Tevs 98 B13 Sentra LecPS VE
Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: Tevs 98 B13 Sentra LecPS VE
  1. #1
    G20 Junior Member
    Join Date
    Apr 2003
    Location
    Baguio City, Ph
    Posts
    52
    Finally got a newer 98 Chassis which came standard with a Carb GA13DS, bought it in the southern part of the Philippines, drove about 6 hours North and finally made it to Baguio around 1pm
    Arrived at the shop and we get to work
    we pressurize/Degrease/Soap/Scrub out and underwash everything to take out years of crud and mud/dirt
    Fit the GTS 1 bumper after washing off the front end as well
    broke down all suspension and brake components:
    Went through the entire suspension assembly and replaced components, Preload upon tightening all Components after assembly
    Front
    1. Arm Balljoints using 555
    2. Steering rack clamp bushings
    3. Front stabilizer bushings
    4. Tie Rod Ends 555
    5. Rack Ends 555
    6. Installed Bilstein HD Yellow's with the B&G Springs using oem TopMounts and Bearings
    7. Installed Front KSB Underbrace (its the pinoy copy of Shigspeed)
    8. Installed ES Engine Mounts on Torque Set (Front and Rear)
    9. New Stabilizer End Links came with car that the owner never installed
    Rear
    1. Stabilizer Bushings
    2. Installed Bilstein HD Yellow's with the B&G Springs using oem TopMounts and Bearings
    3. Install Rear Bar
    4. New Stabilizer End Links came with car
    Brakes = AD22VF Fronts and A7's Rear
    1. Checked and Cleaned All Pistons and Sliders, cleaned and regreased sliders (retightened Caliper Brackets)
    2. Checked All Pads front and rear with shims
    3. Installed APP Stainless Steel Brakes
    4. Full bleed Removed all Old Brake Fluid and air pockets
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Junior Member
    Join Date
    Apr 2003
    Location
    Baguio City, Ph
    Posts
    52
    Nonstop work for about 2 days
    oem nissan vc gasket finally arrived, china replacements leak
    Copy header
    Shigspeed Copy underbrace
    2.5 inch exhaust piping (mild Steel)
  4. #3
    G20 Junior Member
    Join Date
    Apr 2003
    Location
    Baguio City, Ph
    Posts
    52
    Next Up was replacing the Leaking Valve Cover Gasket and Accesory Belts
    We Used a Valve Cover Gasket meant for the SR20DE Powered Altima, Perfect Fit, since we had the VC removed, checked all cam lobes and they are smooth as well as the head assembly
    the replacement vc eventually leaked, now using oem Nissan Altima Sr20DE VC gasket
    a Quick Engine Flush and Regular Oil Changes will eventually remove the oil residue
    purchase GATES Belts to replace the cracked PITWORK Accessory belts that came with the Engine, here are the part numbers, the thicker belt for the AC Compressor and Alternator was supposed to be 1030, as the store only had 1040, it worked and tensioned fine
    oem Pitwork belts that came with the engine are
    4PK855
    6PK1030
    these are all that was available local and they work fine
  5. #4
    G20 Junior Member
    Join Date
    Apr 2003
    Location
    Baguio City, Ph
    Posts
    52
    Used a GA16DE ecu holder bracket for the SR20VE A/T ECU
    Removed the carpet and cleaned all panels , removed the fabric from the door panels and used Mark-V Interior Cleaner (Klenzol) to remove the adhesive residue. as well as all sidings, panels and Dashboard, easier to remove and do wiring with all the stuff out of the way.
    after assembly, we installed the Fidanza Short Shift Kit, Signal Auto Shiftknob, Momo Corsa SW and Hub, Bride Zeta 1 Bucket seat with Bride Slider and Bracket.
  6. #5
    G20 Junior Member
    Join Date
    Apr 2003
    Location
    Baguio City, Ph
    Posts
    52
    threw some surplus used JDM parts that we found at the JDM importers.
    we got a long way to go, and waiting on more parts, for now it runs fine
  7. #6
    G20 Newbie
    Join Date
    Nov 2011
    Location
    MI
    Posts
    23
    Nice proggres car looks really good, keep up the good work
  8. #7
    rhd specialist j-tek's Avatar
    Join Date
    Apr 2005
    Location
    bay area
    Posts
    4,840
    wow, shes in mint condi. no rust, original paint? subscribing
  9. #8
    G20 Guru
    Join Date
    Mar 2004
    Location
    Cranston, RI
    Posts
    1,592
    Nice work pare!
  10. #9
    WCMIII/SR2012 FLAKER Cesarin_se-r's Avatar
    Join Date
    Jun 2005
    Location
    LaLaLand, CA.
    Posts
    5,091
    Nice b13 Tevs!
    ->My WTB thread for El Chacal<-
    SR20DEEP CA César D
  11. #10
    G20 Guru Teachmehowto20's Avatar
    Join Date
    Aug 2011
    Location
    Norwlk/New Haven
    Posts
    1,570
    looks good,
  12. #11
    G20 Junior Member
    Join Date
    Apr 2003
    Location
    Baguio City, Ph
    Posts
    52
    JC Racing Silicone radiator Hoses Just arrived, got em for around $60 for the pair
    JC Racing Part Numbers
    angle of lower radiator hose
    Purchase 4 of the Best Stainless Clamps you can find, in this case the best we can find are GATES Clamps (Made in the U.S.A) at 60 pesos each
    dont forget to insert and slide over a couple of Gates Clamps prior to sliding the Silicone Hose over your Filler Hose as well as in the right orientation, easier to tighten the 8mm clamps
  13. #12
    G20 Junior Member
    Join Date
    Apr 2003
    Location
    Baguio City, Ph
    Posts
    52
    Quote Originally Posted by j-tek View Post
    Original Paint and No Rust, Paint Fading on the roof and trunk, i think i will keep it unpainted for the next few years or until i'm done sorting out everything
  14. #13
    Prince of Gnet Kidcaffeine's Avatar
    Join Date
    Mar 2007
    Location
    garden state
    Posts
    6,649
    is that a BE engine?
  15. #14
    Join Date
    Apr 2005
    Location
    bay area
    Posts
    4,840
    Can you source me those clear/see through rad hoses? Salamat
  16. #15
    G20 Guru
    Join Date
    Sep 2008
    Location
    Pacnorwest,Utah
    Posts
    1,163
  17. #16
    G20 Newbie Myx's Avatar
    Join Date
    Oct 2009
    Location
    Illinois
    Posts
    46
    Hey, I remember you from Nissanbayan. Haha! too bad that site went down and nobody took care of it.
    how's everything going?
  18. #17
    G20 Newbie
    Join Date
    Sep 2009
    Location
    Australia
    Posts
    5
    Do your Bilstein HD Yellow fronts have a part number left on them ?
  19. #18
    G20 Junior Member
    Join Date
    Apr 2003
    Location
    Baguio City, Ph
    Posts
    52
    kidcaffeine = nah, its a GA13DS
    j-tek = check this out, Clear Rad Products Phone: (562) 594-3892 USA (866) 629-1024, looks like a SoCal Area Code, i'm in P.I. Meng
    myx = Glad you remember me meng, i cant even remember most of the peeps anymore, Mike Black may up NB this year, Chuck kim aka Monk (passed away last year = he had all the info for NB Domain and Board), Mark wrecked his DET altima, 2 forums soaked up most of the peeps from NB, Sentra Club Philippines and Club Nissan Sentra
    coZZmo = i will search for them bud, i saved the part number somewhere, these are HD Yellow's Cartridges meant for the Corolla AE101 fitted into emptied out B13 Strut Casings, got em from a Distributor here called Speedlab
  20. #19
    G20 Junior Member
    Join Date
    Apr 2003
    Location
    Baguio City, Ph
    Posts
    52
    MAF (Mass Air Flow Meter pigtail), CAS (Cam angle Sensor), VVL Solenoid...etc. harness
  21. #20
    G20 Member
    Join Date
    Jun 2008
    Location
    exeter, ca
    Posts
    280
    Holy fuck thats a lot of wires......... man u must be patient. Looks like its comming along nicely. I miss my b13 ser
Posting Permissions
  • You may not post replies
  • You may not edit your posts
