what do you think the chances are of it fitting for a p11?
i'm figuring splicing on the original harness
well maybe i'll try it out and we will see.
do it, that'd be pretty cool and you can just adjust the redline or get a new tach gauge made to fit in there.
here is the back of the pathfinder one
http://cas07.businessflow.ms/3.9.6/m...d-4542175cc674
any one has pics of the back of the p11 one
if you can find a p11 in any junkyard in florida i would def make that drive
i find alot of p10 but never saw one p11 in any junkyard
i looked in the classifieds and saw no sport clusters at all
if u run into one lmk
the website u posted looks like a 01-02 year. but the shape is very similar to ours
They face looks similar, but the connectors are a bit different. You could probably hard wire it
so far the shape and fit is exact. will update later
success about to update with pix and explanation
took about 40 min to do
purchased on ebay for less then 30 shipped 00 pathfinder cluster
this is the path cluster in our dash
perfect fit up to the mounting points
our cluster is the top one in the picture below
if you look at it in person they are basically identical
the plastic cover is exact same as our p11 one
the black bezel is different in some ways the center rings around the tach and speedo are smaller then the p11 so if you were to try to clip on the path black bezel the circle cutout would overlap or be on top of the tach and speedo needles...
it works the other way around eric so you would be able to sell u'r bezel to them .. our bezel has bigger holes in the middle so it would not touch their needles.
connectors
2 out of 3 of our p11 connectors plug right in and work for those functions but the middle one was slimmer and longer on the p11 so it did not plug into the path cluster.
solution
unscrew the gray/white faceplates off the path and unscrew the black off the p11 one and swap
The only tricky part
is pulling the needles off the cluster you want to pull up without bending the little metal pin that its sitting on but so you know the needles just pop right out. make sure not to spin it while pulling it up and remember where the needle was when you pulled it.
if you wanted to swap out the brain u can unscrew 4 bolts off the back of the housing and remove this
in the end put everything back and you are done.
by the way the nissan part number on these
is the exact same part number as the p11's so really i'm guessing someone could just order them and just specify the color needed.
and i have a feeling that the only reason the 3rd connector was not the same for me was because i got a 4x4 pathfinder cluster by mistake.
Clever. Insta sport style cluster. And yeah, be careful w/the needles.
if i could be anyone on this site other then me..it would be you
