tune up question....
I tried the search function but I didn't get what I wanted. I'm hitting 67,000 miles on my G and I was wondering what kind of tune up I should do. All I did was changed the automatic transmission fluid, that's about it. All I could think of on the top of my head is a coolant flush and fuel filter replacement. Anything else I should do? My engine is running kind of sluggish and I need some advice so that it can run smooth again. Thanks.
G20 Senior Member
Scheduled 60K maintenance is air filter, spark plugs, coolant, fuel filter, injector/carbon flush, clean throttle body, idle adjust, oil/filter change. Check your brakes and tires for wear at that mileage too.
G20 Senior Member
I'm a big fan of flushing out the old brake fluid and replacing it with new every two years at minimum.
G20 Guru
Damn U knew all this off the top of your head....
I bought mine with about 60 so I did the air filter,coolant,fuel filter,injector/carbon flush,and oil myself.
Brakes and tires are fine to me so far....
I didnt bother with the spark plugs and I didnt even think about the throttle body and idle adjust....HOw important do U think this is G20-tech????
What about the timing belt? should I change that also? Also for the injector/carbon flush, do I buy the bottle or should I go some place where they use a machine for the flush? Thx again.
G20 Guru
I just used a bottle of the expensive stuff.....cant remember which one exactly...dont know if a machine would be more beneficial or not though....
Oh and U shouldnt have to do timing belt for a long while....
You doesnt have a timing belt.
G20 Senior Member
No timing belt, you have a chain.
Theres always something to replace and fix, just keep looking around
lol thats some great grammar by me.
el capitán Nismo
No timing belt...just a chain which is a less headache for us. Do the plugs if you haven't. The scheduled maintenance and under hood sticker says every 60K for plugs. If you haven't done cap and rotor it never hurts. Check your wires "while you're there".
G20 Guru
Should be less than 10K Ohms per foot.
G20 Senior Member
The TB cleaning/idle adjust is important. Alot of carbon builds up in the throttle body and on the throttle plate which can starve the engine of air at idle causing low idle and stalling. The plugs can go alot longer than 60K, but thats when they're scheduled so we do it. Since they're pretty cheap and easy to do, I would do them also. Oh yeah, a flush of the brake fluid was just added to our 60K schedule, thats a good idea too.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
