Take a look guys, new setup finished - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 55
Thread: Take a look guys, new setup finished
  1. #21
    G20 Newbie
    Join Date
    Jan 2011
    Location
    Mass
    Posts
    1
    Yup, top 5 fav p11's forsure. Congrats man this thing is awesome I like everything about it.
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #22
    Top5DOA
    Join Date
    Feb 2011
    Location
    So.Pasadena CA
    Posts
    1,969
    This build is almost identical to norms, requesting to see some dyno number with video!
  4. #23
    drunken master p10det's Avatar
    Join Date
    Dec 2003
    Location
    de
    Posts
    9,897
    glad you like the blow truw maf. I did a blow threw test on my car one time and was not pleased with the maf voltage fluctuation.
    but each is own Im a draw through guy and I also like the wastgate open dumping in cars
    what i found in blowtrew the air moves back and forth in the maf alot. but if you are ok with the little things and like blow threw thats awsome
    we do it on all the 350z's and such but usually requirs a bit of scaleing pre tuneing
  5. #24
    rhd specialist j-tek's Avatar
    Join Date
    Apr 2005
    Location
    bay area
    Posts
    4,836
    ve-t for the winn!! any dyno sheet on this yet?
  6. #25
    G20 Senior Member ontothenext1's Avatar
    Join Date
    Oct 2010
    Location
    MA
    Posts
    869
    Quote Originally Posted by ser kyle View Post
    Oh G baggin now?
  7. #26
    G20 Member
    Join Date
    Feb 2005
    Location
    Montreal
    Posts
    233
    I dont know about maf fluctuations .... all i did last year is put it after turbo and done... liked it from the beginning.. but i didnt tune it since then, so i'll see what my tuner thinks about it.
    I'll be on the dyno next week... so no numbers for now, we will see the sheet! Hope for the best.
    My tuner suggested me to rewire the fuel fump with a relay, to get full voltage to the pump, so i'll do it this weekend.
  8. #27
    Boosted & Stanced akuma810's Avatar
    Join Date
    Mar 2002
    Location
    San Francisco
    Posts
    3,108
    are you doing it because youre having fuel problems?
    -Norm
    Need to rent a SR20 torque plate? PM me.
  9. #28
    G20 Member
    Join Date
    Feb 2005
    Location
    Montreal
    Posts
    233
    no fuel problem... i was all good last year at all my boost range... but i was not boosting past 14 psi approx. I guess i'll go up to 18 psi this year...
    and for now i dont want to boost it up before gooing to the tuner. Anyway it wont cost much, a relay/wire and done.
  10. #29
    G20 Guru
    Join Date
    Mar 2004
    Location
    Cranston, RI
    Posts
    1,592
    Nice set-up, but why did you recirc the synapse bov? You're running blow through and can keep that open.
  11. #30
    P10 hater
    Join Date
    Aug 2008
    Location
    Layton, UT
    Posts
    2,317
    Nice man! Congrats.
    Good luck on the tune.
  12. #31
    Join Date
    Dec 2003
    Location
    de
    Posts
    9,897
    his tuner is sudgesting this to get full use out of the fuel pump. not a bad thing to do But I would predict your power goals limitation more on the injector size unless he want you to do a rewire and 4 bar but than the maf is to small lol
    what are your power goals . i think your set up is all great left the way it is for 320-340whp but the fuel pump rewire might help keep the injector duty cycle at a better leval
    hope all goes well
  13. #32
    G20 Member fubar1o2's Avatar
    Join Date
    May 2008
    Location
    Philly, PA
    Posts
    148
    Quote Originally Posted by p10det View Post
    hope all goes well
    The E60 MAF maxes out at 325 WHP, before the 555 injectors.
  14. #33
    The figure it out guy... WeazG20's Avatar
    Join Date
    Jun 2011
    Location
    BFE AZ
    Posts
    734
    Looks sweet man!
  15. #34
    G20 Member
    Join Date
    Feb 2005
    Location
    Montreal
    Posts
    233
    Thanks guys!
    For the recirc i like it better when the pssssshh sound is ''dampered''. Making it recirc makes it a bit less ''ricer'' and i like it better sleeper than ''look me i have a blowoff'' but it is just my style.
    Last time my tuner installed a restistor in the ecu... giving more range to the e60 maf. (he is a nissan specialist here in Quebec)
    So i dont really know the limits of this setup but he seems confident there's no problem... i wasent blow thru at that time.
    if i lack fuel i'll can just take it to 4 bars since i already have the nismo AFPR.
    The weld on the mani have seen many cycles yet and no cracks for now... hope it stays this way!
  16. #35
    G20 Member
    Join Date
    Feb 2005
    Location
    Montreal
    Posts
    233
    Here are the news... (dyno pack, the one bolted on the hubs)
    346whp / 305lb.tq
    @ 16.5 psi
    VVL @ 4700rpm
    what is cool is i get 200 lb tq @3250rpm, 275lb.tq @ 3750rpm
    so i ckanked it to 4 bars of fuel pressure, duty cycle at about 90/92%. E60 MAF was allwright with the resistor inside, i think he puts a 8000k resistor in the ecu.
    All i have to say is DaMMMM, the G seems like a monster now, when the VVL kick with open dumptube wide open at 4700rpm, the sound is crazy awesome. I had a vid but my friend didnt film it right and the sound is really poor...
    Anyway i'll keep the WG dumped, i like it now , and i cant recirc it without tuning again.
    Really happy, could have been higher but the injectors were the choke, anyway when i did buy stuff i knew i wanted 350whp, so the 555cc where what i needed. I acheived my power goals, all that with a good streetable turbo with good mid-low-end torque.
    Pics of graph soon!
  17. #36
    G20 Senior Member roblop04's Avatar
    Join Date
    Oct 2006
    Location
    Coral Springs
    Posts
    719
    sick... top 5 DOA!!!
  18. #37
    Join Date
    Oct 2006
    Location
    Coral Springs
    Posts
    719
    definate sleeper...
  19. #38
    'Luke' Loek's Avatar
    Join Date
    Oct 2002
    Location
    Venezuela
    Posts
    5,216
    It must be a beast.
    P11-144SW, VE, B15 LSD swap, DV9, SS/AS exhaust 2.5'-2.25'. AEM ATE B15-Rad B&A BC-Racing BF-Goodridge Bosch Brembo Bride-Brix-II Cusco D-1 DEI Dietz ES Fastbrakes Flexalite Greddy H&R Injen Innovate JWT Magnaflow NGK Nismo Nology Optima Progress Project-Kics Rays Sachs SCE Sparco SSAC Stillen Taylor Valvoline.
  20. #39
    Join Date
    Dec 2003
    Location
    de
    Posts
    9,897
    good power and I wasnt sure why you didnt want to dump the waste gate. I bet the car is pretty fun.
    we also use dyno pack its a really good for tuning dyno
    is the injector duty at 90% after 4 bar are before?
  21. #40
    Join Date
    Mar 2002
    Location
    San Francisco
    Posts
    3,108
    nice! do you have a graph? I wanna see how the curve is like. Hopefully I can get my car retuned soon and compare, only difference is im running the SR16 cams.
    -Norm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
