Front Engine Oil Seal
Results 1 to 5 of 5
Thread: Front Engine Oil Seal
  1. #1
    G20 Member
    Join Date
    Oct 2013
    Location
    Suffolk Virginia
    Posts
    120
    I just swapped out the front crankshaft oil seal and drive belts on my 2000 G20 which was fairly easy. The only difficulty I encountered was finding the correct size screws/bolts to fasten the puller to the crankshaft pulley to enable removal. I found some on my spare metric nuts and bolts collection but I have no idea what size they were. Perhaps someone knows so they can post the size for future reference.
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Senior Member Y2KG20's Avatar
    Join Date
    Aug 2012
    Location
    Springfield, MO
    Posts
    766
    I use the cam cap bolts. I can use my tap size to find out if you need.
    1999 G20 - SR20VET : GTX3076R : 6 Speed : ORC 659D Twin Disc : Black Ops 1600cc : AEM Infinity 6 : E85
    2002 G20 - SR20RR : GTX2867R 14 Psi : RE4F03B Transgo HD Shift Kitted : 4x4 Injector setup : 3" Exhaust : Factory ECU + AEM FIC6 : E15
  4. #3
    G20 Member
    Join Date
    Oct 2013
    Location
    Suffolk Virginia
    Posts
    120
    Quote Originally Posted by Y2KG20 View Post
    Thanks for your help. I tried my tap set but did not have the correct size. No need to go through all that trouble taking off splash shields and stuff to try your taps. I thought someone may know the fastener size.
    Thanks
  5. Remove Advertisements
    G20.net
    Advertisements
  6. #4
    G20 Member olivertwist's Avatar
    Join Date
    Feb 2009
    Location
    Arkansas
    Posts
    209
    I will be doing this on my sister's '00 soon, so I can get the size if someone doesn't beat me to it.
  7. #5
    G20 Member
    Join Date
    Oct 2013
    Location
    Suffolk Virginia
    Posts
    120
    Quote Originally Posted by olivertwist View Post
    As Y2KG20 mentioned you can use some camshaft capscrews if you have some available. The factory tech manual does not mention what size to use. There is just enough room to pull off the crankshaft pulley by the way. No more, no less.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
