[Videos] Can you identify this noise?
Results 1 to 6 of 6
Thread: [Videos] Can you identify this noise?
  1. #1
    G20 Member misterxadobo's Avatar
    Join Date
    Jun 2007
    Location
    Roseville, CA
    Posts
    209
    Hello G20.net. Seeking your help in identifying a noise coming from what seems to be where my drive belts are. Its sounds like plastic vibrating/clacking against metal and is only present at certain RPMs. I have not been able to spot any plastic components or panels vibrating within the engine bay.
    Any insight is much appreciated! Find below a video from within the car, above the engine, and below the engine.
    In Car
    See below a couple more videos
    Update May 18, 2017
    -Loosened the alternator tensioner and the sound got louder
    -Tightened the alternator tensioner and the sound went away after commuting to and from work. On the 25 mile drive to work, the sound would come on at around 4000-47500 RPM, and also at around <1000RPM
    -The offending sound is all but gone as of my latest drive. Sound only seems comes on when I have the air conditioning turned on now
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    Join Date
    Jun 2007
    Location
    Roseville, CA
    Posts
    209
    Above Engine Bay
  4. #3
    Join Date
    Jun 2007
    Location
    Roseville, CA
    Posts
    209
    Below Engine Bay
  5. Remove Advertisements
    G20.net
    Advertisements
  6. #4
    G20 Member MFNchip's Avatar
    Join Date
    May 2016
    Location
    Holiday, FL
    Posts
    142
    Alternator bearing sounds like. Take the belt off and start see if it's there still. if its gone open the alternator and clean and regrease. It's easy there is a pinhole in the back to hold the brushes down when you put it all back together.
    P.S. stay away from those belts when it's on, did you see that video I posted?
  7. #5
    Join Date
    Jun 2007
    Location
    Roseville, CA
    Posts
    209
    Quote Originally Posted by MFNchip View Post
    Thanks MFNchip
    Is there a specific part of the alternator to clean a regrease? Should I just replace the alternator altogether if I'm taking it out?
    Brushes?
    Also no I haven't seen the video you posted. Where is it?? I'm curious now
  8. #6
    Join Date
    May 2016
    Location
    Holiday, FL
    Posts
    142
    There is bearings on each side. A bigger one under the pulley you have to remove pulley to get too. And a little on the back shaft. I used electronic cleaner and cleaned everything and let dry in the sun. You'll see if brushes need replaced when you open it. They should spring out half way through the round space in the back where the commutator shaft part connects to it. Make sure its dry before you put it back on. And if you grease it back up before driving it to much you might not have to replace anything yet. Make sure the belt is at FSM spec . Too tight = screwed bearings, too loose burnt belt. The video is in Wire Spool thread. BE extra careful when working around spinning moving parts. O and use lithium EP 2 grease for bearings. They are sealed bearings but you can use a paper clip to open it just keep it flat as possible, and use same paper clip to hold down brushes
Posting Permissions
  • You may not post replies
  • You may not edit your posts
