Why do i hear my Rpm's in my radio
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Why do i hear my Rpm's in my radio
  1. #1
    G20 Senior Member p10socal's Avatar
    Join Date
    Apr 2002
    Location
    San Diego
    Posts
    581
    I think the old p10 is having electrical problems. I could hear my rpm's through the radio at minimum volume. as the rpm's get higher the noise gets louder also...what is the cure for this?
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Member InfinitiTuned's Avatar
    Join Date
    Aug 2005
    Location
    Indianapolis
    Posts
    333
    its an electrical problem, mine did it w/ the stock HU...so i bought a new (AEM) one, problem solved.
  4. #3
    G20 Senior Member UncleShasta's Avatar
    Join Date
    Jul 2005
    Location
    Peoria, IL
    Posts
    546
    does it sound like an electrical whine? i have the same problem, but it's intermittent. and i've got an aftermarket HU...
  5. #4
    ʎןןnɟ˙˙ǝdoɹƃ Alex's Avatar
    Join Date
    May 2002
    Location
    Columbus, OH
    Posts
    2,773
    Bad ground? I get it when I switch to AM on frequencies w/ lots of static
  6. #5
    Questioning Answers ENO's Avatar
    Join Date
    Jan 2006
    Location
    Not Philly area.
    Posts
    6,273
    Quote Originally Posted by p10socal
    Quote Originally Posted by UncleShasta
    if aftermarket is playing a role in this, the nosie u are hearing is normally from having...say the RCA & the amp power line close together, OR you have interference on one of the wires....your radio will pick up almost any good frequency, ex. when cell phone is about to ring you here the ....buzzzz. buzz. buzz
    Quote Originally Posted by Nikola Tesla
    I do not think there is any thrill that can go through the human heart like that felt by the inventor as he sees some creation of the brain unfolding to success... such emotions make a man forget food, sleep, friends, love, everything
  7. #6
    Prince of Joy MrFancypants's Avatar
    Join Date
    Dec 2002
    Location
    Tucson, AZ
    Posts
    4,614
    It's because theres a ground difference between your amp and your head unit. Should be fun to fix
    - Greg -
  8. #7
    G20 Senior Member satanshollow's Avatar
    Join Date
    Feb 2005
    Location
    Langley, BC
    Posts
    906
    i get the same thing. the amp gets power right from the battery, and the h/u gets it from the normal wiring (i believe).
    what about those ground filters you can get from Radio Shack? Would that work?
  9. #8
    AzG20P11's Avatar
    Join Date
    Jul 2004
    Location
    Tucson, Az
    Posts
    3,946
    my friends sentra does this on a few am stations w/ the throttle. we turn it up loud, and it sounds like a v dub. lol
  10. #9
    G20 Senior Member odin's Avatar
    Join Date
    May 2004
    Location
    Nieuweschans NL
    Posts
    701
    That could help, but not neccesary. It is usually a ground issue that needs to be solved. It is best to try and reground hu and amp.
  11. #10
    V3.0 VE-T Mautai916's Avatar
    Join Date
    Oct 2004
    Location
    Sacramento, CA
    Posts
    3,170
    Quote Originally Posted by odin
    +1
    Sounds like a grounding issue to me too. Reground everything and you should be ok. And if you need a grounding kit, check my sig, im doing a GB on them.
  12. #11
    Join Date
    Apr 2002
    Location
    San Diego
    Posts
    581
    Aww crap seems to me that I see a lot of potential problems that were mentioned..
    1. My ground terminal is loose ie. after you nut and you start to deflate and condom starts slipping off. ----so i put zip ties to hold down the ground wire connecting to the battery.
    2. I disconnected my amp and woofer so my wires are just dangaling in the trunk.
    If this wont work out im going to get Mautai916 ground kit
  13. #12
    G20 Senior Member foreverzero89's Avatar
    Join Date
    Mar 2005
    Location
    Bedford,Texas
    Posts
    653
    that is one possability, but most likly it's a weak battery. see the battery "fliters" out most of the elcetrical junk, but as the batt gets older the stuff(not sure what its called) comes off the plates in the batt and some of the junk comes through.
    what you are hearing is the alternator.
  14. #13
    G20 Senior Member Mr.Snuggles's Avatar
    Join Date
    Dec 2004
    Location
    Chino Valley, AZ
    Posts
    694
    make sure your amp wire isn't real close to your plug wires, or distributor...if its not, then you got a bad ground...somewhere!
    --lifes a beach, I'm just playin in the sand
    Had 96 DL0 5mt (modded and gone)
    Now 02 KR4 5port
  15. #14
    G20 Guru Kazmi's Avatar
    Join Date
    Apr 2004
    Location
    37.17 79.57
    Posts
    1,707
    I actually have been having the same issues...whenever my radio is on and I have my cell phone holder plugged into the charger, I hear a slight "whine"...it's only at the lower rpms though and it goes away after that.....my holder has a speaker too and it makes awful noise when connected to the cig ligher slot.....my battery is fairly new........I wonder if I should just reground it.....
  16. #15
    Join Date
    Apr 2002
    Location
    San Diego
    Posts
    581
    my problem is fixed I disconnected my wire to the amp from the positive terminal..
  17. #16
    Join Date
    Jul 2005
    Location
    Peoria, IL
    Posts
    546
    grounding issue eh? i guess when i get mautai's grounding kit i'll reground everything, see if that works
  18. #17
    Join Date
    Feb 2005
    Location
    Langley, BC
    Posts
    906
    I redid the ground on my head unit. I have a Sony unit and it was spliced into the factory wiring. I snipped that ground, then grounded it right to the metal beside the radio, where the 4 screws hold the radio in. Still have the same problem.
    Doesn't matter what I play, AM, FM or the CD Changer i still get the whine.
    Like I said before, the amp (in the trunk) gets the power right from the battery. The radio power from the stock wiring. The amp has a big black ground cable, but where its ground I don't know. It goes to the drivers side up over the rear suspension tower someplace. Is there a good ground in the trunk someplace that I can add another ground?
    As far as I can tell, the RCA cables from the h/U goes down the passenger side to the trunk, to the amp.
  19. #18
    Join Date
    Jul 2005
    Location
    Peoria, IL
    Posts
    546
    i've still got the same problem too, but my alternator is going bad on me. i'll update as soon as i install a new one.
  20. #19
    G20 Newbie
    Join Date
    Jun 2006
    Location
    Massapequa, NY
    Posts
    25
    its the ground
  21. #20
    Join Date
    Feb 2005
    Location
    Langley, BC
    Posts
    906
    Oh i noticed there is a big ground in the trunk, underneath the carpet! Can I connect the ground to this? Then the ground from the amp will be less than 2'.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
