ATTN all with Calum ECU
Results 1 to 10 of 10
Thread: ATTN all with Calum ECU
  1. #1
    G20 Member
    Join Date
    Apr 2005
    Location
    narragansett RI
    Posts
    311
    i have a few questions regarding the tuning with this ECU.
    i'm running basically an avenir turbo setup on 9psi. i am trying to sell my pretty much complete emanage in favor of the calum ECU. i've been reading he can remove rev limiter/speed limiter/etc...how is it that i would go about actually tuning and burning a chip? i know i'll have to get a rom burner and all associated hardware but i cant seem to find the software so i can familiarize myself with it before i order/install.
    any help will be greatly appreciated. thanks in advance.
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Senior Member gdubb's Avatar
    Join Date
    May 2004
    Location
    oakley ca
    Posts
    600
    im sending my ecu out tomorrow to have calum tune it
  4. #3
    Nobody f's with the Jesus Yahnozha's Avatar
    Join Date
    Mar 2002
    Location
    Land of Enchant
    Posts
    11,381
    check calums forum on sr20forum.com there is a ton of info there that will help you out.
    P@ = Pat - No longer "The Man" - Odd greenish P11 Daily Driver (170K) - 01' Pathy 4x4
  5. #4
    V3.0 VE-T Mautai916's Avatar
    Join Date
    Oct 2004
    Location
    Sacramento, CA
    Posts
    3,174
    Quote Originally Posted by Yahnozha
    +1
    On a side note for those that dunno about Calcum. He's the guy over @ Sr20forum that pretty much does what JWT can do for your ECU except he can do it better + cheaper. But the ONLY drawback is that he only does OBD1 ecu's.
  6. #5
    G20 Member
    Join Date
    Apr 2005
    Location
    narragansett RI
    Posts
    311
    Quote Originally Posted by Mautai916
    +1
    i found that he will give you a good base map but i found very little info about how one would go about actually tuning the ECU. i know you need the rom burner and such but i havent seen any software outside of the consult interface.
    i searched on sr20forum and maybe its just me being search-lexic but i didnt find anything.
  7. #6
    G20 Guru MikeG's Avatar
    Join Date
    Mar 2003
    Location
    nh
    Posts
    1,616
    Ahh the future is bright for obdII though.. He recently got the daughter board working on them. Only problem is no one has any obdII programs for them yet but that will change shortly. He has a few proto type ecus being made and people are fiddling around with them trying to get programs to copy over to the new ecus. Woot!
    Check the linky for more info on the obdII:
    http://www.sr20forum.com/showthread.php?t=161597
    Mike
  8. #7
    Join Date
    Mar 2003
    Location
    nh
    Posts
    1,616
    Quote Originally Posted by beakmoney
    If you get contributers account axcess he has a forum where you can download working programs and burn them yourself onto one of his ecus. All the programs are sorted out by people running his ecus and alot of them work very well.
    Mike
  9. #8
    G20 Guru ERIKbronx's Avatar
    Join Date
    Mar 2002
    Location
    NYCGs
    Posts
    4,451
    Im looking into getting a obdII programmed ecu from Calcum as weel. But im wonder if u update/burn ur ecu using a laptop? I noticed on his thread he said something about usb... That would be great!
  10. #9
    G20 Member
    Join Date
    Apr 2005
    Location
    narragansett RI
    Posts
    311
    Quote Originally Posted by ERIKbronx
    erik, you need a rom burner i know that much.
    what i'm unclear on, is can you live edit this ecu for realtime tuning without burning a rom every time you make a change?
    also i wonder if calum is good enough to let the ECU run on a MAP sensor in place of the MAF, using the same wiring. seems like it wouldnt be too hard for someone with a good programming background. just need a voltage scale from a given sensor and adjust fuel tables accordingly to that instead of the MAF scale..who knows...certainly not me..if i did i'd be running megasquirt.
  11. #10
    G20.net Staff
    Super Moderator
    markbuts3's Avatar
    Join Date
    Jan 2004
    Location
    Derbyshire, UK
    Posts
    11,586
    http://www.romeditor.com/liveedit.html Also check out the paid for NRE.
    http://www.z31.com/prom/romedit/
    http://www.nissanclub.com/forums/ecm...ogramming.html
    http://www.nissanclub.com/forums/2889382-post1.html
    Not sure on the burners and software used to do that, Calum was supposed to be detailing that here
    Just call me Mark
    My Site
Posting Permissions
  • You may not post replies
  • You may not edit your posts
