G20 Member
check engine light on after finish install Short Ram Intake
omg.. my car check engine light on after i finished install the Short Ram intake....
what's can i do now pleasee help me!!...
G20 Guru
did u place the air intake temperature sensor in the vacinity of your intake? if u dont do this ur CEL will come on and stay on. (this is the smaller sensor that you had to unplug when installing ur intake)
G20 Member
is it the sensor that stuck on the MAF???if it's is i already screw it's in the maf... i saw this 1 small connecter that i took it off from the bottom of AIRBOX and now i don't know where can i plug it back too...
After finishing installed SHORT RAM INTAKE>.. it made my Car won't work as BELOW
1.Check engine light On.
2.Overdrive button sometime work,, sometime don't
3.gas meter stay the same FULL...?????
WHERE IS CHECk ENGINE FUSE LOCATED AT????? I CAN'T FIND IT
hELP Me ! pleaseeee
G20 Member
check to make sure you reconnected you sensors!
G20 Member
yeah.. everytime seem fine to me.. the new SHORT RAM INTAKE work perfect.. it's way faster than the old 1... but my huge problem is .. the CHECK ENGINE LIHGHT On and i can't find the FUSE BOX for it?? do you know where the fuse box located at???
second problem is my OVER DRIVE BUTTON ON/OFF doesn't work.. it likes INTERMITTEN .. sometime work , sometime don't???? why??? what's can cause these problems ??? all i do just replace the INTAKE??
G20 Guru
for the check engine use this http://www.troublecodes.net/infiniti/ your car isn't OBD II so follow the first part of the instructions. make sure your MAF and air temp sensor is plugged. if you dont know where to put the air temp sensor just tape it to the the Filter. thats how i have mine. and no problems. but you can always make a hole in the pipe and install the air temp sensor correctly. hope this helps. sorry i dont know anything about the overdrive.
G20.net Staff
Super Moderator
A 1995 P10 is OBD-II. The reading and resetting of codes has been covered on here plenty of times...
http://www.g20.net/forum/showthread.php?t=1992
You said you unplugged a connector off the bottom of the airbox and don't know where to plug it in. Is that still unplugged ?? Sounds like the IAT sensor, just remove it from the airbox and plug it in then cabletie it in the same vicinity of the filter...
G20 Member
do u guy know where is the CHECK ENGINE FUSE at?? i couldn't find it!!
talking about the Air Temp sensor... i put it's inside the intake PIPE.. made a hole and screw it's in.. but doesn't help.. the ENGINE CHECK LIGHT STILL ON!!!...
G20.net Staff
Super Moderator
What do you want the fuse for ?? Read the thread I posted a link to for a how-to on resetting the codes.
G20 Member
i couldn't find the ECU.. is it in the middle under the dash??? under the HU??? .. will it mess up my car if i did something wrong with the ECU?
G20 Member
Calm down man, you're fine. It's pretty normal for a CEL to come on when you put on intake/exhaust parts. The ECU is under the center console, on the inside of the car near the firewall. There is a small kick panel on the passnger side of the very front of the center console with one screw holding it on. Take that off, and you'll see the ECU behind it. Now follow these steps:
1. Turn your key to on (do not turn the car on, just to the on position)
2. There is a small screw under a piece of tape on the ECU. Use a flathead screwdriver and turn it clockwise until it stops.
3. Wait 2-5 seconds.
4. Turn the scew counterclockwise until it stops.
5. The check engine light will now flash and tell you what codes you have. It will have a series of long flashes followed by a series of short flashes. If you have 3 long flashes and 3 short flashes, the code would be 33, or 0303 (same thing).
6. Now repeat the process of turning the screw clockwise then counterclockwise, and the codes will be reset. If they don't come on again, you're fine.
G20.net Staff
Super Moderator
Stick your head in the passenger footwell then look to the left, that very back section of plastic trim comes off to reveal the ECU.
http://www.g20.net/forum/showpost.ph...14&postcount=4
G20 Member
ok i did what u guy told me.. i reset the ECU and it's the light DOES FLASH... now my car won't start??? lol??? omg my dad going to kick my ass
G20 Member
here what i did...
i turn the screw to clockwise and wait 2-5 seconds and turn it back to counterclockwise...
than i look at my engine light.. it's flashed
than i do the samething.. 1 more time turn the screw to clockwise and wiat 2 - 5 seconds than turn it back to counterclockwise.. and now my car not starting up???
G20.net Staff
Super Moderator
Sounds like you did the correct procedure. Is the screw now in the same position as when you started ??
Our UK ECUs don't have the screw and we have to short a couple of wires in the consult port to get the codes....So I've never had to turn a screw for codes. Plenty of guys on here have though.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
