can a bad evap canister affect gas mileage
Results 1 to 7 of 7
Thread: can a bad evap canister affect gas mileage
  1. #1
    G20 Senior Member
    Join Date
    May 2007
    Location
    Boston, MA
    Posts
    816
    jus asking because i know i have to get my evap canister replaced, my car also get poor gas mileage, i was just wondering if the evap canister could affect my mpg?
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Member
    Join Date
    Dec 2006
    Location
    NY/NJ
    Posts
    192
    no evap canister neutralize vapor from gas tank
  4. #3
    G20 Guru
    Join Date
    Jun 2007
    Location
    BFE South
    Posts
    1,418
    evap csystem is in place to attempt to keep gas fumes from entering the atmosphere. it sends excess fumes into the intake manifold to be burned in the engine. car will run/perform fine without it. it will not effect anything. only thing is you will get a hiss when you remove the gas cap.
  5. Remove Advertisements
    G20.net
    Advertisements
  6. #4
    shenanigans gotboost44's Avatar
    Join Date
    Apr 2006
    Location
    Waukesha, WI
    Posts
    2,002
    I always get a hiss when I open the gas tank. Does that mean my evap system is not working right??
  7. #5
    G20 Guru
    Join Date
    Jun 2007
    Location
    BFE South
    Posts
    1,418
    that is what i was told by a mechanic. he was replacing the evap on a mustang when i asked him what exactly it did.
    so from what i have been told, i would say yes it is not working as it should.
  8. #6
    Still learning :D LilAznFishinDude's Avatar
    Join Date
    Dec 2005
    Location
    Sacramento, CA
    Posts
    2,233
    Ehhhh... I dunno. I'm a noob at this, but I get the hiss every now and then when I fill up. I believe it's just pressure built up by the fuel pump. I've read some one else say this. If you let your car sit a while, you won't get the hiss when you pop the cap.
  9. #7
    G20 Guru
    Join Date
    Feb 2007
    Location
    Santa Rosa, Ca.
    Posts
    2,862
    The gas cap hiss has nothing to do with the functionality of your EVAP system.
    And no, a bad canister wont affect your mileage by any drastic means. Maybe .5 to 1 mpg
Posting Permissions
  • You may not post replies
  • You may not edit your posts
