Any way to polish plastic?
Results 1 to 9 of 9
Thread: Any way to polish plastic?
  1. #1
    G20 Guru mattb's Avatar
    Join Date
    Sep 2002
    Location
    Herndon, VA
    Posts
    5,585
    So I got the I35 grill in the mail today, and the finish on it is scratched and pitted from normal wear. Is there anything I can use on it to polish it up and make it look better? It's painted plastic.
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Member 4dollarg20's Avatar
    Join Date
    Dec 2006
    Location
    parma, oh
    Posts
    430
    flitz it
  4. #3
    G20 Member Wiggy's Avatar
    Join Date
    Nov 2002
    Location
    utah
    Posts
    415
    use meguiars plasti - x. its a plastic polish. its in a white bottle and costs about 5 bucks dose a wonder on plastic headlights and on my phone
    joe
    hope that helps
    "A good friend will bail you out of jail, but your best friend will be the one sitting next to you saying "That was fu(*ing awesome!"
    Mods to the g include (a)Obx header (b)Battery in the trunk (c)short shifter (d) Apexi TT (e)UR underdive pulley set (f) fidanza flywheel (g)crown stainless steel brake lines (h)rear strut tower bar that i built (i) a front strut tower bar that i built (j) a lower control arm brace that i built (k)a set of four blown shocks/struts that are waiting to be replaced with adjustables and coilovers once i get the money(l)Hot Shot Cold Air Intake w/ $30 autozone filter (m) JWT s3 cams (n)ADDCO rear anti-sway bar (o) infinity speakers front and rear
  5. #4
    G20 Guru njprimera's Avatar
    Join Date
    Dec 2005
    Location
    Sussex, NJ
    Posts
    2,522
    Quote Originally Posted by Wiggy
    joe
    hope that helps
    it specificly says on Plasti-X that it should not be
    used on painted surfaces. its for bare plastic only
  6. #5
    G20 Guru SgtDGun's Avatar
    Join Date
    Jan 2007
    Location
    Texas & SC
    Posts
    2,139
    well think of it as polishing paint not plastic in this case. so buff it with a fine polishing compound
  7. #6
    Dude, your bed is a car..
    Join Date
    Jan 2007
    Location
    Illinois
    Posts
    4,568
    Yeap. fine polishing compound would do the trick...
  8. #7
    G20 Member
    Join Date
    Jan 2007
    Location
    DFW
    Posts
    107
    they fit on P10 or P11?
  9. #8
    I met Gate Cat hiimj0ne's Avatar
    Join Date
    Mar 2002
    Location
    San Jose, CA
    Posts
    4,436
    Quote Originally Posted by docG20
    no.
  10. #9
    no rainguard clips...FML junknstuff's Avatar
    Join Date
    Jan 2005
    Location
    san jose, ca
    Posts
    4,132
    he has an a33 not p chassis
Posting Permissions
  • You may not post replies
  • You may not edit your posts
