Infiniti Check Engine Codes
Page 1 of 4 1234 LastLast
Results 1 to 20 of 65
Thread: Infiniti Check Engine Codes
  1. #1
    G20 Junior Member baco99's Avatar
    Join Date
    Aug 2002
    Location
    Boston, MA, USA
    Posts
    91
    Can someone make this a sticky?
    http://www.troublecodes.net/infiniti/
    Infiniti
    Without OBD II
    On G20 models, the ECU is located behind the center console. On J30, M30 and Q45 models, the ECU is located behind the RH kick panel.
    If a malfunction occurs within the ECU/fuel injection system, a diagnostic trouble code may be stored in the ECU and the ‘‘Check Engine’’ lamp will blink. There is also a lamp built into the ECU which will concurrently blink. To read Code output, proceed as follows:
    1. Turn ignition On, but do not start engine.
    2. Using a small screwdriver, turn diagnostic mode selector switch, located on side of ECU, fully clockwise.
    3. Wait two seconds, then rotate switch to full counterclockwise position.
    4. A malfunction code can be read as the long (0.6 second) blink, indicating the first digit of a two digit number and the short (0.3 second) blink, indicating the second digit.
    Ensure that the diagnostic switch is to the full counterclockwise position whenever the vehicle is in use.
    w/OBD II
    On G20 and I30 models, connect a suitable Scan Tool to the DLC, located under instrument panel fuse box cover.
    On J30, Q45 and QX4 models, connect a suitable Scan Tool to the DLC, located under or on lower portion of instrument panel.
    Clearing Codes
    If using a scan tool, follow tool manufacturer’s instructions to clear Codes.
    A second, though more time consuming method of clearing Codes involves using a small screwdriver to turn the diagnostic mode selector switch, located on the side of the ECM/ECU, fully clockwise. After waiting two seconds, rotate the switch to the full counterclockwise position. The diagnosis will end and memory will then be cleared.
    Check Engine Lamp
    11
    Crank Angle Sensor
    12
    Mass Air Flow Sensor
    13
    ECT Sensor
    14
    Vehicle Speed Sensor
    16
    TCS Signal
    21
    Ignition Signal Circuit
    25
    Idle Air Control Valve
    22
    Fuel Pump Control
    31
    ECM
    32
    EGR Function
    33
    Heated Oxygen Sensor
    34
    Knock Sensor
    35
    EGR Temperature Sensor (RH)
    41
    Intake Air Temperature Sensor
    42
    Fuel Pump Sensor
    43
    Throttle Position Sensor
    45
    Injector Leak
    46
    Secondary Throttle Sensor
    51
    Injector Analysis
    53
    EGR Temperature Sensor (LH)
    54
    Signal Circuit From A/T Control Unit To ECM
    65-71
    Single Cylinder Or Multiple Cylinder Misfire
    72
    Three Way catalyst Function
    76
    Fuel Injection System Function
    77
    Rear Heated Oxygen Sensor
    82
    Crankshaft Position Sensor
    84
    A/T Diagnosis Communication Line
    91
    Front Heated Oxygen Sensor Heater
    103
    Park/Neutral Position Switch
    105
    EGR & Canister Control Solenoid
    OBD2 Codes
    P0000
    No Self Diagnostic Failure Indicated
    P0100
    MAF Sensor
    P0105
    Absolute Pressure Sensor
    P0110
    IAT Sensor
    P0115
    ECT Sensor
    P0120
    TP Sensor
    P0125
    ECT Sensor
    P0130
    Closed Loop, Bank 1 Or Front O2S, Bank 1
    P0131
    Front O2 Sensor, Bank 1 Lean Shift Monitoring
    P0132
    Front O2 Sensor, Bank 1 Rich Shift Monitoring
    P0133
    Front O2 Sensor, Bank 1 Response Monitoring
    P0134
    Front O2 Sensor, Bank 1 High Voltage
    P0135
    Front HO2S Heater, Bank 1
    P0136
    Rear O2S, Bank 1
    P0137
    Rear O2S, Bank 1 Minimum Voltage Monitoring
    P0138
    Rear O2S, Bank 1 Maximum Voltage Monitoring
    P0139
    Rear O2S, Bank 1 Response Monitoring
    P0140
    Rear O2S, Bank 1 High Voltage
    P0141
    Rear H02S Heater, Bank 1
    P0150
    Closed Loop, Bank 2 Or Front O2S, Bank 2
    P0151
    Front O2 Sensor, Bank 2 Lean Shift Monitoring
    P0152
    Front O2 Sensor, Bank 2 Rich Shift Monitoring
    P0153
    Front O2 Sensor, Bank 2 Response Monitoring
    P0154
    Front O2 Sensor, Bank 2 High Voltage
    P0155
    Front HO2S Heater, Bank 2
    P0156
    Rear H02S Sensor, LH Bank
    P0157–P0160
    Rear O2S, Bank 2
    P0161
    Rear H02S Heater, LH Bank Or Bank 2
    P0171
    Fuel System Lean, Bank 1
    P0172
    Fuel System Rich, Bank 1
    P0174
    Fuel System Lean, Bank 2
    P0175
    Fuel System Rich, Bank 2
    P0180
    Tank Fuel Temp Sensor
    P0300
    Random Misfire
    P0301–P0308
    Misfire, Cylinder No. 1–8
    P0325
    Knock Sensor, Bank 1
    P0330
    Knock Sensor, Bank 2
    P0335
    CKP Sensor (Pos)
    P0340
    CMP
    P0400
    EGR System
    P0402
    EGRC/BPT Valve
    P0403
    EGR Volume Control Valve Circuit
    P0420
    TW Catalyst System, Bank 1
    P0430
    TW Catalyst System, Bank 2
    P0440
    EVAP Small Leak
    P0443
    Purge Control/V & S/V
    P0446
    Vent Control Valve
    P0450
    EVAP Pressure Sensor
    P0500
    P0505
    IACV/AAC Valve
    P0510
    Closed TP Sensor
    P0600
    A/T Comm Line
    P0605
    ECM/ECU
    P0705
    PNP Or Inhibitor Switch
    P0710
    ATF Temp Sensor
    P0720
    VSS A/T
    P0725
    Engine Speed Signal
    P0731
    A/T 1ST Signal
    P0732
    A/T 2ND Signal
    P0733
    A/T 3RD Signal
    P0734
    A/T 4TH Signal Or TCC
    P0740
    TCC SV Solenoid
    P0744
    A/T TCC Signal
    P0745
    Line Pressure S/V
    P0750
    Shift Solenoid/V A
    P0755
    Shift Solenoid/V B
    P1105
    MAP/BARO Switch SOL/V
    P1110
    Intake Valve Timing Control, LH Bank
    P1120
    TP Sensor 2
    P1125
    Tandem TP Sensor
    P1130
    Swirl Control Valve Control Solenoid Valve
    P1135
    Intake Valve Timing Control, RH Bank 2
    P1140
    Intake Valve Timing Control Position Sensor, LH Bank 1
    P1145
    Intake Valve Timing Control Position Sensor, RH Bank 2
    P1148
    Closed Loop, Bank 1
    P1165
    Swirl Control Valve Control Vacuum Check Switch
    P1168
    Closed Loop, Bank 2
    P1210
    Traction Control Signal Circuit
    P1220
    FPCM
    P1320
    Ignition Signal, Primary
    P1335
    CKP Sensor (Ref)
    P1336
    CKP Sensor (POS) Cog
    P1400
    EGRC Solenoid/V
    P1401
    EGR Temp Sensor
    P1402
    EGR System
    P1440
    EVAP Small Leak
    P1441
    VC/V Bypass/V
    P1443
    Canister Control Vacuum Check Switch
    P1444
    Purge Volume Control/V
    P1445
    P1446
    Vent Control Valve
    P1447
    EVAP Purge Flow
    P1448
    Vent Control Valve
    P1490
    VC/V Bypass/V
    P1491
    VC Cut/V Bypass/V
    P1492
    Purge Control/V S/V
    P1493
    P1605
    A/T Diag Comm Line
    P1705
    TP Sensor A/T
    P1706
    PNP Switch
    P1760
    Overrun Clutch S/V
    P1900
    Cooling Fan
    96 & newer vehicles are OBD2 systems
    and REQUIRE A SCANNER, unless otherwise stated.
    Warning: Please check for manufacturer specific codes and
    confirm the trouble code descriptions with an appropriate manual.
    Disclaimer: We cannot guarantee the accuracy of all trouble codes.
    We try and make them as accurate as we can, but sometimes we all make mistakes.
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Senior Member
    Join Date
    Jan 2006
    Location
    Bolingbrook, IL
    Posts
    938
    Should be sticky, was exactly what I was looking for, this site rocks. Thanks
    -tony
  4. #3
    G20 Member
    Join Date
    Nov 2005
    Location
    New York
    Posts
    455
    Hey, i have the lovely OBDI. Do you havet he codes for that? Can the car be run while NOT in diagnostic modes? Can i retrive codes without the diagonstics on?
    +1 on the sticky
  5. Remove Advertisements
    G20.net
    Advertisements
  6. #4
    G20.net Staff
    Super Moderator
    markbuts3's Avatar
    Join Date
    Jan 2004
    Location
    Derbyshire, UK
    Posts
    11,585
    No need for the sticky really as just knowing the codes means nothing without knowing how to find out the cause.
    www.phatg20.net
    OBD-I codes are the two digit ones at the top...
    They have been posted on here before. http://www.g20.net/forum/showthread....&threadid=3423
    And some I found ages ago... http://www.g20.net/forum/showpost.ph...05&postcount=4
    Just call me Mark
    My Site
  7. #5
    G20 Member
    Join Date
    Nov 2005
    Location
    New York
    Posts
    455
    thanks mark! but can i do diagnostis readings on teh car whiel driving like OBDII or no?
  8. #6
    G20.net Staff
    Super Moderator
    markbuts3's Avatar
    Join Date
    Jan 2004
    Location
    Derbyshire, UK
    Posts
    11,585
    Quote Originally Posted by GenesisFactor
    Look for consult interface systems.
    http://www.g20.net/forum/showthread.php?t=23444
    And there is the self contained one at the sr20forum store.... http://store.sr20forum.com/forum/ind...8fd7485c524f4f that can be used on it's own for certian stuff or connected to a computer and use the same software as in my thread...
    Just call me Mark
    My Site
  9. #7
    'Luke' Loek's Avatar
    Join Date
    Oct 2002
    Location
    Ankara, Turkey
    Posts
    5,319
    It would be good if also the codes for the Euro-cars would have been included
    There is a whole bunch of codes for CVT-equipped cars for instance. Not all cars on this forum are US-versions. I will try to post some codes as soon as i can.
    I'm right in the middel of that....
    STORED: WP11-144: VE, B15 LSD swap, DV9, SS/AS exhaust 2.5'-2.25'. AEM ATE B15-Rad B&A BC-Racing BF-Goodridge Bosch Brembo Bride-Brix-II Cusco D-1 DEI Dietz ES Fastbrakes Flexalite Greddy H&R Injen Innovate JWT Magnaflow NGK Nismo Nology Optima Progress Project-Kics Rays Sachs SCE Sparco SSAC Stillen Taylor Valvoline. DD: Hyundai Santa Fe 2001 AT 4WD V6 2700 cc.
  10. #8
    G20.net Staff
    Super Moderator
    markbuts3's Avatar
    Join Date
    Jan 2004
    Location
    Derbyshire, UK
    Posts
    11,585
    Same thing though Luke....someone only has to go to phatg20 for a FSM
    Just call me Mark
    My Site
  11. #9
    G20 Member Slm b rad's Avatar
    Join Date
    Feb 2004
    Location
    Ky
    Posts
    248
    Sorry i know kinda old thread but the whole 96 and newer is not true....my car is OBD-II and its a 95.....just a litte tidbit for some of you guys...
  12. #10
    G20.net Staff
    Super Moderator
    markbuts3's Avatar
    Join Date
    Jan 2004
    Location
    Derbyshire, UK
    Posts
    11,585
    1994 onwards G20s are OBD-II.
    Primeras didn't go to OBD-II until 1999
    Just call me Mark
    My Site
  13. #11
    *Im Being Moderated* blackp10g20's Avatar
    Join Date
    Jan 2003
    Location
    Columbus, Ohio
    Posts
    963
    thank god someone posted this
  14. #12
    G20 Guru brammes's Avatar
    Join Date
    Oct 2006
    Location
    masshole
    Posts
    1,235
    soooo i wouldnt be able to use that consult on my 94 correct?
  15. #13
    G20.net Staff
    Super Moderator
    markbuts3's Avatar
    Join Date
    Jan 2004
    Location
    Derbyshire, UK
    Posts
    11,585
    Yes you would... check posts #34 and #69 of my thread about the consult interface.
    Just call me Mark
    My Site
  16. #14
    G20 Newbie kujio's Avatar
    Join Date
    May 2007
    Location
    Tempe, AZ
    Posts
    21
    I am getting error code P1320 which according to this post is FPCM.
    Anyone know what FPCM is, and what I have to do to fix this problem?
  17. #15
    AzG20P11's Avatar
    Join Date
    Jul 2004
    Location
    Tucson, Az
    Posts
    3,947
    Quote Originally Posted by kujio View Post
    Its "ignition signal, primary", your looking at the one above it.
    P1320:
    Malfunction is detected when:
    The ignition signal in the primary circuit is not entered during engine cranking or running.
    Items to check:
    Harness or connectors (the ignition primary circuit is open or shorted).
    Power transistor unit
    Resistor
    Cam position sensor
    Cam position circuit
  18. #16
    G20 Guru merlin's Avatar
    Join Date
    Sep 2005
    Location
    around
    Posts
    2,881
    /\/\ beat me to it
  19. #17
    Join Date
    May 2007
    Location
    Tempe, AZ
    Posts
    21
    sweet thanks for the help...I have an appointment at the dealership tomorrow...unfortunately the car wont pass emissions with the error code
    Hopefully they wont try to rape me or else ill have to try to fix it myself.
  20. #18
    G20 Newbie
    Join Date
    Jul 2009
    Location
    Utah
    Posts
    14
    I have a '95 and it has the check engine light on. I need to find out how to read the codes. I am NOT going to pay to have the codes read when I can get it done myself. I have pulled the kick panels off on both sides, I am seeing a socket in the fuse panel access. Again this is a '95 G20 with a manual transmission. I have looked under the dash and felt around behind the centre console. There is no screw. Any advice will be greatly appreciated.
  21. #19
    G20 Newbie
    Join Date
    Sep 2009
    Location
    san diego
    Posts
    Thanks this info prob just saved me I dont know how much money. What other options than the stealership can I buy a legit ecm/ecu?
  22. #20
    G20 Guru XnotedgeanymoreX's Avatar
    Join Date
    Sep 2006
    Location
    Pensacola. FL
    Posts
    1,469
    Quote Originally Posted by blackxx95xxg20xx View Post
    Get a used one from the for sale section here, maybe a partout. Or the other SR20 forums.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
