open/closing mechanism from the driver side door
hi,
need the open/closing mechanism from the driver side door. the unit that grabs onto the hinge of the door
the car was recently bought used ('94, P10)
It seemed the open/closing mechanism from the driver side door is much more worn compare to the passenger front's
please read the picture's description.
basically the closing sound should be a "clomph" but mine has a "clunk/click" sound. Opening sounds ok.
can i got that mechanism from a junkyard is it just that unit or bunch of other things connect to it?
not sure if is easy or hard?
-lw
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
