Auto Transmission Problem
Results 1 to 3 of 3
Thread: Auto Transmission Problem
  1. #1
    G20 Newbie
    Join Date
    Jan 2004
    Location
    Pa. USA
    Posts
    6
    I would appreciate any help. My 99 P-11 with 122k had a check engine light come on. It started to shift hard sometimes and feels like something is holding it back on power.It is an automatic and a 732 code showed up on scope.Any ideas?
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20.net Staff
    Super Moderator
    markbuts3's Avatar
    Join Date
    Jan 2004
    Location
    Derbyshire, UK
    Posts
    11,586
    I don't know if you have seen the FSM for this...
    **This is an OBD-II self-diagnostic item and not available in TCM
    self-diagnosis.
    **This malfunction will not be detected while the O/D OFF indicator
    lamp is indicating another self-diagnosis malfunction.
    **This malfunction is detected when the A/T does not shift into
    second gear position as instructed by the TCM. This is not
    caused by electrical malfunction (circuits open or shorted) but
    by mechanical malfunction such as control valve sticking,
    improper solenoid valve operation, etc.
    Malfunction is detected when ... A/T cannot be shifted to the 2nd gear position even if electrical circuit is good.
    Check items (Possible cause)
    **Shift solenoid valve B
    **Each clutch
    **Hydraulic control circuit
    Gear position supposed by TCM................................ ..............2
    In case of gear position with no malfunctions....................... .....2
    In case of gear position with shift solenoid valve B stuck open.....3
    Just call me Mark
    My Site
  4. #3
    G20 Member
    Join Date
    Jun 2007
    Location
    Ma
    Posts
    233
    I just got the same code. How did you solve the problem?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
