Do I have a Roller Rocker Motor??? - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 66 of 66
Thread: Do I have a Roller Rocker Motor???
  1. #61
    'Luke' Loek's Avatar
    Join Date
    Oct 2002
    Location
    Venezuela
    Posts
    5,216
    Quote Originally Posted by Nismo1998cc View Post
    All these posts are quite confusing and doesnt look like some questions got answered.
    As far as a RR motor, why not just look for the oil filter.. if its near the strut tower it is NON RR.
    If oil filter is on the back of the block it IS A RR motor.
    Now for the Roller/Rocker arms. They have a rolling pin(Two part rocker arm with a rolling pin, vs. one part rocker on non RR motor) on them which results in smoother high RPM operation..IE: wont fly off and break from over revving.
    If any of you have ever broke a rocker arm from a misshift or over rev, you know what im talking about.
    As for the JDM valve cover on a US motor, im not sure, just line up the ports visually, see what lines up. and EGR block off plates can be made.
    Sorry for the thread revival, but wanted to clear some things up.
    Sorry, but NOT true. Mine is a 2000+ RR-motor, EUDM, and the oil filter is near the strut-tower. You will find that most EUDM RR-motors are like that....
    P11-144SW, VE, B15 LSD swap, DV9, SS/AS exhaust 2.5'-2.25'. AEM ATE B15-Rad B&A BC-Racing BF-Goodridge Bosch Brembo Bride-Brix-II Cusco D-1 DEI Dietz ES Fastbrakes Flexalite Greddy H&R Injen Innovate JWT Magnaflow NGK Nismo Nology Optima Progress Project-Kics Rays Sachs SCE Sparco SSAC Stillen Taylor Valvoline.
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #62
    G20 Newbie
    Join Date
    Aug 2003
    Location
    Silverdale, WA
    Posts
    41
    Quote Originally Posted by Loek View Post
    Ok, so the Euro motor is different, just like the suspension and whole bunch of other things.
    My post was in general for USDM motors.
  4. #63
    Join Date
    Oct 2002
    Location
    Venezuela
    Posts
    5,216
    I have done some extensive comparing between EUDM and USDM/CADM when I lived in Canada and had my Primera Wagon with me. Look carefully at the license-plate in my sig, pics were taken in Toronto. Difference is really not that much, engine-wise. Almost anything that fits the USDM /CADM-motor, also fits the EUDM and vv. My car proves it, almost every modded engine-part comes from the US (or Japan...).
  5. #64
    G20 Member thesaint's Avatar
    Join Date
    Mar 2007
    Location
    Barbados
    Posts
    271
    You cant post and say that your statement is for usdm only, fact is the title doesnt say that, next fact is my car was made in Japan and shipped to the Caribbean and sold in 2001 and it has a RR engine but my valve cover most definitely is designed like the non RR, i know its RR because i lifted the cover when i first got the car during my tune up.
    look at the engine pic on this page and u will see
    http://www.g20.net/forum/showthread.php?t=62243&page=2
    Did some work on my car today here are some pics
    the cover looks like a non RR by the descriptions given
    But as you can see it is RR
  6. #65
    G20 Newbie
    Join Date
    Jul 2012
    Location
    houston tx
    Posts
    13
    hi... can someone tell me where to find roller rocker arms? anyone looking for parts online? im planning to install higher lift roller rocker arms, I hope someone could help me. thanks!
  7. #66
    G20 Senior Member CovertRussian's Avatar
    Join Date
    Apr 2008
    Location
    VA
    Posts
    714
    Not sure if this has been covered, but noticed the first post has some misinformation.
    Some Side Notes: A non RR VC will not fit a RR motor, but you can fit a RR VC onto a non RR motor. Why you ask?
    Non-Roller Rocker VC will work on a roller rocker, you just need to use the black box (or something else). You cannot use an RR VC in a regular DE or VE. The RR VC baffles sit too low and will hit oil squirters on DE/VE. Now you can try to modify the RR VC (beat the baffles in) and then you might be able to use RR VC in a DE, but at that point just get a VE VC for your DE.
    Quote Originally Posted by oliverz View Post
    Start a new thread please. Also check for RR part outs.
    00 G20t KH3 - Loller Rocker + Disco Potato + 6 Speed
    01 B15 SE /PP - SR20DET
    04 Forester XT - Stock
Posting Permissions
  • You may not post replies
  • You may not edit your posts
