Originally Posted by
2000 G-Twenty-T
well, thats more or less correct but see below. and okay that actually makes sense to test. im not positive where the eec relay is.. theres only one other relay next to the fuel pump, its blue, i suppose thats probably it. ill test those and get back to you.
basically if i jump direct from the battery to 787 @ C101 with c101 unplugged, or even jump it to 238 at the relay with thte relay out, the pump runs. however to do that i have either c101 unplugged, or the relay out, so that my jumper is the only source of power. if i unplug c101 and test the wire coming from the inertia switch, it has power, it reads exactly like the battery does. the second i plug it in, and test it again, the power is gone.
i will do the above test to see if its the relay is the breaking point or before though.
