Changing springs and shocks
Results 1 to 10 of 10
Thread: Changing springs and shocks
  1. #1
    G20 Newbie
    Join Date
    Jul 2010
    Location
    South Carolina
    Posts
    I have 99 G20T and planning on replacing the springs with Eibach Pro-Kit and shocks with Bilstein HD and would like to know what kind of problems I will be facing or will the ride be too rough for everyday driving.
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Guru
    Join Date
    Sep 2008
    Location
    Pacnorwest,Utah
    Posts
    1,162
    What problems are you referring to? Problems that may arise while you are installing the Shocks and springs? Problems as far as the ride being too harsh should not be a problem. It should handle nice. On the front struts use a heat gun to heat up the bolts holding the shock on. Heat is your friend they will come off like butter.
  4. #3
    G20 Guru CarolinaPanthers's Avatar
    Join Date
    Feb 2010
    Location
    New Jersey
    Posts
    1,732
    you might want to pick up some DMSentra top mounts to restore some of the shock travel up front, but it should be a pretty solid set up
  5. #4
    G20 Guru Teachmehowto20's Avatar
    Join Date
    Aug 2011
    Location
    Norwlk/New Haven
    Posts
    1,628
    ^this
  6. #5
    Pining for "DMSentra" DMSentra's Avatar
    Join Date
    Oct 2006
    Location
    Oregon
    Posts
    5,127
    Quote Originally Posted by p10der View Post
    Say what?????
  7. #6
    rhd specialist j-tek's Avatar
    Join Date
    Apr 2005
    Location
    bay area
    Posts
    4,838
    Butter is for biscuits
  8. #7
    Yeah That Just Happened! Dane's Avatar
    Join Date
    Aug 2004
    Location
    Oak Town, Wa
    Posts
    14,215
    Quote Originally Posted by j-tek View Post
    Quote Originally Posted by Blackwater32 View Post
    Someone quote me.
    Dane, don't quote me
    WWW.TOP5DOA.NET
  9. #8
    G20 Junior Member BMG20's Avatar
    Join Date
    Apr 2009
    Location
    M TOWN
    Posts
    69
    springs
    If your mechanically inclined you can do it no problem .Buy some penetrating fluid so stuff will come apart easier. I bought a cheap spring compressor.
    You'll need it for the Eibachs cause they have alot of coils . The Tiens u dont need a compressor at all . get a buddy to help u'll see why.
  10. #9
    Im a organ donor.
    Join Date
    Feb 2008
    Location
    Atlanta
    Posts
    4,636
    go to autozone rent a spring compressor pull suspention and compress the spring. Take the top nut off and release the spring compressor. Fit all parts how they came off old shock onto new shocks. Its pretty easy. You might want to either get some rubber shower pan liner from home desperate or new oem gaskets for where the shock mounts to the body. The oem ones will crumble to a bunch of pieces.
  11. #10
    G20 Newbie
    Join Date
    Jul 2010
    Location
    South Carolina
    Posts
    Thanks for all the replies. Another question....Tire rack wants 158 dollars for each Bilstein shock, Does anyone know of another place that has them cheaper?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
