Ksport although has a suspesion kit for the P10 or P11 1200$
http://www.ksportusa.com/products/coilovers.html
They also have a dealership in the UK.
http://www.k-sport.co.uk/store.asp
does anyone have a picture of a rear strut bar installed?
Octotats goodness, I should go through the first post and add new goodies sometime.
- j0n
I love how that sits so low and flush. Though the stillen isn't that much higher its a good inch or two above that, so if you snowboard like me it can cause problems.
Gmac
Actually, iirc when jd20jd had the Stillen RSTB installed, it sat a least 3" higher than Chuck's bar. Remember, the Stillen brackets that mount to the top of the rear strut towers, and then the bar goes straight across. It really impedes on an already small pass-through access IMO. Somebody has to have a pic of the Stillen RSTB installed!Originally Posted by Gmac03
I have one on both of my cars, just don't think I have any pics.
Gmac
Is it always scwared. cause mine is more oval. I'll take a pic as soon as i can.
OK...was that $327 shipped or before shipping?Originally Posted by 2000 G-Twenty-T
Actually, I bought a set of KYB AGX's from www.performancepeddler.com for $321 SHIPPED!!!
Use discount code: ebayrocks to get $10 off
Check it out, fellas...
Greetings fellow G's..
I've got 99' G20T
Looking to lower ride..
- Not really concerned with performance, moreso comfort level..since I dont race or anything..
Mainly looking to get...
- nice low look with max comfort level, and no cambering issues
(whats the max i should be looking to drop?)
- full kit with springs and shocks, at low price
- also would like it to be winter drive-able
- other than shocks/springs any other accessories needed as part of the lowering kit?
Any recommendations or links would be solid!!
Regards,
Dreyos
p.s: Has anyone dealt with Eibach "Pro-Systems" kit?
well manny peopl eon here have the tein/AGX combo's
Wheres a good place to shop for lowering springs and shocks?
Also what kind of shocks / springs should I be looking for if i want a lowered ride but soft suspension.
Ok so its down to between 2 springs i want to get..
- Tein S Tech F(1.8") R(0.8")
vs
- Intrax F(1.7") R(1.6")
Whats the deal with the Teins height ratio being so different from front to back?.... will it even out to give me a 1.5" avg drop on both sides?
Will intrax give me the lower drop without camber issues?
Which will give me a softer ride?
The Intrax are about $40-50 more than the Teins
.. I also need to drive in winter*
Let me kno your thoughts
thanks SER REAL!... looks good
Hiya from The Bahamas
I just got a 1998 Primera Camino and was wondering, with the bad roads and speed bumps over here, what is the best way for me to raise it a bit for street clearance ?
Thanks for the info
mybahamas
I want to order a set of agx struts but....
I'm trying to figure out why rear b14 agx struts should be used on the p11.
Also why does Pat refer to the p11 agx setup as ghetto in the post below?
http://www.g20.net/forum/showpost.ph...44&postcount=3
any help is appreciated. thanks
bump anyone got an answer to my question above?
ghetto= not a direct fitment. Go with pats recommendation.
May 2008 MOTM
Check out my T-Shirt company, funny/quality shirts: www.ratfinktshirts.com Code jesp414 saves you $3 per shirt.
