Fuel system cleaner
I heard fuel system cleaner is a no go for a sr20 engine. Is that true and if so why?
Nissan released some bulletins warning owners not to use it and it's not necessary. Just use some higher octane gas here and there if you want to keep your valves free of carbon buildup.
G20 Senior Member
I used it and it's fine. Lucas, Chevron, etc...
i use the Chevron stuff when i go on a road trip. still want to try the Lucas.
I use seafoam and it worked fine. got better gas milage too
G20 Junior Member
i have tried most of the name brands an some off brands and never had any issues i would say most of all stay away from cheap low quality fuels and you should be fine... also keepin up on your oil changes should help keep deposits down as well
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
