How To: Replace Valve Cover Gasket
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: How To: Replace Valve Cover Gasket
  1. #1
    G20 Newbie
    Join Date
    Oct 2004
    Posts
    24
    valve cover gasket
    I need to replace my valve cover gasket...does anyone have any links on how to do it correctly, or have any tips? I'd like to do it myself if possible.
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Guru Garrett's Avatar
    Join Date
    Aug 2003
    Location
    Malibu, Ca
    Posts
    4,301
    If you already have one, it should be pretty streight foward, take off the bolts, replace the gasket, but them back on, someone would need to re-affirm this though, I dont' trust myself 100% under the hoot yet.
    --Garrett
    To strive; to seek; to find, but not to yield.
    ACU
  4. #3
    G20.net Staff
    Super Moderator
    markbuts3's Avatar
    Join Date
    Jan 2004
    Location
    Derbyshire, UK
    Posts
    11,585
    Read this thread, and read the replies regarding the sealant...
    Check steps two and eight on this page for the loosening/tightening sequence.....
    Just call me Mark
    My Site
  5. Remove Advertisements
    G20.net
    Advertisements
  6. #4
    GeeTwentyTee
    Guest
    Re: valve cover gasket
    Its very easy to do shouldibuy. Just take off the VC in this order...
    Then take off both the old outer gasket and the one that goes around the spark plug holes (on the inside part of the VC). Put some RTV silicone around the cresent shaped part of the new outer gasket and stick that on the VC (along with the new spark plug hole one, ya gotta buy both) and tighten the VC using this sequence...
    Tighten the bolts down to 6.5-7 foot lbs with a torque wrench.
    And thats it. Its really easy bro.
  7. #5
    Nobody f's with the Jesus Yahnozha's Avatar
    Join Date
    Mar 2002
    Location
    Land of Enchant
    Posts
    11,383
    Cool, you guys made the FAQ - Just be sure to note the torque value on those VC bolts....they are in IN/LB
    http://www.g20.net/forum/showthread....743#post136743
    P@ = Pat - No longer "The Man" - Odd greenish P11 Daily Driver (170K) - 01' Pathy 4x4
  8. #6
    G20 Junior Member clokwurk's Avatar
    Join Date
    Sep 2007
    Location
    south carolina
    Posts
    63
    Quote Originally Posted by Yahnozha View Post
    6.5-7 IN/LB?
    This conversion chart says that is ~.5 FT/LB.
  9. #7
    G20.net Staff
    Super Moderator
    markbuts3's Avatar
    Join Date
    Jan 2004
    Location
    Derbyshire, UK
    Posts
    11,585
    Quote Originally Posted by clokwurk View Post
    6.5-7 IN/LB?
    No the figures in the post above are in lb-ft but the FSM values are in lb-in
    http://www.g20.net/forum/showthread.php?t=21537
    Just call me Mark
    My Site
  10. #8
    Join Date
    Sep 2007
    Location
    south carolina
    Posts
    63
    Thought so. I just wanted to clarify the above post. It is a little unclear about which values are in what measurement.
    The way it read was different from the posts and the manuals as far as I could tell.
  11. #9
    The Emo Kid. 2000 G-Twenty-T's Avatar
    Join Date
    Aug 2005
    Location
    Independence OR
    Posts
    6,673
    question,
    could tightening these down too much cause any issues, if it doesnt result in breaking a bolt or torquing the gasket funny?
    it seems torquing down too far would cause minimal reverse "thermobloc spacer" effect.
    i ask because back in the day we did reannas valve cover, and we didnt have a torque wrench but it seems we tightened probably more than .5
    Feedback
    Move it cone. I eat cones like you for breakfast.
  12. #10
    Dude, your bed is a car..
    Join Date
    Jan 2007
    Location
    Illinois
    Posts
    4,567
    good question. how can you go by feel if you don't have a tourque wrench???
  13. #11
    La-illaha Il-lallah Hamzer11's Avatar
    Join Date
    Dec 2004
    Location
    Queens, NYC
    Posts
    2,034
    I don't know but I think torquing is important but not absolutely necessary in all parts. I have never seen a regular mechanic torque a valve cover or most any other minor part. Not that I think it shouldn't be done but the effects of not torquing are rarely detrimental on parts like valve covers.
    (¯`'·.¸НŻНS¸.·'´¯)
  14. #12
    G20 Newbie
    Join Date
    Nov 2007
    Location
    San Diego
    Posts
    23
    I'm glad I found this thread. I just bought a used '91 G20 and found oil in three of the spark plug tubes.
  15. #13
    G20 Member
    Join Date
    Sep 2005
    Location
    Oregon
    Posts
    361
    Quote Originally Posted by Turbo Diesel View Post
    Oh man ive been there! Replacing the gasket isn't really that hard
  16. #14
    G20 Guru AWOL_g's Avatar
    Join Date
    May 2003
    Location
    D_Town
    Posts
    1,134
    bringing it back from the dead...
    I'm doing my VC today and just wanted to touch on a couple things...
    I do need to remove the spark plugs right?
    There is no need to drain the oil right?
    RTV only goes on the cresent moon parts of the gasket? Bottom, top or both?
    Anything else important to remember aside from torque values and order of removal from bolts?
  17. #15
    G20 Newbie
    Join Date
    Jun 2005
    Posts
    usually when i change VC's if i don't have a torque wrench i usually tighten until i fell the first amount of resistance than tighten 1/4 turn after that.as for the oil change, i would change my oil just because you can never have too many oil changes.i only put it on the head cresent parts but make sure you don't use too much and have the extra crap end up under your VC and in spots you really don't want it to be.
  18. #16
    Join Date
    May 2003
    Location
    D_Town
    Posts
    1,134
    thanks
    Just changed the oil 150~miles ago so if there is no need to change it....
    also
  19. #17
    G20 Newbie
    Join Date
    Jun 2005
    Posts
    you can do both to be on the safe side but all you really need to do is put it on the head but like i said don't use too much.
  20. #18
    G20 Member VQ_Pwr'd's Avatar
    Join Date
    Jul 2007
    Location
    Exeter, CA
    Posts
    164
    You have to change the gaskets if there is oil on the top(thread/white part, none on tips) of the spark plugs right?
  21. #19
    Full-Time Chiller . . . . Black95G20's Avatar
    Join Date
    Sep 2002
    Location
    Southeast NH
    Posts
    6,285
    spark plugs stay in.
    Oil stays in.
    RTV around the whole thing for the best seal (just a little bit, with a little extra on teh crescents), that's what I always do.
    May 2008 MOTM
    Check out my T-Shirt company, funny/quality shirts: www.ratfinktshirts.com Code jesp414 saves you $3 per shirt.
  22. #20
    Join Date
    May 2003
    Location
    D_Town
    Posts
    1,134
    I pulled the plugs, wasted my time I guess..
    I only did rtv in the cresent moon parts, no leaks so far at least.....
    Tip: The washers on the VC will pop of and can easily be lost... Make sure to take them off after the nuts come of so you don't loose them
Posting Permissions
  • You may not post replies
  • You may not edit your posts
