slipping clutch temporary fix
Results 1 to 10 of 10
Thread: slipping clutch temporary fix
  1. #1
    G20 Guru
    Join Date
    Apr 2002
    Location
    VA
    Posts
    2,312
    my clutch is starting to slip but i really dont have the cash to get a new one now, so is there any way to tighten something up in there or what not so it will drive ok for a few months until i can get some more money?
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Junkee GTA_G20's Avatar
    Join Date
    Mar 2002
    Location
    Ajax,Ontario,Can
    Posts
    2,339
    you could drive with out using the clutch.
  4. #3
    G20 Guru KevShek's Avatar
    Join Date
    Mar 2002
    Location
    NE England, UK
    Posts
    1,566
    or you could lighten the load of your Lead Right Foot! hehe. I dont think theres gonna be a quick fix to this but bear in mind that the longer you leave t, the more chance of it slipping and burning up the flywheel. Then you create high spots and the flywheel will need refacing or you will get judder to no end. Even your new clutch wont fix that out then. In fact you will probably wear the new clutch out prematurely. So just be careful i say.
  5. Remove Advertisements
    G20.net
    Advertisements
  6. #4
    G20 Guru
    Join Date
    Apr 2002
    Location
    VA
    Posts
    2,312
    I dont know about not using the clutch. Im not quite there yet, but ive definitely slowed down both my driving and my shifting. Maybe ill just have to get a lightened flywheel at the same time as the clutch...
  7. #5
    Join Date
    Mar 2002
    Location
    Ajax,Ontario,Can
    Posts
    2,339
    I dont know how to explain it to you but I can do it. I guess at a certain RPM the flywheel matches the clutch and you can change gears without using the clutch. If you practice double clutching it will be really easy
  8. #6
    G20 Guru
    Join Date
    Apr 2002
    Location
    VA
    Posts
    2,312
    I'm ok at double clutching, but I never saw much point in doing it before. I'm more a single clutch kind of guy, but if it comes right down to it, i might have no other choice. So far at least it hasnt been slipping so long as I just take it easy you know.
  9. #7
    G20 Member JG20's Avatar
    Join Date
    Mar 2002
    Location
    Toronto
    Posts
    199
    If your clutch cable is too tight, you can try loosening it a little. This will let your clutch grab more. If your cable is already loose, then try GTA_G20s idea. I've heard of other people doing it but I'm afraid to try it myself.
  10. #8
    G20 Guru
    Join Date
    Apr 2002
    Location
    VA
    Posts
    2,312
    That might be worth a try but i already barely have to push the pedal in to release the clutch so I think its shot. What does a clutch job usually end up costing for labor only (dealer or elsewhere)?
  11. #9
    G20 Member Money G20's Avatar
    Join Date
    May 2002
    Location
    Indianapolis
    Posts
    194
    reducing clutch wear
    This technique is called "speed shifting" and it's a good way to screw up a perfectly good transmission. If you use too much force, you can shear off a dogtooth and that's not a good thing to have rattling around in your transmission case. It should also be noted that it's only possible with gears that are close in ratio (3, 4, 5). Double clutching can help if done correctly, but it's overkill if all you're wanting to do is save wear on your clutch. Rev matching is probably your best bet since it's simpler than double clutching and safer than speed shifting. Bottom line, though, there's no way to "undo" a worn clutch and it's better to replace it ASAP before other damage is caused.
  12. #10
    G20 Guru
    Join Date
    Apr 2002
    Location
    VA
    Posts
    2,312
    What other damage can be caused? Ive heard the flywheel can get a little screwed up, but this can be resurfaced at the same time the new clutch is installed. Is there anything else i should be worried about?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
