What's the octane rating for a VE?
Results 1 to 18 of 18
Thread: What's the octane rating for a VE?
  1. #1
    G20 Junior Member P-ten's Avatar
    Join Date
    Aug 2006
    Location
    Minnesota
    Posts
    87
    Sup y'allz? I'm just trying to find out what the octane rating is for an SR20VE. Anyone know for sure and not guessing/assuming? Thanx!
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    3 Hole Bumper Guru stuntzG20's Avatar
    Join Date
    Feb 2008
    Location
    02339 & 02360
    Posts
    4,497
    im guessing you'd wanna run 91-93 which ever you find,
    IIRC in Japan they have higher octane rating's at the pump.
    "Generally, octane ratings are higher in Europe than they are in North America and most other parts of the world. This is especially true when comparing the lowest available octane level in each country. In many parts of Europe, 95 RON (90-91 AKI) is the minimum available standard (but is called Premium Unleaded), with 97/98 being higher specification (being called Super Unleaded)"
    thats from wikipedia and im guessing would be the same for Japan, Asia.
    Quote Originally Posted by 00 blk G20t View Post
    stuntz started yelling on a megaphone.
    Quote Originally Posted by Blackwater32 View Post
    looks like he got his penis stuck in the air box again.
  4. #3
    G20 Member stockone's Avatar
    Join Date
    Nov 2005
    Location
    Tampa, FL
    Posts
    223
    No less than 91, but 93 or better if you can get it.
  5. #4
    G20 Guru Domiken's Avatar
    Join Date
    Apr 2002
    Location
    Queens-New York
    Posts
    7,569
    93'
  6. #5
    THAT f'ing guy...
    G20.net Administrator
    cavern's Avatar
    Join Date
    May 2002
    Location
    Phoenix, AZ
    Posts
    5,387
    91 with a good and proper tune, otherwise 93 if you can get it.
    - j0n
  7. #6
    G20 Guru
    Join Date
    Jun 2007
    Location
    BFE South
    Posts
    1,419
    if you are going for performance it is almost always going to go with premium.
  8. #7
    Automotive Design Concept Straitup D's Avatar
    Join Date
    Oct 2006
    Location
    MN Member 1of5
    Posts
    3,519
    well 93 is a hard find here in MN, but most of the blueplanet stations have some 92
  9. #8
    G20 Guru james23nyc's Avatar
    Join Date
    Jul 2007
    Location
    Maryland
    Posts
    1,308
    we got 98 over here in maryland
    sike, just playin, I say use '93 like everyone else says, if not, than '91
  10. #9
    G20 Guru
    Join Date
    Jun 2007
    Location
    BFE South
    Posts
    1,419
    there are a few stores around here that sell 100, but i have not checked the price of that lately...
  11. #10
    G20 Member
    Join Date
    Mar 2004
    Location
    ATL
    Posts
    496
    So wus wrong with 87 octane in a VE
    99 P11: VE powered
  12. #11
    G20 Guru
    Join Date
    Jun 2007
    Location
    BFE South
    Posts
    1,419
    nothing is wrong if you are grandma. the higher performance motors RECOMMEND premium. it will perform better. noone said that it would not run or work, but if you are putting a VE in, then you are looking for some kind of performance upgrade, right? or it was just there so you figured you would use it?
  13. #12
    Join Date
    Nov 2005
    Location
    Tampa, FL
    Posts
    223
    Dont even wast your time with pump gas, SR's run better on race fuel.
    J/k. Like stated befor, 91+ or 87 if you don't care.
  14. #13
    Join Date
    Feb 2008
    Location
    02339 & 02360
    Posts
    4,497
    Quote Originally Posted by boommer View Post
    yeah its kinda a bad idea, because the VE is gonna have really shitty performance if you put cheaper gas in it.
    even using 91,93 i'd still add an octane booster every once and a while.
  15. #14
    THAT f'ing guy...
    cavern's Avatar
    Join Date
    May 2002
    Location
    Phoenix, AZ
    Posts
    5,387
    Putting lower octane in will cause massive detonation,,
    If you run that way to long you'll end up with:
    1. Mechanical damage (broken ring lands)
    2. Abrasion (pitting of the piston crown)
    3. Overheating (scuffed piston skirts due to excess heat input or high coolant temperatures)
    To name a few..
    Check out: http://www.streetrodstuff.com/Articl...ne/Detonation/ for more information..
    - j0n
  16. #15
    G20 Guru Chris's Avatar
    Join Date
    Mar 2002
    Location
    Mt. Prospect,IL
    Posts
    12,455
    a lot has to do with how you drive and the outside temp too..
    For example, in the middle of winter, if I'm just doing easy slower driving (not fast shifting, not high revving), I just used regular 87 in my former SRT4.. but in summer months and at the track, ONLY 93 octane (sometimes 94)..
    It just depends on your use.. if you don't get into boost on an SRT4 and drive below 4000 rpm on freezing days.. it is fine...
  17. #16
    BannedDragon CurtDragon's Avatar
    Join Date
    Jan 2005
    Location
    Rahway, NJ
    Posts
    6,393
    lots of speculation.. what does the actual manual say to use for these motors?
    I've been running 87 since I got the motor. No signs of detonation at all but I havent run it with A/C and I'm also running lightweight pulleys on w/p and crank so there is less load on the motor. My timing is set to 15*
    I havent heard any detonation nor have I seen signs when I did a plug change (flashlight down the hole and you can see the piston crown.
    However now that i have a Calum I am doing a log with Premium (93) and Regular (87) to see what the temperatures are like as well as MPG
  18. #17
    G20 Guru md_emory's Avatar
    Join Date
    Sep 2003
    Location
    Mililani, HI
    Posts
    1,660
    thankz - I would like to see that
  19. #18
    rhd specialist j-tek's Avatar
    Join Date
    Apr 2005
    Location
    bay area
    Posts
    4,840
    run 87 if your low on greenbacks; recommend you drive it like your a bus driver though. if money is not the issue go 91-93...... enjoy
Posting Permissions
  • You may not post replies
  • You may not edit your posts
