Is a 96 good for ve swap?
Results 1 to 10 of 10
Thread: Is a 96 good for ve swap?
    G20 Member
    Mar 2006
    new york
    183
    like the title states. Just trying to find the best model that would be easiest to pass emissions in ny
    G20 Guru
    Sep 2008
    Pacnorwest,Utah
    1,162
    yes
    Yeah That Just Happened! Dane's Avatar
    Aug 2004
    Oak Town, Wa
    14,215
    97 is best.
    Quote Originally Posted by Blackwater32 View Post
    Someone quote me.
    Dane, don't quote me
    WWW.TOP5DOA.NET
  5. #4
    Mar 2011
    Canandaigua NY
    39
    Being in NY, I would stick to 96 or older simply because they dont check anything but the mechanicals for inspection. In other words, you don't have to worry about check engine lights being on, or previous CELs having to be cleared.
    Makes life tons easier come inspection time
  6. #5
    G20 Member
    Mar 2006
    new york
    183
    oh ok, for some reason I thought the 96 was the first year they could connect to computer
  7. #6
    G20 Senior Member P10 Goodness's Avatar
    Sep 2008
    Mesa, AZ
    694
    by law 96 is the first year OBD2 was required to be in all vehicles. Not sure individual state emissions laws, but in AZ 96 and newer they only check the ecu for any codes. I bought my 96 p10 for that fact. One other factor you will need to consider is tuning, what are you planning on doing for your ecu tuning? Nistune would require a 95 or older ECU to work. Select ecus older than 96 do still have OBD2 in them, you would need to look for one of those. If going with JWT, check with them to find out what ECU they can take, and if they can retain OBD2. I wouldn't suggest simply doing a piggy back because at that point it becomes a lot harder to tune the car without tripping a check engine. JWT would be the easiest option. Other wise, go with a 95 or older to just have a smog check on the rollers. Properly tuned VE's do very well with emissions.
    Lol @ dane 97's rock!
    http://www.jimwolftechnology.com/wolfpdf/ECU-ID.PDF
  8. #7
    p10 guru StangG20's Avatar
    Apr 2005
    CT
    2,908
    Quote Originally Posted by kcazual View Post
    ^ truth.
    you can still make it happen but is not as easy as 95 and older.
    17" Maxxim Harpoon, GR-2 + Tein S, Spec stage 3 clutch, Zex 55-75hp dry shot, carbon fiber trunk, cf hood, cf mirror covers, cf b-pillars, Primera eGT bumpers + skirts, Eastbear grill, Catz hi/lo hids, euro tails, Carbing rstb, NissDataScan, 20% tints, g20T interior, Alpine CDA-9853, Alpine interiors, Directed 1500d amp, 2 - 10" Memphis audio subs, RF Punch 250.2
    In the works: sr20ve + lsd tranny, ACT hdss, Fidanza
  9. #8
    G20 Senior Member CovertRussian's Avatar
    Apr 2008
    VA
    721
    Look for older, OBD1 one would be your best bet.
    Lighter
    96 G20t Curbweight: 2954 lbs.
    93 and Older: 2745 lbs.
    OBD1 = Better tuning options including TunerCode and Nemu boards
    Older = Easier to pass emissions, especially sniffers since VE's are very clean motors.
    I have a P11 with a VE swap, P11 weighs around 2980lbs. It's way too slow with 2.5" SSAC header, 3" exhaust, bunch of here and there mods and a fully tunable ECU. Going turbo on the newer P10's to compensate for the weight would work better.
    00 G20t KH3 - Loller Rocker + Disco Potato + 6 Speed
    01 B15 SE /PP - SR20DET
    04 Forester XT - Stock
  10. #9
    drunken master p10det's Avatar
    Dec 2003
    de
    9,913
    I think 96 is really easy to do. I did a swap in a 96 se-r he has no codes at all and passes all srt tests.
    I even got a 95 p10 ecu in a members b15 working and compleatly codeless car but he recenlty recked it
  11. #10
    Sep 2008
    Mesa, AZ
    694
    Quote Originally Posted by p10det View Post
    what ecu tuning did you use on those machines?
    Project Green Machine
    1/4 mi. time: maybe...
    HP: Neigh!!!
    Torque: Yes please....
