Lower Car
Results 1 to 4 of 4
Thread: Lower Car
    Apr 2002
    Denver
    23
    Lower Car
    Does anybody have any suggestions as to what lowering springs I can use on my 95 G20?
    Nobody f's with the Jesus Yahnozha's Avatar
    Mar 2002
    Land of Enchant
    11,381
    theres a handful, try using the search function, or filter thru the suspension section, this topic is a pretty regular one...and Welcome, its good to see more faces in here.
    P@ = Pat - 99' Red P11 Daily Driver (298K) - 95' White P10 Daily Driver (RIP) - 97' Black Pathy 4x4 (170K+) - 90' Maroon Z32 NA (160K+) rebuilt...f***ing oil leak somewhere - 01' Pathy 4x4 (140K+)
    G20 Member Outbreak's Avatar
    May 2002
    Norway
    157
    I use H&R, 35mm. Good stuff.
  5. #4
    G20 Guru MR. RYTE's Avatar
    Mar 2002
    San Antonio, TX
    5,270
    Re: Lower Car
    Although I don't have the setup myself, I've rode in a G that has the Ground Control/KYB AGX setup. The spring rates were 275 front/200 rear on 205/40/17 tires. It was a "tad bit" jiggly, but the car rode almost as well as stock. For more info, www.ground-control.com .
    Hope that helps.
    Real name:Howard Wright
    Current mods:S3 cams, TopSpeed header, M3-style rear wing, P11 rims, Recaro LS-L seats, Pioneer DEH-P6800MP CD/MP3 head unit w/6.5" Audiobahn AS65Q all around
    THOU SHALT NOT MOD THAT WHICH THY CANNOT MAINTAIN" -thus speaketh Mr. Ryte
