broke retainers on nx!
Results 1 to 19 of 19
Thread: broke retainers on nx!
  1. #1
    G20 Guru rooster's Avatar
    Join Date
    Apr 2002
    Location
    harrison nj
    Posts
    1,049
    where can i get new retainers cheap, missed a gear overrevved and crack,,ouch
    another question, one of the lobes on the stock cams got damaged , it's the cam in back if your facing the motor from the front of the car. Is that the intake or exhaust cam.
    300WHP "ROLLER ROCKER SR20'S ROCK"
    HASS TURBO KIT W/ GT2871R RUNNING @10PSI
    630cc injectors
    3" MANDEREL BENT MAGNAFLOW TURBO BACK
    LOW COMP WISEICO PISTONS
    jwt s3r cams
    unorthodox pulleys
    CLUTCHNET CLUTCH & 10LB FLYWHEEL
    EIBACH/KYB W/KONI BUMP STOPS
    OCTAT RSTB
    260WHP DYNO SHEET @ 8PSI W/STOCK EXHAUST
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    #1 cop hater randyo156's Avatar
    Join Date
    Feb 2004
    Location
    BUFFALO, ny
    Posts
    5,318
    if you dont mind
    how high did you rev?
    Randy
  4. #3
    Join Date
    Apr 2002
    Location
    harrison nj
    Posts
    1,049
    well let's see, for some reason the nx does not have a rev limiter so when i shifted from second to thrird close to redline i missed and it shot past 8k
    630cc injectors
    jwt s3r cams
    unorthodox pulleys
    OCTAT RSTB
  5. #4
    G20 Guru MikeG's Avatar
    Join Date
    Mar 2003
    Location
    nh
    Posts
    1,616
    The nx dose have a rev limiter. If you over rev the motor it will rev as high as it's forced to . You must have shifted into 2nd from the top of third? I did the same thing in my first sr20 powered car. I bent three valves and shattered all but one rocker arm. It was a sad sight. I ended up swapping out the motor with a DET then I tore the old one apart to check out the damage.
    Mike
    Quote Originally Posted by rooster
  6. #5
    Join Date
    Feb 2004
    Location
    BUFFALO, ny
    Posts
    5,318
    haha
    my brother did that once
    in his first g
    he got it up over 9k
    he got lucky tho
    ntn broke
    the highest ever got mine was bout 7800 rpms
    was not by accident tho
  7. #6
    G20 Newbie
    Join Date
    Apr 2006
    Location
    VABEach
    Posts
    19
    so P10s done have a rev limiter?
  8. #7
    Join Date
    Feb 2004
    Location
    BUFFALO, ny
    Posts
    5,318
    Quote Originally Posted by Al_s14
    i am pretty sure they do
    i think its 7750 for 5 spd p10s
  9. #8
    Join Date
    Apr 2002
    Location
    harrison nj
    Posts
    1,049
    Quote Originally Posted by Mike Gosselin
    Mike
    no, i went to shift into 3rd rather quickly and missed and nailed the gas quickly before it was in. that's when it just stopped
    630cc injectors
    jwt s3r cams
    unorthodox pulleys
    OCTAT RSTB
  10. #9
    Join Date
    Feb 2004
    Location
    BUFFALO, ny
    Posts
    5,318
    i thing the one near the firewall is the intake cam
    i am guessing
    logic - closer to intake mani
    Hopefully someone will tell you for sure
  11. #10
    G20.net Staff
    Super Moderator
    markbuts3's Avatar
    Join Date
    Jan 2004
    Location
    Derbyshire, UK
    Posts
    11,586
    The rev limit is 7500, but the dash tacho is inaccurate....
    Rear cam is intake....
    Just call me Mark
    My Site
  12. #11
    Join Date
    Feb 2004
    Location
    BUFFALO, ny
    Posts
    5,318
    Quote Originally Posted by markbuts3
    on nxs?
  13. #12
    Boosted & Stanced akuma810's Avatar
    Join Date
    Mar 2002
    Location
    San Francisco
    Posts
    3,111
    correct, intake cam
    -Norm
    Need to rent a SR20 torque plate? PM me.
  14. #13
    G20.net Staff
    Super Moderator
    markbuts3's Avatar
    Join Date
    Jan 2004
    Location
    Derbyshire, UK
    Posts
    11,586
    I was supposed to be quoting your post Randy...
    but forgot to tick the 'Quote message in reply?' box....
    Just call me Mark
    My Site
  15. #14
    Join Date
    Feb 2004
    Location
    BUFFALO, ny
    Posts
    5,318
    maybe uk p10s are different
    i know my car
    and other p10.5s ive driven redline at 7.5
    limit at 7750
    Lmk please
  16. #15
    G20.net Staff
    Super Moderator
    markbuts3's Avatar
    Join Date
    Jan 2004
    Location
    Derbyshire, UK
    Posts
    11,586
    Quote Originally Posted by randyo156
    i know my car
    limit at 7750
    Lmk please
    Yea I thought mine revved higher until I used consult on the laptop and saw the max reading...
    The tach is inaccurate
    Just call me Mark
    My Site
  17. #16
    Join Date
    Apr 2002
    Location
    harrison nj
    Posts
    1,049
    my tach must be way off than because i've yet to hit the limiter and i'ts gone as far up as 8 and yesterday it went well over 8 and it not bounce at all!
    630cc injectors
    jwt s3r cams
    unorthodox pulleys
    OCTAT RSTB
  18. #17
    Join Date
    Feb 2004
    Location
    BUFFALO, ny
    Posts
    5,318
    werd!
  19. #18
    Join Date
    Mar 2003
    Location
    nh
    Posts
    1,616
    Are you running a jwt ecu by any chance? Have you disabled the rev limiter? That seems very weird that you were able to rev to the point of causing damage with out being in gear.
  20. #19
    Join Date
    Apr 2002
    Location
    harrison nj
    Posts
    1,049
    not that i know of,, i bought the car off some kid in rochester a couple of weeks ago. From what i could tell the only mod done to the car was a shift knob
    630cc injectors
    jwt s3r cams
    unorthodox pulleys
    OCTAT RSTB
Posting Permissions
  • You may not post replies
  • You may not edit your posts
