**P11 Bulb Replacement Guide** - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 67
Thread: **P11 Bulb Replacement Guide**
  1. #21
    G20 Newbie
    Join Date
    Mar 2007
    Location
    Baltimore, Md
    Posts
    42
    Is this the same guide for the P10 or does anyone know where I can find it....
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #22
    G20 Guru merlin's Avatar
    Join Date
    Sep 2005
    Location
    around
    Posts
    2,881
    Quote Originally Posted by P10G20
    http://g20.net/forum/showthread.php?t=27668
  4. #23
    Pizdeet kak Trotsky J..M's Avatar
    Join Date
    Aug 2005
    Location
    NW UK
    Posts
    3,069
    Key questions: What size bulbs does my Primera P11 use/ take/ need
    Nissan Primera P11 (1996~1999) Light bulbs guide
    High beam headlamp
    448 (H1) 55w
    Dipped beam headlamp
    448 (H1) 55w
    Fog Lights (Front)
    448 (H1) 55w
    Side light
    501
    Front turn signal
    581 (Amber)
    Rear turn signal
    581 (Amber)
    Stop & Tail light
    566
    Rear Fog Lights
    382
    High mount stop light (Saloon)
    382
    High mount stop light (Hatch)
    Led array (ya fooked) RTFM
    "PRND21" Transmission mode display (Auto Only)
    501
    License plate
    501
    Reversing light
    382
    Glove Box
    501
    Interior Light (Door Controlled Courtesy Light)
    (Festoon Type) Ferk Knows Really
    Interior Light (Next to Rear View Mirror)
    501
    Inside Boot/Hatch Load area
    501
    Dash Analogue Clocks Night Illumination
    501
    Dash Digital Clocks Night Illumination
    286
    Heater Controls Night Illumination
    286
    Dash Warning Lights
    286
    Ignition Light (in dash) Dunno why its different to all the others
    501
    What do they look like .......... (Bulbs Ya Turkey)
    H1 (Don't touch the glass)
    581 (Locating pins at ten to two position.... think clockface)
    566 (Dual Filament)
    382 Pretty standard
    Festoon
    501 Push fit
    286 (The original dash bulbs have a blue condom over them)
    286T (Same as 286 but you get the base as well)
  5. Remove Advertisements
    G20.net
    Advertisements
  6. #24
    G20 Member Plat-num's Avatar
    Join Date
    Jul 2002
    Location
    Hawaii
    Posts
    302
    why is this not a sticky? i always take sooo long trying to locate this thread. lol
  7. #25
    Join Date
    Jul 2002
    Location
    Hawaii
    Posts
    302
    Anyone know the bulb for the map light by the rear view mirror on a USDM P11?
    is it the same as the dome light?
  8. #26
    THEY TOOK OUR JOBS! P11Gdub's Avatar
    Join Date
    Apr 2005
    Location
    Sunagakure
    Posts
    13,766
  9. #27
    G20 Guru burubuduy's Avatar
    Join Date
    Oct 2007
    Location
    LoS AnGeLeS
    Posts
    1,980
    still not a sticky?
  10. #28
    G20 Newbie
    Join Date
    May 2008
    Location
    Sacramento, CA
    Posts
    23
    Would anyone know why my US 2001 P11t use the PY21W (581) bulbs for the turn signals? It's the same as what's listed for the Primera P11. The bulb is marked PY21W. I went in to Autozone looking at the 7440 bulbs which are listed for the US P11, and they aren't even close to the same type.
  11. #29
    G20 Senior Member
    Join Date
    Nov 2008
    Location
    Minnesota
    Posts
    642
    please sticky this thread!!
  12. #30
    G20 Member
    Join Date
    May 2007
    Location
    America
    Posts
    151
    What's the deal with CHMSL on the G20t (the one in the spoiler)? Mine stopped working, but looks like its a bunch of LED's. Ok.... So, do you replace the whole unit or is there something else I should be checking first?
    Thanks.
  13. #31
    G20 Member
    Join Date
    Apr 2006
    Location
    Milwaukee
    Posts
    144
    Excellent guide, better than the manual! Thank you.
  14. #32
    Join Date
    Oct 2007
    Location
    LoS AnGeLeS
    Posts
    1,980
    Quote Originally Posted by Plat-num View Post
    anyone got answers for this?
  15. #33
    brave little...
    Join Date
    Nov 2008
    Location
    SLC
    Posts
    2,648
    194/168
  16. #34
    Join Date
    Oct 2007
    Location
    LoS AnGeLeS
    Posts
    1,980
    ^^ yo da man!
  17. #35
    G20.net Staff
    Super Moderator
    slimlou's Avatar
    Join Date
    Sep 2004
    Location
    Calgary, AB
    Posts
    6,140
    Quote Originally Posted by Sphinx View Post
    Thanks.
    You'd have to replace the entire unit, if indeed it's the issue. However, 99% of the time, the LED brake light bar is not the issue. Instead, it's broken wires in the wire harness that provides power to all the lights on the trunk lid itself. The wire harness is located on the passenger side trunk hinge. Sometimes the break in the wire(s) is quite obvious, and the outer rubber protective sheath is cracked as well, and you can see the broken wires. Other times the sheath is still intact, and you can't see the broken wire(s). In this case, you'd need to do a continuity check on each wire. The best way to do this is to remove the wire harness, and check it. Actually, I lie, you don't need to take out the harness, you can just check for voltage with the harnes in place using a multimeter. You'd need to check this by first disconnecting the harness on the trunk end. It's a white 6 pin connector. However, you might need a second person to be inside the car to depress the brake pedal. You might as well check all the wires as well, because this same harness provides the power to the reverse lights
    In my case, my LED light bar was to blame. Mine wasn't working, I saw the crack in the protective sheath, so I replaced the harness. But my LED light bar still wasn't working! So when I took the light bar out, I saw the issue. Somehow water got into it, and shorted out one of the diodes inside it. The two halfs are ultrasonically welded together, and I tried opening it up without destroying it, but I couldn't. Luckily I found a used light bar. Brand new, they go for $250-300! Yikes!!
    FYI, there's been a few separate threads on this very topic. I've posted pics of the harness and where the break occurs. Unfortunately, I can't remember the exact thread(s) at the moment.
  18. #36
    Join Date
    Oct 2007
    Location
    LoS AnGeLeS
    Posts
    1,980
    anyone knows the bulb size for P11 third brake light?
    its 1156
  19. #37
    G20.net Staff
    Super Moderator
    slimlou's Avatar
    Join Date
    Sep 2004
    Location
    Calgary, AB
    Posts
    6,140
    Arrow Vanity Light Bulbs
    To answer that age old question, "What type of bulb is used in the visor vanity lights?"
    I got curious the other day and decided to find out! They are called a fuselamp (fuse lamp). It looks like this:
    The dimensions are 6mm diameter & 29mm long. And according to my P11 FSM, they are 8 watts.
    The closest sized bulbs out there are festoon bulbs, but they are 8mm x 31mm. and the diameter of the glass portion is often larger than 8mm (they bulge out in the middle) and there really isn't alot of room for anything larger than 6m IIRC. I took pics with my cell phone, but can't seem to d/l or send them from it. Crappy pics anyhow.
    Next Question people will ask, where can I get an LED version. Answer - Nowhere. I called up superbrightleds.com and spoke with the them. The guy I talked to is a car nut with a Honda (we'll forgive him for that) but he said he too would love to go LED for these bulbs, but they're not available. He said he's going to harass his management again about finding some. He's received alot of requests.
    Another solution? Possibly! I scrolled through flea-Bay and I think I may have found a bulb that will work. I ordered a pair, and just waiting on them. The only issue is the ones I ordered are an 8mm diameter & 31mm long, and I think that might be too big. I'm sure I can pop them in, just not sure if they'll stay in. I'll keep you all posted!
  20. #38
    G20 Newbie Kulpa's Avatar
    Join Date
    Mar 2010
    Location
    Montréal, QC
    Posts
    38
    Hey I just bought some new headlights and im looking for some bulbs! are these going to fit? Any suggestions are welcome
    headlight link: http://cgi.ebay.ca/JDM-Nissan-Infini...#ht_2520wt_913
    Bulb link: http://cgi.ebay.com/ebaymotors/50W-5...ht_5930wt_1167
    thz in advance, Kulpa
  21. #39
    Join Date
    Mar 2007
    Location
    orlando/ct
    Posts
    3,201
    duals are h1
  22. #40
    Join Date
    Mar 2010
    Location
    Montréal, QC
    Posts
    38
    bi-xenon hid h4?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
