I've been curious on how much heavier the P11 (P10 too) front multi-link suspension then the standard Sentra Macpherson setup is.
Please read Moto IQ's MacPherson vs Multi-link technical comparison, if you are curious to see why one is better then the other.
MacPherson Strut Suspension
Weight: 27lbs per side, 54lbs both sides
I don't have the OEM strut, oem weight's shouldn't be to far from the Tein Basics.
Turning is done by the top hat
Multi-link Shock Suspension
Weight: 45lbs per side, 90lbs both sides
Turning is done at the knuckle, the shock does not move, it also does not support the weight of the car.
There is also a third link, this helps keep negative camber when suspension gets under load.
Total weight difference is 18lbs per side and 36lbs for both sides.
