91-96 Infiniti G20 Suspension Modifications - Page 3
Page 3 of 6 FirstFirst 123456 LastLast
Results 41 to 60 of 116
Thread: 91-96 Infiniti G20 Suspension Modifications
  1. #41
    G20 Guru G20Pimp's Avatar
    Join Date
    Jun 2002
    Location
    Boulder, CO
    Posts
    1,301
    Get struts; and make sure that they're real teins, there's copies out there. I have HKS spring and stock struts/shocks and wish had done Shocks/struts at the same time...
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #42
    Automotive Design Concept Straitup D's Avatar
    Join Date
    Oct 2006
    Location
    MN Member 1of5
    Posts
    3,519
    any segestions on what struts/shocks are a good fit for the g's
    I got my springs from a hole saler
  4. #43
    Join Date
    Jun 2002
    Location
    Boulder, CO
    Posts
    1,301
    KYB AGX or GR2....
  5. #44
    I'm Better Than Zohaib DragonEye's Avatar
    Join Date
    Jun 2006
    Location
    Romeoville, IL
    Posts
    1,024
    Quote Originally Posted by G20Pimp
    KYB AGX or GR2....
    AGX>GR2
  6. #45
    Join Date
    Jun 2002
    Location
    Boulder, CO
    Posts
    1,301
    Adjustable vs. Non adjustable and AGX are a little more just depends on what you want if your going for mostly appearance and a little better performance then GR2, more performance and appearance too the AGX for the adjustability for track days and street performance..... GL
  7. #46
    Join Date
    Jun 2006
    Location
    Romeoville, IL
    Posts
    1,024
    GR2's wear out really fast AGX last a lot longer... I had them on one of my old cars and the AGX lasted a hell of a lot longer.
  8. #47
    The Emo Kid. 2000 G-Twenty-T's Avatar
    Join Date
    Aug 2005
    Location
    Independence OR
    Posts
    6,673
    im upset that we got gr-2s now, why do people recommend them? i feel like we wasted money getting them now. how long will they generally last?
    Feedback
    Move it cone. I eat cones like you for breakfast.
  9. #48
    G20 Guru amek's Avatar
    Join Date
    Feb 2005
    Location
    cali
    Posts
    1,707
    you get what you pay for... sell them to someone who needs em and invest in agx.. my rear shox are STOCK , like 1994 unless the guy i got the car from replaced them and the two front are monroe sensa trac... im not complaining, but ground control and agx will be on b4 summer. ...btw i miss your musk.
  10. #49
    Join Date
    Jun 2006
    Location
    Romeoville, IL
    Posts
    1,024
    people suggest them because they are the cheapest after market shock out there... and it would be unfair for me to specify milage because it depends on the driving you do.... the AGX are great for almost anything you do, but the GR2's will wear out in about a year or 2's time like i said depending on how the roads and conditions are..
  11. #50
    G20 Newbie rmyc's Avatar
    Join Date
    Sep 2004
    Location
    Corvalis/PDX OR
    Posts
    6,570
    This thread need to be updated... with all the other suspension parts
  12. #51
    G20 Guru casual's Avatar
    Join Date
    Mar 2002
    Location
    FL
    Posts
    5,866
    nismo p10
  13. #52
    G20.net "part-time" Janitor G20-Budo's Avatar
    Join Date
    Mar 2002
    Location
    Chandler, AZ
    Posts
    4,635
    Nice!! So who's buying them?
    -Kyle
    96' G20(VE)
    Calum RT | Innovate LC-1 | Ohlins | Octotat | LoCo Performance | Addco | SuperPro | VRS | AEM | Custom Steel | Factory Upgrades (Motor | VC | CAMS | Header | Brakes | Others)
    My Gallery
    My Feedback
  14. #53
    G20 Guru gomd3's Avatar
    Join Date
    Apr 2002
    Location
    MD
    Posts
    1,675
    I just installed Tein S and Gr-2's that I got from Nismo_sean... funny thing is that the car sits around the same height as before... guess my stock springs were sagging a bit...
  15. #54
    G20 Newbie BlackSRi-UK's Avatar
    Join Date
    Jan 2007
    Location
    Midlands uk
    Posts
    4
    sorry if this is in the wrong place, but theres something i need to know, possibly best answered by someone from the UK (such as mark). i have a p10 1.6 sri saloon/sedan. does anyone know if the springs and shocks designed to fit the g20/ eGT will fit straight on? are the std suspension parts for the 1.6sri and eGT the same part or should i convert to egt suspension and then look into lowering it, im assuming my shell and suspension mounting is the same as the eGT and g20....? i would like to lower my car 60 ish mm.... thanks
  16. #55
    G20.net Staff
    Super Moderator
    markbuts3's Avatar
    Join Date
    Jan 2004
    Location
    Derbyshire, UK
    Posts
    11,586
    The P10 1.6 rear springs are slightly smaller in diameter...
    To lower it 60mm you will probably need coilovers which will come with springs dampers and top mounts anyway.
    Just call me Mark
    My Site
  17. #56
    Join Date
    Jan 2007
    Location
    Midlands uk
    Posts
    4
    kool, cheers! should i put the rear suspension of an eGT hatchback onto my 1.6 saloon the? or is it not worth it/they wont fit(possibly differences btwn hatch n saloon but nothing i cn see from the manual? i already have rear disks so theres no advantage there... but it would mean i can get lowering springs for a gt and fit them to mine because they are easier to find...
    thanks in advance.
  18. #57
    G20 Newbie Spelunko's Avatar
    Join Date
    Dec 2006
    Location
    Taiwan
    Posts
    38
    Question:
    My car now has KYB G2 shocks and HKS Springs. Yes it is stiff and has lowered the car, but in the front from the top of the whell well on the frame to the top of the tire is about 1 finger width in height. In Taiwan ( Where I am currently living) you need to have about 1" clearance. I can't get my car inspected because the car is too low. So, is there a way to increase the height teporarily for the inspection as I have the system now set or will I need to change the springs or shocks?
    If I change and have an adjustable set up, will this adjustment only change the ride or can I adjust them to increase the height? I know: a silly question.
  19. #58
    G20 Senior Member HP10DRIFTPRIMERA's Avatar
    Join Date
    May 2006
    Location
    des plaines IL
    Posts
    518
    put smaller tires on it
  20. #59
    G20 Newbie
    Join Date
    Mar 2007
    Location
    queens
    Posts
    39
    are there traction bars for the p10?
  21. #60
    North Star Fighter KwikyMAN's Avatar
    Join Date
    Nov 2004
    Location
    A loT of pLaces
    Posts
    3,216
    i thought traction bars are mainly a rwd thing...?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
