OEM struts vs AGX
Results 1 to 19 of 19
Thread: OEM struts vs AGX
  1. #1
    G20 Senior Member serganich's Avatar
    Join Date
    Mar 2007
    Location
    Seattle
    Posts
    832
    OEM struts vs AGX
    I want to get OEM rears and fronts.
    Rears are too pricey though, AGX seems to be way cheaper but i very concerned about a quality of ride with AGX.
    I heard that they stiffer and not as good as NEW OEM ones.
    The car is not lowered and not going to be, i will reuse OEM springs at this time also. Has anyone any experience please share. Thanks
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Senior Member
    Join Date
    Nov 2007
    Location
    Someones Canyon
    Posts
    671
    AGX's are WAY better than OEM. The AGX's are adjustable and you can set them to meet your driving style. I had them on both of my 200sx's and I loved them. It's the KYB GR2's that I'd stay away from. But then again, to each his own.
  4. #3
    G20 Member Diavolo's Avatar
    Join Date
    Jun 2007
    Location
    Bay Area, Cali
    Posts
    430
    You don't need the AGX (adjustables) just get some GR-2.
    They are an OEM replacement, and will ride like stock.
    here are the best prices:
    Buy the shocks at rockauto:
    $53.99 each
    http://www.rockauto.com/catalog/x,ca...6,partGroup,27
    use my discount code at rock auto and get 5% off.
    941498831887
    ...and buy the struts at classic garage:
    $122.96 for the pair
    http://www.classicgarage.com/ing20recostp.html
  5. #4
    Join Date
    Mar 2007
    Location
    Seattle
    Posts
    832
    I appreciate quick answer, here is my concern though.
    I do like how the G20 handles, thats the only reason i'm keeping it and rebuilding it. The OEM struts were designed to give such ride to the car, while aftermarket you got to adjust. I understand this might be a benefit to those who needs it, but i dont.
    I need to know how are they comparing to OEM ones, are they harsher, are they wear out faster, what are they? How much stiffer they are? Can i have them adjust to same as OEM ride quality?
    Diavolo I sure appreciate your response, thanks for the links, i will definatly look into it, the price is great too
  6. #5
    Dont Fool with his Cool Jaralaccs's Avatar
    Join Date
    Nov 2005
    Location
    Delco, PA
    Posts
    2,357
    you can set them to have the same stiffness as stock.
    I believe the rears can even go softer than stock, but it's not like it will make major differences. I'd stick with GR-2s if you are keeping everything else the same
  7. #6
    G20 Guru MaximusG20's Avatar
    Join Date
    May 2005
    Location
    Atlanta
    Posts
    1,735
    SUBS! Inquiring minds want to know cause I plan on getting the AGX's soon also.
  8. #7
    Full-Time Chiller . . . . Black95G20's Avatar
    Join Date
    Sep 2002
    Location
    Southeast NH
    Posts
    6,286
    AGX > OEM
    AGX on setting 1 is same stiffness as stock +/- 5% stiffness.
    I heart my AGX's
    May 2008 MOTM
    Check out my T-Shirt company, funny/quality shirts: www.ratfinktshirts.com Code jesp414 saves you $3 per shirt.
  9. #8
    G20 Senior Member
    Join Date
    Nov 2007
    Location
    Someones Canyon
    Posts
    671
    Quote Originally Posted by serganich View Post
    Are they harsh and wear out faster: No.
    What are they: Better than stock.
    How much stiffer: Depends on what you have them set at.
    Adjust to be as smooth as OEM: Yes.
  10. #9
    Join Date
    Jun 2007
    Location
    Bay Area, Cali
    Posts
    430
    Quote Originally Posted by Jaralaccs View Post
    +1
    Exactly just get the GR-2's you WILL NOT notice much of a difference compared to stock. It will still be a nice ride. Don't worry so much about it, you'll be happy.
    Don't waste your money on adjustables.
  11. #10
    Join Date
    May 2005
    Location
    Atlanta
    Posts
    1,735
    Quote Originally Posted by Diavolo View Post
    +1
    Exactly just get the GR-2's you WILL NOT notice much of a differenc compared to stock. It will be a little more responsive, and with less lean in corners.
    Still a nice ride.
    So which is cheaper and durable of the 2? AGX or GR-2?
  12. #11
    Join Date
    Jun 2007
    Location
    Bay Area, Cali
    Posts
    430
    GR-2 are less expensive. Both are just as durable.
    My RX7 has AGX and my G20 has GR-2's
  13. #12
    Join Date
    May 2005
    Location
    Atlanta
    Posts
    1,735
    Thanx bro, so where's the link to the GR-2's?
  14. #13
    G20 Guru merlin's Avatar
    Join Date
    Sep 2005
    Location
    around
    Posts
    2,881
    +1 to everything, GR-2 are a perfect stock replacement if you like the way it rides stock, save your $$ and get the GR-2s
  15. #14
    Sick of idiots on G20.net SR20 Inside's Avatar
    Join Date
    May 2002
    Location
    Not on g20.net
    Posts
    2,615
    $53.99 each
    941498831887
    The rockauto link is that for a pair of agx's for 108.79 or 108.79 each?
  16. #15
    Join Date
    Mar 2007
    Location
    Seattle
    Posts
    832
    Great guys thanks, GR-2 it is!
    The reason i'm concerned about KYB, i bought them for my Jaguar once and they were absolutely horroble, POS!
    But if you say they are fine then i go for it
  17. #16
    Join Date
    Sep 2002
    Location
    Southeast NH
    Posts
    6,286
    basically all of us run kyb's without issues, so you should be fine.
    May 2008 MOTM
  18. #17
    el capitán Nismo nis.k.a.'s Avatar
    Join Date
    Sep 2002
    Location
    Denzel, WA
    Posts
    2,242
    I need to know how are they comparing to OEM ones, do they wear out faster?
    No need to worry there. AGX = Lifetime warranty. Especially since you're not lowering the car.
    Everything else has been covered.
    You mentioned you liked the handling. There is a gray area between stock and compromising. AGX and tires would be a great combination for a super stock ride.
  19. #18
    Join Date
    Mar 2007
    Location
    Seattle
    Posts
    832
    Good deal, fortunatly i just got 15 inch twenty spoke wheel off of a 99, with basically new 195/60/15 GoodYear Triple Tred. And a steering rack with 49K on it with new boots and tie rod ends. Installing this saturday, u know this lifetime free alingment at firestone is great thing, for the past year i'v done 5 alingments for 130 bucks.
  20. #19
    G20 Member
    Join Date
    Sep 2006
    Location
    San Francisco
    Posts
    388
Posting Permissions
  • You may not post replies
  • You may not edit your posts
