I can haz ve? - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 93
Thread: I can haz ve?
  1. #21
    G20 Guru Kirru's Avatar
    Join Date
    Apr 2007
    Location
    Conyers, GA
    Posts
    1,501
    More pics. Delivered today. opened the vc to get a peek inside. looks amazing!
    プリメーラ Cory きる Stone Mountain Nissan, Lilburn, GA
    www.stonemountainparts.com cory@stonemountainnissan.com
    Direct: 678-252-3100 x123
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #22
    Yeah That Just Happened! Dane's Avatar
    Join Date
    Aug 2004
    Location
    Oak Town, Wa
    Posts
    14,170
    Not a real complicated swap but I would get the motor in and running before you start tucking.
    Quote Originally Posted by Blackwater32 View Post
    Someone quote me.
    Dane, don't quote me
    WWW.TOP5DOA.NET
  4. #23
    Join Date
    Apr 2007
    Location
    Conyers, GA
    Posts
    1,501
    Yea, not going to do the tuck.. only cause i have to work the next two weekends and then i am gone the third and the 4th i have a mid term... february is a busy month
  5. #24
    drunken master p10det's Avatar
    Join Date
    Dec 2003
    Location
    de
    Posts
    9,894
    sweet but do take your time with the install paying attention to aall small detials.
    and when the old engine is out take the time to clean an scrub the engine bay so you ve has a nice and clean new home
  6. #25
    G20.net Staff
    Super Moderator
    bhowle's Avatar
    Join Date
    Sep 2006
    Location
    Columbia, SC
    Posts
    2,948
    Quote Originally Posted by p10det View Post
    This man has some great advice! I always soak the bay down with purple power and pressure wash the hell out of it when the engine is out. Working on a nasty, greasy car sucks.
  7. #26
    Join Date
    Apr 2007
    Location
    Conyers, GA
    Posts
    1,501
    trust me, when you get the pics of the bay you'll be wondering where the car and motor are it'll be so clean.
  8. #27
    Join Date
    Apr 2007
    Location
    Conyers, GA
    Posts
    1,501
    how many lines come off a ve intake? i only see one directly on it.. i need to make one to fit my filter.. as i didnt get one when I bought mine. n60 maf really needed or can i roll with my stock de till i get the nemu board and then i get it programmed for the n60? isnt that the 99-04 max maf as well?
  9. #28
    Join Date
    Apr 2007
    Location
    Conyers, GA
    Posts
    1,501
    Got the water pump and rear main seal in today. Gonna swap those out sometime...
    Quote Originally Posted by Xtrakritical View Post
    Could you post it on google docs?
    My list is a bit excessive, but Im going to try to post a link...
    I actually need to update it some more, I've picked up the axles, fender markers , and a few other things since.
    http://docs.google.com/viewer?a=v&pi...xYTI3&hl=en_US
    Xtra
    Good idea to replace water pump. So ought add that to you list of stuff to replace.
  10. #29
    Join Date
    Apr 2007
    Location
    Conyers, GA
    Posts
    1,501
    Just some random questions...
    Can I run with the stock DE maf and fuel pump and injectors for the time being? I figured I should at least get the Nemu board first and have it programmed for a basic tune with out the listed items and when I can find the larger MAFs... I believe N60 load the new tune on the board, but i was also curious if i had to upgrade injectors for any reason other than turbo which i wont be for a while....
    I'm sure i will have more ?s in the future so keep a look out
  11. #30
    p10 guru StangG20's Avatar
    Join Date
    Apr 2005
    Location
    CT
    Posts
    2,905
    stock de maf and fuel pump is fine for a stock ve. when you say stock injectors do you mean de's or ve's? if you are rocking a stock ecu, i'd go with stock injectors for the time being and dont switch the cams
    17" Maxxim Harpoon, GR-2 + Tein S, Spec stage 3 clutch, Zex 55-75hp dry shot, carbon fiber trunk, cf hood, cf mirror covers, cf b-pillars, Primera eGT bumpers + skirts, Eastbear grill, Catz hi/lo hids, euro tails, Carbing rstb, NissDataScan, 20% tints, g20T interior, Alpine CDA-9853, Alpine interiors, Directed 1500d amp, 2 - 10" Memphis audio subs, RF Punch 250.2
    In the works: sr20ve + lsd tranny, ACT hdss, Fidanza
  12. #31
    Join Date
    Apr 2007
    Location
    Conyers, GA
    Posts
    1,501
    Just going to rock the stock de ecu till i get the motor installed and running. I'll send off the ECU after I get back from vacation.
    stock ve injectors.
    no vvl for me till nemu board.
    at most i will do are the springs and N1 cams in the future. and maybe i will turbo it but i doubt that
  13. #32
    Join Date
    Apr 2005
    Location
    CT
    Posts
    2,905
    my car ran very poorly with the stock ecu and ve injectors.
  14. #33
    Join Date
    Apr 2007
    Location
    Conyers, GA
    Posts
    1,501
    gonna get Nemu board after I get back from snowboarding so i know how much I can blow riight when I get back from vacation.. i'll probably have him send me the stuff as I can solder it right up but then again, the hassle of doing it is beside me lol we'll see..
  15. #34
    G20 Guru LerkZone's Avatar
    Join Date
    Sep 2003
    Location
    Temecula Socal
    Posts
    1,191
    Clean ve!!!! Nice build .
  16. #35
    Join Date
    Apr 2007
    Location
    Conyers, GA
    Posts
    1,501
    thanks Lerk.. Pulled VE exhaust mani off and pulled water pump. scraped all the old grey rtv off getting ready to put the new one on tomorrow at lunch time. going to take the ve harness off and get ready to install the high port DE one when i get back from vacation.
  17. #36
    Join Date
    Apr 2007
    Location
    Conyers, GA
    Posts
    1,501
    anyone have an intake available for this? just the piece from the TB to the MAF... all i have is one for my High port that was a CAI... any help would be great
  18. #37
    Join Date
    Apr 2007
    Location
    Conyers, GA
    Posts
    1,501
    Car is running, had to switch two wires on the dizzy and it started right up. then only cyclinder 2&3 were firing as they were not getting fuel, figure out that the injector plugs needed to be swapped so 1&4 were not plugged in right. got that fixed and all is better.
    .....VE PLUG SIDE..........Highport 93.5 DE harness side
    Pin 1- Black.............................. ...Black
    Pin 2- White/Red........................Orange
    Pin 3- Black/White......................Blue
    Pin 4- Blue............................... ....Blue/White
    Pin 5- Green.............................. ..Green/Yellow
    Pin 6- White/Red........................Black/Red
    Pin 7- Black/White......................Black
    Pin 8- Brown/White.....................White
    I this is how I got mine to work and only took one failed attempt
  19. #38
    Join Date
    Apr 2005
    Location
    CT
    Posts
    2,905
    sweet! glad you got it running
  20. #39
    Join Date
    Apr 2007
    Location
    Conyers, GA
    Posts
    1,501
    thanks stang
  21. #40
    Join Date
    Apr 2007
    Location
    Conyers, GA
    Posts
    1,501
    Sound bite update before leaving work...
    https://www.youtube.com/watch?v=RLBG...e_gdata_player
Posting Permissions
  • You may not post replies
  • You may not edit your posts
