In what order do you bleed the brakes?
G20.net is the premier Infiniti G20 Nissan Primera Forum on the internet. Registered Users do not see the above ads.
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: In what order do you bleed the brakes?
  1. #1
    G20 Guru
    Join Date
    Jun 2006
    Location
    Bay Area, CA
    Posts
    1,182
    In terms of, driver front, passenger front, passenger rear, and driver rear, in what order should you go for bleeding the brakes?
    Thanks!
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Guru merlin's Avatar
    Join Date
    Sep 2005
    Location
    around
    Posts
    2,881
    Right Rear
    Left Front
    Left Rear
    Right Front
    page BR-7, FSM
  4. #3
    G20 Senior Member biomimetic's Avatar
    Join Date
    Aug 2006
    Location
    Arcata, CA
    Posts
    763
    Where right is passenger and left is driver.
  5. #4
    G20 Member
    Join Date
    Dec 2007
    Location
    Vancouver, BC
    Posts
    204
    my fsm from my 92, says opposite for some weird reason. left rear/right front/right rear/left front. normally rule of thumb is start from the furthest brake from the MC. I guess it's from the different abs system used throughout the years.
  6. #5
    G20 Member MattNJ's Avatar
    Join Date
    May 2008
    Location
    New Jersey
    Posts
    211
    what do you mean by "bleeding" the brakes?
  7. #6
    G20 Guru
    Join Date
    Jun 2006
    Location
    Bay Area, CA
    Posts
    1,182
    Replacing old brake fluid with new brake fluid and getting any air pockets out of the brake lines.
    Can anyone confirm for the 00+ what the order is?
  8. #7
    T3h Sexy Beast trbobrk's Avatar
    Join Date
    Mar 2002
    Location
    Seattle, WA USA
    Posts
    20,479
    They changed the ABS system in 93.
  9. #8
    G20 Guru
    Join Date
    Jun 2006
    Location
    Bay Area, CA
    Posts
    1,182
    So for everything after that, P10's and P11's included, the ABS system and all other brake related stuff is the same, minus the rotors, calipurs and whatnot that take part in the P11 brake upgrade for P10's, and so the bleeding order is the same, passenger rear, drive front, driver rear, passenger front?
  10. #9
    Join Date
    Mar 2002
    Location
    Seattle, WA USA
    Posts
    20,479
    Right Rear, Left Front, Left Rear, Right Front
    2000 FSM BR-8
  11. #10
    G20 Guru
    Join Date
    Jun 2006
    Location
    Bay Area, CA
    Posts
    1,182
    Thanks!
    Yay, soon no more mushy, quickly fading, questionable brakes...
    Then again it's been a good kick in the ass for a reminder of driving. Knowing my brakes are a little mushy, knowing they won't last as long as they could until they fade really helped me remember how to brake the least possible and carry speed through turns...
  12. #11
    G20.net Staff
    Super Moderator
    slimlou's Avatar
    Join Date
    Sep 2004
    Location
    Calgary, AB
    Posts
    6,139
    P10 & P11 Brake Bleeding Order is Different
    According to the FSM's, there is a difference between P10 & P11's.
    Here's a scan from the P10 (93.5) FSM
    And here's scan from the P11 (2001) FSM
  13. #12
    Join Date
    Mar 2002
    Location
    Seattle, WA USA
    Posts
    20,479
    What is wierd is the 94+ FSM shows Right Rear, Left Front, Left Rear, Right Front even though it is the same system as the 93.5.
  14. #13
    G20 Guru
    Join Date
    Jun 2006
    Location
    Bay Area, CA
    Posts
    1,182
    Ugh I should bleed my brakes soon...
    But mad thanks for the postings you guys!
  15. #14
    stock rocks! Robj80's Avatar
    Join Date
    Feb 2004
    Location
    meriden, CT
    Posts
    8,137
    I've always done RR, LR, RF, LF in that order? I was always taught start the furthest away from the master cylinder and work your way up. You learn something new everyday! Also did know your suppose to disconnect the battery when you bleed brakes that have ABS? I wonder what for and how that works?
    How do you know if LSD or not? Like you would check any tranny. Get down there and look for a bulge.
  16. #15
    G20 Guru burubuduy's Avatar
    Join Date
    Oct 2007
    Location
    LoS AnGeLeS
    Posts
    1,980
    so 93.5 and 99 have the same pattern when bleeding?
  17. #16
    G20 Junior Member AlistairJordan's Avatar
    Join Date
    Aug 2009
    Location
    California
    Posts
    77
    Quote Originally Posted by burubuduy View Post
    yeah. but it doesn't really matter i bled mine right front, left front, right rear, left rear. and it is very tight. but i used a caliper vacuum. ;]
  18. #17
    G20 Guru LoSt's Avatar
    Join Date
    Oct 2005
    Location
    Maryland
    Posts
    1,059
    Just to add to this thread: what's the best way to 'flush' old brake fluid? Is it easy to tell when all the old fluid is out and new fluid is in?
    I was thinking of taking my car to a HPDE and after 233k miles I'm sure the fluid could stand to be replaced.
  19. #18
    Join Date
    Oct 2005
    Location
    Maryland
    Posts
    1,059
    Was checking the FSM for my 2000 P11 and I think I see why the bleed order is: Right rear brake -> Left front brake -> Left rear brake -> Right front brake
    on BR-9 there is a picture of the Hydraulic Circuit. I looks like RR & LF are on one and LR & RF are on the other. Seeing it that way, then the order makes sense now.
    Just thought I'd post for the next person to find this thread.
  20. #19
    tornaDON itinifni's Avatar
    Join Date
    Aug 2006
    Location
    Flyover, KS.
    Posts
    805
    So what about a 96? what order should that go?
  21. #20
    G20 Member
    Join Date
    Sep 2008
    Location
    614
    Posts
    377
    Noob question, but this is only on a need-to-do basis right? Or for people who autocross or do a lot of heavy breaking? Ive never done this as its just a DD, but is it something I should seriously think about doing?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
