Horn and windshield wiper problem
Results 1 to 4 of 4
Thread: Horn and windshield wiper problem
  1. #1
    G20 Newbie
    Join Date
    Mar 2004
    Location
    new york city
    Posts
    6
    I have a 1992 G20 and my car horn does not work. My mechanic checked the fuse which was ok and told me it has to be inside the steering wheel which would cost alot. Is there any way to fix this myself?
    I am also having problems with my windshield wiper. It stops in the middle of the windshield. How can i fix this? pls help thanks.
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Member krazeguy's Avatar
    Join Date
    Jul 2003
    Location
    New Zealand
    Posts
    325
    Dont know if this is any help, but my horn stopped working after I pressed it lots, then the next day it worked fine.
    Also check all the connections, also use a multimeter to make sure a current is going to the horn when someone presses the horn, if it is and no sound it could be the horn itself.
  4. #3
    G20 Guru mattb's Avatar
    Join Date
    Sep 2002
    Location
    Herndon, VA
    Posts
    5,585
    The wipers may be a bad wiper motor or transmission.
  5. #4
    G20 Guru
    Join Date
    Apr 2002
    Location
    VA
    Posts
    2,313
    My horn also stopped working one day. But strangely enough about an hour later it started working again and I havent had a problem since. Now my cruise control is kind of messed up so I suspect there is a bad contact at the slip ring connection.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
