PCV Valve Grommet Broke, debris fell inside...
Results 1 to 4 of 4
Thread: PCV Valve Grommet Broke, debris fell inside...
  1. #1
    G20 Newbie
    Join Date
    Feb 2017
    Location
    Houston, TX
    Posts
    Good morning everybody!
    I was attempting to change my PCV valve this weekend, and the grommet crumbled in my fingers.
    Along with this magical senario, some small pieces fell inside the valve cover.
    First, please tell me, should I be concerned enough to not drive the car until I can remove the covers and attempt to fish out the debris?
    - If you feel this is something that can ruin everything and i must fix before driving... then can an oil change fix it? or do i have to open the valve covers? if i have to open up the valve covers, would you suggest an easy way to get the crud out? I've read thru searches and some people used a vacuum then an oil change.
    Second, would you agree that my chances of engine issues are slim (with the debris that fell inside)?
    I've never had this happen before. I am not sure if I should be concerned, or if the debris is so small it will just get disintegrated.
    thank you!
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Guru JDM_Ej's Avatar
    Join Date
    Dec 2006
    Location
    CT
    Posts
    1,822
    I would pull off the valve cover and remove any pieces you see definitely.
    2010 Mazda MazdaSpeed 3 - Celestial Blue
    2000 Honda CR-V EX - The work horse!
    2002 P11 KH3 w/205k miles (SOLD!)
  4. #3
    G20 Member MFNchip's Avatar
    Join Date
    May 2016
    Location
    Holiday, FL
    Posts
    146
    Also there is a restricter inside that pcv hose if you change the hose too. Clean it. Ej is right , even though he sold a p11 and drives a Honda. Hahaha. JK.
  5. Remove Advertisements
    G20.net
    Advertisements
  6. #4
    Join Date
    Dec 2006
    Location
    CT
    Posts
    1,822
    lol my P11 was rusting away unfortunately.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
