pulley tensioner
Results 1 to 6 of 6
Thread: pulley tensioner
  1. #1
    G20 Member Hellspeaker's Avatar
    Join Date
    Feb 2012
    Location
    Georgia
    Posts
    193
    pulley tensioner
    pulley tensioner making noise, how I change this?
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Guru CarolinaPanthers's Avatar
    Join Date
    Feb 2010
    Location
    New Jersey
    Posts
    1,732
    you could tighten it
    ps pulley or alternator belt?
  4. #3
    G20.net Staff
    Super Moderator
    bhowle's Avatar
    Join Date
    Sep 2006
    Location
    Columbia, SC
    Posts
    2,963
    There are no tensioner pulleys on a G20. The alternator and PS pump act as the tensioner for those belts. What sort of noise do you have? A loud screech or a slight squeak. When does it happen? (on startup, cold engine, hot engine, under load, revving the engine, etc.)
  5. #4
    G20.net Staff
    Super Moderator
    slimlou's Avatar
    Join Date
    Sep 2004
    Location
    Toronto, ON
    Posts
    6,075
    I've got squealing at start up. Then again, it started after I had my GSpec crank pulley. Summer time not much of an issue, but cold & winter, yikes!
  6. #5
    Join Date
    Feb 2012
    Location
    Georgia
    Posts
    193
    I guess ill have to make a video of it, and its basically all the damn time. I don't really know how to explain it honestly. It was just until it warmed up, not its a constant thing. If the car is under 2k rpm it doesn't make the noise once its warmed up though.
  7. #6
    G20.net Staff
    Super Moderator
    slimlou's Avatar
    Join Date
    Sep 2004
    Location
    Toronto, ON
    Posts
    6,075
    You need to check your belt tension. Also, how old are your belts? Did you ever replace them when you got the car? If they've been squealing this long, and you don't know there age, then I'd consider changing them. With all the squealing going on for this long, the belt surfaces could now be glazed over, and no matter if you properly tension the belt, it will just squeal again. Unfortunately belts are one thing people overlook as something that needs to be replaced as regular maintenance.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
