The main girlfriend aka the reason I'm broke
Results 1 to 12 of 12
Thread: The main girlfriend aka the reason I'm broke
  1. #1
    G20 Newbie
    Join Date
    Jan 2017
    Location
    Albuquerque
    Posts
    5
    So I just joined this forum after getting a 2000 P11 as a daily, so I will just do a pix heavy bring up to date type thing, so you guys can see what I have going on.......
    Started with a 1980 S110, but due to a fire in the shop due to a persons negligence and being dumb all the parts missing in these photos got burned up
    so with S110 parts impossible to find at this point I can keep going on it and just patch her together all race car style or find something else since at this point since I have a bunch of parts collected such as my transmission and half paid on my engine.....
    came across this
    which I like the S12 more then the S110 I have owned both of them before so was kinda of a score
    so it begins
    a little rear end work
    snack time
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Newbie
    Join Date
    Jan 2017
    Location
    Albuquerque
    Posts
    5
    a little foam fill
    a
    oval port to round port adapters
    a little head work
    working on getting the front end together
    decided to use different front knuckles for better geometry
    which I just picked up last weekend
    if you are on Ratsun.net or Maxima.org I have threads since the beginning and on Club-S12.org since I switched to the 86
  4. #3
    G20 Member MFNchip's Avatar
    Join Date
    May 2016
    Location
    Holiday, FL
    Posts
    146
    Maybe use the s110 platform into the p11. RWD . Only seen 1 online. That Would be the tits!!!! Looks like the juniors (cats) are lovin it too.
  5. #4
    G20 Member olivertwist's Avatar
    Join Date
    Feb 2009
    Location
    Arkansas
    Posts
    209
    ^I was thinking the same thing about the cats.
  6. #5
    G20 Newbie
    Join Date
    Jan 2017
    Location
    Albuquerque
    Posts
    5
    Quote Originally Posted by MFNchip View Post
    If I ever get though my other cars and decide to build the P11 other then just engine upgrades I would use a GTiR or X-trail GT trans on a SR20VET. The engine for the S110 was in the shop when it burned, and I already had sold the rods out of it to someone for their L/Z build
  7. #6
    G20 Newbie
    Join Date
    Jan 2017
    Location
    Albuquerque
    Posts
    5
    New lower bracket is on order from BC hope it doesn't take to long to get here
    Got steering rack mounts made this weekend
    I can still get my starter out without taking it apart so that a plus
    I did lose a few degrees of ackermans but I am going to leave it as a movable mount so I can dial some more in if needed for the hair pins....
  8. #7
    G20 Newbie
    Join Date
    Jan 2017
    Location
    Albuquerque
    Posts
    5
    did some odds and ends this weekend, put the new fusible links that were needed in.
    cleaned headlight switch
    hooked up some power
    found out that both my head light motors work, so thats a score just need to make some linkages for them still going back and forth on how I'm going to make them.... fully functional sleepy eyes would be cool but I already have enough to do with out having to make complicated parts....
    have this ready for the plug I need to make for the new spline and double ujoints set up that I need to order
    had some fun at 0.040 for job #2
    "I can sits here with out being in the way"
    started getting this set up, according to the rope I need a 9 foot hose made
    "pet me I know you want to"
    need to work out what to do with the wiring, the two small wires go to the ETS-PRO but the other two are the pressure switch to kick the pump on via relay, from what I can tell by what little I can find online I have one as a ground and one to ground the relay, with a switched power wire to control the power wire for the pump...... but it's something I want to for sure on since I don't want to fry anything on this cuz it's parts that are a bit hard to come by here.....
  9. #8
    G20 Newbie
    Join Date
    Jan 2017
    Location
    Albuquerque
    Posts
    5
    Got some parts in last week.
    just one more part for this stuff to get, but just getting a coupler to make sure I get the right size for the rack, this one (part in the bag) is to big so have the other one that it might be the right one on the way and once that gets here, if it is the right one I will return them and get the part I really need....
    made the part I needed for the steering shaft to be welded in
    new lower mounts for the coil overs came also
    they are taller which is fine since I was kinda bummed with the S13 that I wouldn't have been able to go 4X4 stance at all
    just need to make my tension rod bracket spacers to take care of the angle on the tension rod other then that, it's starting to look not to bad of angles
    Also got started on this, have them all assigned to their seat, have some 400 grit on the way so when that gets here have another night of fire starting
    pix before I do the last row
    have some clean up to do from when the valve guides were done and the 400 grit on the seats then a run though the dish washer and put them together so I can figure out what buckets I need to order and the heads will be ready.
  10. #9
    G20 Newbie
    Join Date
    Jan 2017
    Location
    Albuquerque
    Posts
    5
    Found the right spline for my steering rack so now have to send back the couplers and order the U joint I need for that then I should have all the parts for finishing up the steering other then tie rod ends which I want to work out how much of a spacer I can run on the inner tie rods to get a bit more angle if my rack will allow them, and get the knuckles so I can see how long they need to be.
    for hubs I modified some rear S13s
    "hmmmmm new parts box" "so what didn't you smell this sandwich"
    test fitted the hubs
    I just need to take a little more off the inside on the back side just to be sure it's not hitting on the CV shaft before the bearing, it wasn't but close so just to be on the safe side..... Then there is a matter of brake rotors which I am looking into a few options....
    also took care of this issue on lil G this weekend
  11. #10
    G20 Newbie
    Join Date
    Jan 2017
    Location
    Albuquerque
    Posts
    5
    took on my intake this weekend just some mild port matching and clean up
    I did open this up a little on the back side
    just a little ledge to get rid of
    just need to drill and tap holes for throttle body and match that up and clean out runners and thats all set other then getting gaskets and matching those up
    also have one of my adapter plates (oval to round port) all set but called it a night while the glue was setting that I used to glue the round port NWP spacer to adapter plate to lower intake so I can keep them all together in place while I finish porting so should have those down this week and then get the heads ran though the dish washer and start assembling them. Hope to get me credit bills paid down and start ordering lower end parts soon.
  12. #11
    G20 Newbie
    Join Date
    Jan 2017
    Location
    Albuquerque
    Posts
    5
    well finished off my adapter plates, so those are all ready and just have clean up and assembly on the rest of the intake. Should be start getting heads assembled soon also. Ordered last of the parts I need for steering shaft so next time I get to the car shop I will be putting that together.
  13. #12
    Questioning Answers ENO's Avatar
    Join Date
    Jan 2006
    Location
    Not Philly area.
    Posts
    6,817
    nice... there hasnt been a thread like this in a while....glad you decided to post this build up here
    The longer the explanation, the bigger the lie.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
