b14 ecu on 00 p11
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: b14 ecu on 00 p11
Hybrid View
    G20 Guru rooster's Avatar
    Apr 2002
    harrison nj
    1,049
    b14 ecu on 00 p11
    the gearing on 00-02p11 are too short especially 1st and 2nd,,,what do i need to change to a b14 ecu. would i lenthen the gearing with 225/45/17?
    300WHP "ROLLER ROCKER SR20'S ROCK"
    HASS TURBO KIT W/ GT2871R RUNNING @10PSI
    630cc injectors
    3" MANDEREL BENT MAGNAFLOW TURBO BACK
    LOW COMP WISEICO PISTONS
    jwt s3r cams
    unorthodox pulleys
    CLUTCHNET CLUTCH & 10LB FLYWHEEL
    EIBACH/KYB W/KONI BUMP STOPS
    OCTAT RSTB
    260WHP DYNO SHEET @ 8PSI W/STOCK EXHAUST
  2. #2
    stock rocks! Robj80's Avatar
    Feb 2004
    meriden, CT
    7,807
    I know on the 99 ecu there is a couple of wire you have to switch around. I don't know if it's the same for the 00+. I don't know much about gearing but I thought it was the gears in the transmission that determined the length and not the ecu. Unless you are talking about fuel cut off?
    I don't own a G20, but if I did, it would be a p11. Stay sexy my friends.
  3. #3
    Apr 2002
    harrison nj
    1,049
    the 00 have shorter gears than the 99's and it only revs to 6750, i was thinking of doing some jwt valve springs and changing to an earlier ecu set up because they don't make one for 00-02 p11. All i get is wheelspin in first and most of second gear, i figured i would get more than 55mph if i changed the rev limiter to about 7500
    630cc injectors
    jwt s3r cams
    unorthodox pulleys
    OCTAT RSTB
  4. #4
    G20 Guru Domiken's Avatar
    Apr 2002
    Queens-New York
    7,569
    ECU has nothing to do with gearing, its all in the tranny. If you change the ECU to the older one then yes you will be able to rev ro 7200RPM
  5. #5
    Feb 2004
    meriden, CT
    7,807
    Another option is the new e-manage ultimate. That is suppose to let you set your own rev limit. It will keep the injectors flowing even past the factory limit.
    http://www.greddy.com/prod_e_manage_ult.htm
  6. #6
    G20 Guru Ericdd's Avatar
    Mar 2002
    Long Island, NY
    7,715
    you can't put a b14 ECU in a 00-01 G20 any way, not without switching half the damn car.
    Sorry, I don't do custom work anymore, PLEASE don't ask
  7. #7
    Apr 2002
    Queens-New York
    7,569
    Quote Originally Posted by Ericdd
    Actually you can, all you need is the intake manifold, harness (which is literaly attached to it), and ECU. Im going E-manage but if it doesnt work, I already have a whole thing waiting for me after someone else that I know down here goes VVL.
  8. #8
    Apr 2002
    harrison nj
    1,049
    isn't it mainly the b14 manifold an wiring harness. i also meant a higher redline would mean slightly more speed in each gear.....no?
    630cc injectors
    jwt s3r cams
    unorthodox pulleys
    OCTAT RSTB
  9. #9
    Apr 2002
    Queens-New York
    7,569
    Quote Originally Posted by rooster
    A higher redline would mean you can take that powerband a little further and yes pick up a couple of more MPH. See thats great for me and my turbo because its big anything past 4500RPM and its ridiculously quick and hard to shift. I say stick with it let the LSD do its job.
    You know whats funny, the non USDM roller rocker motors like the one in my car rev up to 7400RPM STOCK!! I dont know why in the US they didnt.
  10. #10
    G20 Guru Koojo's Avatar
    Mar 2002
    WV
    7,765
    Hmm I wonder if the US engines last longer on average since we can't beat on our engines till 7200+rpms, but only 6750. I have a T25 turbo, so higher gearing won't really help me too too much
    I just looked up emanage ultimate....and it said somethign about automatic transmission shift control...INTERESTING !
  11. #11
    G20 Newbie pavoolon's Avatar
    Oct 2005
    Poland
    10
    Can anyone tell me what is the safe redline for a roller rocker engine? My P11 also revs to 6750 an its not high enough because of new cams. I was thinking of replacing the ecu from the P11 GT (redline: 7100) but I'm not sure if I can do it without changing the stock valve springs
  12. #12
    Apr 2002
    harrison nj
    1,049
    i'm curious on the answer to this also
    630cc injectors
    jwt s3r cams
    unorthodox pulleys
    OCTAT RSTB
  13. #13
    Apr 2002
    Queens-New York
    7,569
    You have to upgrade to Jim Wolf valve springs to rev all the way up to 7500RPM
    http://www.jimwolftechnology.com/cus...asp?PartID=455
    Quote Originally Posted by Koojo
    Our engines were not made to be high revvers, the concentration was on higher torque and more hp (5 anyway) for better driveability at a lower redline. Thats why the new MR20DE makes 145hp and 144lbs of torque (around there) at only 2.5k RPMS the non USDM roller motors have a smaller throttle body but a nicer intake manifold (IMO) with no EGR (except the 10:1 roller rocker found in P11GT's).
    Im sure they last exactly the same if well taken care of.
  14. #14
    G20 Guru NismoPC's Avatar
    Mar 2002
    Mansfield, OH
    2,120
    Quote Originally Posted by Domiken
    I think you've got aboyt 10hp too much listed there. Nissan released the est. specs for the new Sentra MR20DE.
  15. #15
    Apr 2002
    Queens-New York
    7,569
    Quote Originally Posted by NismoPC
    Whoops. Im sure it will feel PEPPY making that power at that RPM, if you think about it how many times do yall redline your car each day. Not much. CVT trannies are great for daily drivers too.
  16. #16
    Apr 2002
    harrison nj
    1,049
    due the jdm rr motors have beefier valve springs?
    630cc injectors
    jwt s3r cams
    unorthodox pulleys
    OCTAT RSTB
  17. #17
    Apr 2002
    Queens-New York
    7,569
    To tell you the truth I dont know, but if they do I have them. I checked on this motor with some of the guys overseas and they say they rev up to 7400RPM without a problem, so im sure they must be a little beefier.
  18. #18
    Oct 2005
    Poland
    10
    thanx for the info. now I know that 7500 rpm needs another valve springs, but If rev limiter will be set at 7100 or 7200 rpm, will they be also necessary? I'm asking because I would like not to change the stock springs and make the rev limiter a bit higher than it is now (6750 or 6800)
  19. #19
    Apr 2002
    harrison nj
    1,049
    but your car still is limited at 6800? or did you change the ecu?
    630cc injectors
    jwt s3r cams
    unorthodox pulleys
    OCTAT RSTB
  20. #20
    Apr 2002
    harrison nj
    1,049
    i have the same problem you have , if you look at the dyno graph in my sig you'll notice that whp doesn't really drop off but when i shift to the next gear is drops off way to much , i want to go a bit higher in the rev range so that when the needle drops during the next sshift i'll still be in the fat part of the powerband
    630cc injectors
    jwt s3r cams
    unorthodox pulleys
    OCTAT RSTB
