Hole in "flex pipe" ?
Results 1 to 10 of 10
Thread: Hole in "flex pipe" ?
  1. #1
    G20 Guru DaPCWiz's Avatar
    Join Date
    Mar 2002
    Location
    Northern NJ
    Posts
    1,837
    ok so my car is making a sound like there is a hole in the exhaust (93.5 P10), so I take it to the mechanice to have it checked out. He tells me there is a hole in the "flex pipe" before the cat. Is that like the headers? or is there something between the headers and cat that is called a "flex pipe" ? He told me a bunch of stuff that sounded like bs after that about prices and cuting it and fixing the pipe and whatever... so I figured I'd see what I can find out here.
    93.5 P10: Sold
    96 S14: Track / Summer Toy
    05 Saabaru: Daily
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Senior Member littlerudegirl's Avatar
    Join Date
    Mar 2002
    Location
    Yer Mom's house
    Posts
    586
    Find someone who may have just ordered new headers and ask them to purchase their old OEM flex pipe... I forget who I sold mine to, was it Fray?? He had a hole in his flex pipe, and I think brand new they're like $200?
    Why would he cut the flex pipe to fix it, theres a hole in it already... but like I said, try to find a used one or just use some duct tape
  4. #3
    G20 Guru Domiken's Avatar
    Join Date
    Apr 2002
    Location
    Queens-New York
    Posts
    7,570
    Those little wire things is what flexes and that is the flex pipe (downpipe), it is there so when you haul ass with your engine movement, the pipe doesnt brake, as you do know your engine moves when you drive at different RPMS. It drops back and goes forward, the flex pipe flexes to accomodate the movement because if it wad a hard pipe it would have broken long ago. The wires somehow probably dragged something which made a hole in it. Buy a new downpipe for like $100, i always see P10's in junkyards and the downpipes are $35
  5. Remove Advertisements
    G20.net
    Advertisements
  6. #4
    Join Date
    Mar 2002
    Location
    Northern NJ
    Posts
    1,837
    thanks for the info guys, it is greatly appreciated
    93.5 P10: Sold
    05 Saabaru: Daily
  7. #5
    Join Date
    Apr 2002
    Location
    Queens-New York
    Posts
    7,570
    Thats what were here for buddy!!
  8. #6
    G20 Member jdragonprc's Avatar
    Join Date
    Apr 2002
    Location
    NorCal-Hayward
    Posts
    453
    i don't know if i'm too late on this thread.. but to throw is some more info... a flexpipe should not cost more than $100 to be replaced... i had my hotshot header flexpipe replaced for $75 flat...
    if you go to midas or any type of "big name" exhaust place they'll charge a lot more...
    but if you go to a smaller shop, it shouldn't cost that much...
    and small shops do decent jobs too...
  9. #7
    Join Date
    Mar 2002
    Location
    Northern NJ
    Posts
    1,837
    once again thanks for all the info... I got one more question. I live up in NJ, do you guys think my car will pass emmisions inspection w/ a hole in the flex pipe? I'm due for inspection this month
    93.5 P10: Sold
    05 Saabaru: Daily
  10. #8
    G20 Newbie TardBarnEscapee's Avatar
    Join Date
    Jun 2003
    Location
    Wells Maine
    Posts
    29
    My story.
    This is what happened when my flex pipe needed replacement...
    http://www.g20.net/forum/showthread....threadid=11352
  11. #9
    G20 Senior Member
    Join Date
    Mar 2002
    Location
    SINY/Brick City
    Posts
    626
    you will NOT pass inspection with an exhaust leak of any kind, especialy before the cat.
    a good temporary fix is some muffler tape (when it heats up it hardens) but that wont hold for long. nows a good time to get a hotshot header. thats what i did when i got a hole in my pipe. think about it even if you go used a flex pipe installed could cost up to $100, and thatsa good price. you can get the hotshot header for around $390 now (i bought mine last year from sr20development for $410)
    HS claims 12HP and 10 ft/lb of torque i dont know about that much but there is a big diffrence in power.
    get the header it comes with a new flex pipe!!
    BTW if your realy cheap and dont care about preformace you can get a pacesetter for real cheap, i think there like $200 brand new
  12. #10
    G20 Member
    Join Date
    Jun 2003
    Location
    Connecticut, US
    Posts
    178
    Same thing happened to me. Apperently the flex section holds moisture which causes it to rust faster. If you go to Midas or any where else they will want to replce the whole header. This will cost 400+ easily. The place i guy i went to can get just the flex section and weld it on. he charged $140 for the new section and labor, which is a lot cheaper than replacing the headers. Its common for a lot of older cars for this problem, it happened to my old car, and my sisters. I guess northeast weather will do that to cars.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
