEM replacement, my car is pretty much stock so I think it will be fine.
  7. #6
    G20 Senior Member
    Join Date
    Jul 2010
    Location
    MASSA u SHIT
    Posts
    887
    very good choice, exedy is a very good clutch, best replacement clutch outhere besides act street disk
Posting Permissions
  • You may not post replies
  • You may not edit your posts
