code P0505
Results 1 to 5 of 5
Thread: code P0505
  1. #1
    G20 Newbie
    Join Date
    Apr 2014
    Location
    Waterford, Mi
    Posts
    6
    code P0505
    I need help, have this code, I know it's the idle control valve but it's costly and have read when some have replaced it it didn't solve the problem. Mine is not idling it stalls and is getting worse. It seemed to do it when the engine was hot but now seems most of the time. I can keep it going by brake torqueing it. While driving it's ok just when stopping at traffic lights etc. Any help?
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Senior Member
    Join Date
    Aug 2012
    Location
    Springfield, MO
    Posts
    744
    I'm guessing that you have a 2000+ P11. Pull the IAC plug and see if coolant has made it's way into it. Very common problem with them and usually burns up the stepper driver chip inside of the ECU. If it hasn't I would suggest bypassing the throttle body coolant line.
  4. #3
    G20 Member MFNchip's Avatar
    Join Date
    May 2016
    Location
    Holiday, FL
    Posts
    112
    I got the 505 on WOT everytime and it was the spring was weak on the inside. Played with the spring a week then Pulled one from the scrap yard cut out a rubber fiber gasket and all good now. +2 on the bypass the coolant save you a lot of trouble.
  5. Remove Advertisements
    G20.net
    Advertisements
  6. #4
    G20 Newbie
    Join Date
    Apr 2014
    Location
    Waterford, Mi
    Posts
    6
    Thanks for the replies. I should have said it's a 1999 G20 4 cly
  7. #5
    G20 Newbie
    Join Date
    Apr 2014
    Location
    Waterford, Mi
    Posts
    6
    Does anyone have info on this problem? The part is $200 and I have read that some have changed this and still had the problem. I don't want to waste money if I don't have too. Thanks for helping!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
