Infiniti G20 T - 5 Speed Manual - Runs great but AC is not working
+ Reply to Thread
Results 1 to 1 of 1
Thread: Infiniti G20 T - 5 Speed Manual - Runs great but AC is not working
  1. #1
    G20 Newbie
    Join Date
    Nov 2006
    Location
    San Antonio, TX
    Posts
    45
    Infiniti G20 T - 5 Speed Manual car for sale - $1200
    Car has been kept up and many parts replaced. Not too many miles put on the car since I've owned it. Always used Mobil 1 synthetic for oil changes. Car still runs and has been my daily driver for the past 6 years. Transmission and engine still running strong.
    The Good:
    Radiator replaced
    Both belts recently replaced
    Power Steering High Pressure hose replaced
    Both CV joints on the front axles replaced
    Shocks replaced
    Inner and Outer Tie Rods replaced
    IAC valve replaced
    New rear tires (Fronts still have 20k to go at least)
    New air filter and cabin air filter installed
    Recent oil change
    The Bad:
    AC is not working (Most likely needs a new compressor as that is where it is leaking but has not been diagnosed by mechanic)
    Belt squeals on car startup most likely due to compressor problem. (Belts have been replaced and are new)
    Paint is coming off on the roof, hood and spoiler.
    Dash is cracked
    Photos:
    https://sanantonio.craigslist.org/cto/6131944038.html
+ Reply to Thread
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may post attachments
  • You may edit your posts
