Power Window Part Name or #
Results 1 to 7 of 7
Thread: Power Window Part Name or #
  1. #1
    G20 Newbie
    Join Date
    Jul 2003
    Posts
    12
    Gentlemen,
    I'm trying to find out the name or # of a part related to my power window. I've checked past threads here and its been referred to as "regulator", "window regulator box", "amplifier", "relay", "thingy". Can anyone tell me EXACTLY what this thing is called so I can try and locate it? Better yet not only what to call it but where to find it cheap as well?
    Obviously its located within the door panel, its white, rectangular, about the size of a cigarrette pack, and on it its marked:
    AMP ASSY-AUTOP/W
    28515 60V00
    ET881 12V
    307 JIDECO 307
    30723S
    Any help would be much appreciated!
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Newbie
    Join Date
    Jul 2003
    Posts
    12
    Power Window (cont'd)
    Some more names i've encountered:
    "Power window relay"
    "Window amplifier"
    "Controller Box"
  4. #3
    G20 Newbie
    Join Date
    Jul 2003
    Posts
    12
    Question Answered
    For future reference should anyone need to know...
    The Infiniti dealership does refer to this part as a "Power Window Amplifier" and I was told the part# is B851560U85. Cost is 63.38 from Scottsdale Infiniti.
    If your window aint working but your motor seems fine, the fuse seems fine and your switch is ok this just might be the culprit. It was for me. Heads up.
  5. Remove Advertisements
    G20.net
    Advertisements
  6. #4
    G20 Member
    Join Date
    Mar 2010
    Location
    new zealand
    Posts
    203
    Same for me, I pulled mine apart & resolded a solder point that had failed.
  7. #5
    G20 Member
    Join Date
    Aug 2010
    Location
    North Carolina
    Posts
    301
    I re-soldered the bad point, but my window still does not work.
    I have tried the amplifier with two motors that have no more than 2.2 Ohms of resistance (.7 and 2.1 Ohms) when I touch the terminals with the multimeter leads. (I believe the motors to be good.)
    No luck.
    The power windows fuse is good.
    How can one tell if the window switch is bad?
  8. #6
    G hoarder
    Join Date
    Aug 2007
    Location
    Columbia SC
    Posts
    2,316
    check for a resistance change across the switch when it is activated
  9. #7
    G20 Member
    Join Date
    Aug 2010
    Location
    North Carolina
    Posts
    301
    Thanks Greenless. I appreciate it. I am going to try what you have suggested here.
    I meant to post my question in a different thread, so I'll continue my inquiries at the thread -----> http://www.g20.net/forum/showthread....71#post1614971
Posting Permissions
  • You may not post replies
  • You may not edit your posts
