HowTo: P10/P11 Replace Valve Cover Gasket
Page 1 of 4 1234 LastLast
Results 1 to 20 of 79
Thread: HowTo: P10/P11 Replace Valve Cover Gasket
  1. #1
    G20 Guru DaPCWiz's Avatar
    Join Date
    Mar 2002
    Location
    Northern NJ
    Posts
    1,837
    Talking HowTo: P10/P11 Replace Valve Cover Gasket
    I'm not like the most experienced car guy, but I do like to do stuff myself when I can, I enjoy it. Yesterday me and some friends replaced my valve cover gasket and I'm very proud of myself, as well as really happy that I got to see under the valve cover. Here are pics!
    edit: also, mad props to my friend G who helped me out a great deal with this!
    the gaskets have arrived!
    the valve cover cleaned before we open her up
    G (burningsquirrels) claims to be a domesitc guy, but you can clearly see here that he's crazy about imports!
    me working on the car
    the motor opened up!
    the timing chain
    the diiiiiirty valve cover
    the valve cover being cleaned with simply green and water
    using my mom's hair dryer to dry out the valve cover! LOL
    another shot of the motor
    my friend cleaning the edges as we prepare it for the new valve cover
    the gaskets and sealant being applied
    the valve cover is ready to go back on!
    the cover back on, to see the completed assembly, check the first pic
    93.5 P10: Sold
    96 S14: Track / Summer Toy
    05 Saabaru: Daily
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Guru poppy_morenito's Avatar
    Join Date
    Mar 2002
    Location
    Miami, Fl
    Posts
    3,357
    I need a friend like that .....
  4. #3
    uruG 02G Gealousy's Avatar
    Join Date
    Oct 2002
    Location
    D. Co.
    Posts
    7,417
    Sweet! You should've painted it while it was off though... I would have... overall, A+ job man!
    2004 G35X - 40,590 miles: 080610
  5. Remove Advertisements
    G20.net
    Advertisements
  6. #4
    USPSA M/Pro burningsquirrels's Avatar
    Join Date
    Jun 2003
    Location
    Area 6
    Posts
    5,122
    crazy about imports my ass... lol j/k
  7. #5
    G20 Guru paradyme's Avatar
    Join Date
    Mar 2002
    Location
    Bloomfield NJ
    Posts
    1,087
    What prompted you to just changed the valve cover gasket? I guess your in need of a tune-up now. While you were at it you could have just changed your spark plugs & wires, cap & rotor fuel filter. So how did the simple gasket change turn out.
  8. #6
    Join Date
    Jun 2003
    Location
    Area 6
    Posts
    5,122
    he recently had a tune up. we changed the gasket because it was leaking like a newborn baby after a gallon of water. well, something like that.
  9. #7
    Prince of Joy MrFancypants's Avatar
    Join Date
    Dec 2002
    Location
    Tucson, AZ
    Posts
    4,614
    Hey man I dont mean to rain on your parade, but you only need to put the RTV on the 3 half-moon sections of the gasket. You slathered it all over!
    Congrats though!
    - Greg -
  10. #8
    G20 Member
    Join Date
    Mar 2002
    Location
    dayton oh
    Posts
    382
    how much was that gasket set?
    so those gaskets are reusable?
  11. #9
    G20 Guru NismoPC's Avatar
    Join Date
    Mar 2002
    Location
    Mansfield, OH
    Posts
    2,120
    No. What he is stating is that you don't put RTV gasket sealant all over the "new" valve cover gasket, only on the half moon sections of the gasket when replacing it.
    What they did was major overkill, but should not cause any problems.
  12. #10
    Join Date
    Jun 2003
    Location
    Area 6
    Posts
    5,122
    the gasket set was eight bucks.
    i put rtv on everything, because a top end gasket like that could use it regardless.
  13. #11
    Join Date
    Dec 2002
    Location
    Tucson, AZ
    Posts
    4,614
    Well technically it is a gasket, so it's supposed to be replaced every time you pull the valve cover. But honestly, most people reuse them unless they are really old and/or dried out. With all that RTV all over the place, that gasket wont be reusable, though. Itll also be a lot of work to clean the mating surfaces if you ever pull the cover again. Just cleaning the 3 half-moons with a razor blade is a pain in the ass!
    - Greg -
  14. #12
    G20 Guru mustang dude's Avatar
    Join Date
    Mar 2004
    Location
    Baton Rouge
    Posts
    1,242
    The inside of your engine looks alot cleaner than the inside of the one I changed.. The underside of the valvecover was black... nothing but burnt on oil.. it was NASTY!!! Oh and when I installed the gasket I installed it completely dry without any leaks.
    Scott
    2002 Toyota Highlander 3.0 VVT-IE V6 (stock)
    1988 Mustang GT (auto) blown tranny
    93 Infiniti G20 (RIP)
  15. #13
    Join Date
    Jun 2003
    Location
    Area 6
    Posts
    5,122
    if you pile it on heavy enough the first time around, you can pull it off like a spaghetti string, lol. a razor gets it off easy. besides, it's not like he's going to take it off all the time. no mods planned at all, he's saving up for a 240.
    once he gets that, then i get to have fun
    i wonder where i could pull a few complete 240 motors... hm...
  16. #14
    G20 Senior Member abdulmo86's Avatar
    Join Date
    Feb 2004
    Location
    arlington ht,il
    Posts
    647
    how did u clean the cover and ur engine bay is clean what did u do to clean it
  17. #15
    Join Date
    Jun 2003
    Location
    Area 6
    Posts
    5,122
    arjun used a standard engine degreaser, simply green.
    personally, i like cheap oil eater with water for general cleanup. for small parts i use brake cleaner.
  18. #16
    Join Date
    Mar 2002
    Location
    Northern NJ
    Posts
    1,837
    G - thanks for replying for me
    abdulmo86 - the engine bay has been untouched as far as cleaning... the only thing I cleaned was the valve cover and a little bit of the surrounding area - and as G said, I used simple green.
    93.5 P10: Sold
    05 Saabaru: Daily
  19. #17
    Join Date
    Feb 2004
    Location
    arlington ht,il
    Posts
    647
    can u post the exact link for where to buy gasket i searche infinitipartsusa nand could not find it. plz exact link thanks
  20. #18
    Join Date
    Mar 2002
    Location
    Northern NJ
    Posts
    1,837
    here ya go
    93.5 P10: Sold
    05 Saabaru: Daily
  21. #19
    G20 Guru Garrett's Avatar
    Join Date
    Aug 2003
    Location
    Malibu, Ca
    Posts
    4,301
    Is the SR20DE pressurized? How hard was it? I have to replace my valve cover, with my new red one, and I was just woundering how hard it was. Probably something i will be doing this Saturday.
    --Garrett
    To strive; to seek; to find, but not to yield.
    ACU
  22. #20
    Join Date
    Mar 2002
    Location
    Northern NJ
    Posts
    1,837
    the bolts/ valve cover came off and went back on without too much effort.
    93.5 P10: Sold
    05 Saabaru: Daily
Posting Permissions
  • You may not post replies
  • You may not edit your posts
