Harness install in my P10
Results 1 to 17 of 17
Thread: Harness install in my P10
  1. #1
    G20 Guru SHigSpeed's Avatar
    Join Date
    Feb 2007
    Location
    Rocklin, CA
    Posts
    2,986
    So, a few have asked so here goes...
    I have a Sabelt 3" web 4 point camlock installed in my P10 for track day use.
    It snaps in and out so it's out of the way daily driving...
    Here's where it anchors:
    Behind the fold-down seat behind the driver, I have an eye-bolt through the sheetmetal bulkhead backed by a 2" x 5" or so 1/4" steel plate.
    It's drilled through a double thick part in the sheet near a crease so I think it's suitable for anchoring the rear leg. BTW, note that the rear leg is the anti-sub portion of the 5 point harness attached to the pair of shoulder fly-backs using some heavy duty washers as a link.
    The outboard mount is another eyebolt drilled through the floor and backed by another piece of 1/4" thick steel.
    The inboard mount is a piece of 3/16" thick by 1" steel bar, drilled and bent and anchored through an extended bolt that ties down the seat rail. The bolt is through, then the strap, then a backing nut.
    Sure, it wouldn't pass SCCA tech, but it's strong enough for my purposes. BTW, with the B Pillar where it is in the G, I don't think that a harness and no cage is an issue. Especially if the stock 3 point belts pre-tensioners fire, I'll bet that you have as much "side-duck" as in the harness. I'll take my chances. Besides, I'm that much more likely to lose control if I'm in the stock belts sliding around on the leather than if I'm firmly cinched down and not fighting to stay put!
    _SHig
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    Full-Time Chiller . . . . Black95G20's Avatar
    Join Date
    Sep 2002
    Location
    Southeast NH
    Posts
    6,286
    Sweet
    May 2008 MOTM
    Check out my T-Shirt company, funny/quality shirts: www.ratfinktshirts.com Code jesp414 saves you $3 per shirt.
  4. #3
    THEY TOOK OUR JOBS! P11Gdub's Avatar
    Join Date
    Apr 2005
    Location
    Sunagakure
    Posts
    13,781
    looks safe to me!
  5. #4
    Yeah That Just Happened! Dane's Avatar
    Join Date
    Aug 2004
    Location
    Oak Town, Wa
    Posts
    14,165
    You are the man, now to find an inexpensive pair of takata green belts. Yeah right!!
    Quote Originally Posted by Blackwater32 View Post
    Someone quote me.
    Dane, don't quote me
    WWW.TOP5DOA.NET
  6. #5
    T3h Sexy Beast trbobrk's Avatar
    Join Date
    Mar 2002
    Location
    Seattle, WA USA
    Posts
    19,703
    ^ yeah even the fake ones are expensive.
    How high is the mount in the back compared to your sholders? I want to install my harnesses but I think I should at least have a bar for the belts to go over that is above the sholders a tiny bit.
  7. #6
    Join Date
    Feb 2007
    Location
    Rocklin, CA
    Posts
    2,986
    It's pretty much level with my shoulders. FYI, for you non-touring guys, you can slit the vinyl behind the headrests (93.5 up only) and you can access the eye bolt through there. Rest of the time the headrest can drop down to cover it up. Early cars are SOL though. You could use the furry screw holes to make a mount though (they're there for baby car seats so they should be strong enough...).
    _SHig
  8. #7
    magnificent pooper Zohaib's Avatar
    Join Date
    Mar 2006
    Location
    Long Island
    Posts
    4,024
    Quote Originally Posted by GreenG20t View Post
    http://www.soloracer.com/takataharness.html
    not that bad. good sabelts are around $300, shell another $100 for JDMness
    thanks shig! now the question: why wouldn't it pass SCCA tech?
  9. #8
    Join Date
    Feb 2007
    Location
    Rocklin, CA
    Posts
    2,986
    Quote Originally Posted by Zohaib View Post
    I think SCCA requires (for roadracing, not SOLO II) a 4" x 4" by 1/8" steel backing plate or something like that. Never seen any regulations that specifically allowed seat mount mounted harness attachments either...
    I like red over green tho! $94 for harness PADS! Ludicrous!!
    _SHig
  10. #9
    Why yes, I am a Moderator Uncle Dave's Avatar
    Join Date
    Nov 2005
    Location
    Vietnam
    Posts
    8,918
    Looks good Scott.
    In my B13 the harness attaches similar, it clips into another deal in the back.
    I'll have to take a closer look to see if your way would be better.
    My old Feedback
    Quote Originally Posted by Nelson View Post
    Looks good, but something about the front bumper is bothering me...now go get your F'ing Shine Box.
    Quote Originally Posted by G20-Unit View Post
    You only heard the gunshot, but you didn't see the slap that came before it..
  11. #10
    Join Date
    Mar 2006
    Location
    Long Island
    Posts
    4,024
    Quote Originally Posted by SHigSpeed View Post
    _SHig
    I wanted to know for HPDE and Solo I next year. AutoX is fine in my regular belt, until i spoil myself. gonna have to buy me a rulebook
    thanks!
  12. #11
    Join Date
    Feb 2007
    Location
    Rocklin, CA
    Posts
    2,986
    Regular belt for AutoX? No way! At least get a "Turner Belt". Basic WalMart quick release 2" web belt (Camo Ammo belts are like $5!) that you wrap around your torso and the seatback. Keeps you in place, though not meant to replace a standard 3 point of course!
    Another trick I've used is to recline the seat and slide the seat back, jerk the belt to lock it, then slide forward and put the seatback up. Works well if you get the right "preload".
    _SHig
  13. #12
    Join Date
    Mar 2002
    Location
    Seattle, WA USA
    Posts
    19,703
    ^ I've done that before. Easier to do with power seats.
  14. #13
    G20 Member
    Join Date
    Jul 2007
    Location
    miami
    Posts
    149
    anymore pictures?
  15. #14
    Join Date
    Feb 2007
    Location
    Rocklin, CA
    Posts
    2,986
    Of what?
    _SHig
  16. #15
    G20 Guru Chris's Avatar
    Join Date
    Mar 2002
    Location
    Mt. Prospect,IL
    Posts
    12,455
    just be careful about submarining
    ...maybe get a 6 point to avoid that?
  17. #16
    Join Date
    Feb 2007
    Location
    Rocklin, CA
    Posts
    2,986
    Nah, that'd mean cutting the 't' leathers. I don't plan to track this car that hard, and a 4 point 3" harness is safer in an impact than a 3 point 2".
    Hey, let's swap seatbottoms! Or you could advertise yours as "anti-sub belt ready"!
    Of course there are those who would say that a harness is more dangerous in a rollover, but I'm not convinced, especially in a P10 with the door frames and B Pillars right there...
    _SHig
  18. #17
    Join Date
    Mar 2002
    Location
    Mt. Prospect,IL
    Posts
    12,455
    If you get a 6 point belt, you can mount it in such a way that requires NO drilling/cutting of seat bottom.. You basicly set it up so you are sitting on it and pull up to click in... *understand?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
