oil leak
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: oil leak
  1. #1
    G20 Member bigj's Avatar
    Join Date
    May 2002
    Location
    memphis,tn
    Posts
    495
    oil leak
    anybody have any suggestions on where to look for an oil leak that is dropping spots near where the exhaust passes the oil pan. i have oil on hoses and wiring harnesses from around half way up the motor down.
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    Join Date
    May 2002
    Location
    memphis,tn
    Posts
    495
    the oil pressure switch is on top of the motor isnt it, beside the headers?????
    thanks
  4. #3
    G20 Senior Member TeqP's Avatar
    Join Date
    Apr 2002
    Location
    Yorba Linda, CA
    Posts
    529
    No, the oil pressure switch is next to the oil filter bracket. You can see it when you go under the car above the passenger side axle, next to a power steering hose. It has a brown rubber cover and a couple of wires coming out of it. I recently replaced mine ($7-8 from infinitipartsusa.com). This was causing a slight leak for me. Once I replaced it, the leak was gone.
    If you have a leak near the exhaust pipe, it could be that the oil pan gasket needs replacing. Just to be sure that it isn't your oil pressure switch, get under the car and check the switch for any oil on the rubber cover.
    Good luck and let us know what you find.
  5. Remove Advertisements
    G20.net
    Advertisements
  6. #4
    G20 Guru NismoPC's Avatar
    Join Date
    Mar 2002
    Location
    Mansfield, OH
    Posts
    2,120
    Re: oil leak
    Based on the pattern of the leak from the oil pressure switch (personal experience), I will have to agree with TeqP and point you to the oil pressure switch. It will casuse oil to leak down the back side of the oil pan as well as on the exhaust depending on how bad yours is leaking.
  7. #5
    Join Date
    May 2002
    Location
    memphis,tn
    Posts
    495
    does it look like a square with a hose on each side??
    thanks.....
  8. #6
    Prince of Joy MrFancypants's Avatar
    Join Date
    Dec 2002
    Location
    Tucson, AZ
    Posts
    4,614
    No it looks like the left most sender in this picture:
    Most likely it is the oil sender... they tend to leak on high mileage cars. If youve never dropped your lower oil pan, and havent scraped it on the ground badly, it is most likely not the liquid gasket leaking.
    - Greg -
  9. #7
    Join Date
    May 2002
    Location
    memphis,tn
    Posts
    495
    when you say high mileage, how high is high?? i have 80000
    picture didnt open
  10. #8
    Join Date
    Dec 2002
    Location
    Tucson, AZ
    Posts
    4,614
    Hmm you'll need to log into imagestation first I think. It really would be nice if this site allowed you to post pics without having to link from a URL
    80,000 could be enough. Seems they usually invariably leak by about 100,000. Some worse than others though. You really wont know for sure until you check it!
    - Greg -
  11. #9
    Join Date
    May 2002
    Location
    memphis,tn
    Posts
    495
    where is the picture located at in imagestation.com????
  12. #10
    Join Date
    Dec 2002
    Location
    Tucson, AZ
    Posts
    4,614
    It's in this album... last picture.
    http://www.imagestation.com/album/?id=4290471661&idx=11
    - Greg -
  13. #11
    G20.net Staff
    Super Moderator
    JustinP10's Avatar
    Join Date
    Mar 2002
    Location
    Gilbert, AZ
    Posts
    4,409
    You can right click the first link and just copy and paste the shortcut into your browser window and it'll open up the picture.
    Justin 2010 135i (daily) - 1999 GSX (rattle box) - kinda 04 350z (turbo/gutted/caged race car)
  14. #12
    G20 Senior Member tnpartsguy's Avatar
    Join Date
    Mar 2002
    Location
    Lebanon, TN
    Posts
    848
    the Oil Pressure sender fixed MY oil leak!!
    Richard Garrison
    It was a 93.5 Infiniti G20 | Mods; '95 Chrome Grille. Got Fogs. '99 P11 Wheels. JDM SR20. 19 degree timing. Gone to G Heaven now, the ABS valve went out, car was traded and sold to a salvage company.
    Now it's a 2009 Hyundai Santa Fe SE
  15. #13
    Join Date
    May 2002
    Location
    memphis,tn
    Posts
    495
    does anybody have a part number for it??
  16. #14
    Join Date
    Mar 2002
    Location
    Mansfield, OH
    Posts
    2,120
  17. #15
    Join Date
    May 2002
    Location
    memphis,tn
    Posts
    495
    i think im blind. i cant find the pressure switch anywhere on my engine compartment. could somebody take a pic of the motor and circle the pressure switch for me?? thanks very much.
  18. #16
    Join Date
    Mar 2002
    Location
    Lebanon, TN
    Posts
    848
    get under the car, look above the passenger side axel, kinda BEHIND the timing cover.....it's crazy, I know....but it's sorta in an odd place, but it's there, trust me, i just did mine last week. it's almost like the timing chain extends out beyond the block.
    Richard Garrison
  19. #17
    Join Date
    May 2002
    Location
    memphis,tn
    Posts
    495
    is their a wiring harness coming out of it, on one side..... and the other side screws in???
    thanks.
  20. #18
    Join Date
    Dec 2002
    Location
    Tucson, AZ
    Posts
    4,614
    Yeah if you look at the last pic, the threaded portion threads into the block towards the passenger side, then the harness clips into the plastic side.
    By the way, if/when you replace it, remember to teflon tape the threads.
    - Greg -
  21. #19
    Join Date
    May 2002
    Location
    memphis,tn
    Posts
    495
    look at the last 2 pictures, is this it?? is it at the same place on a p10??
    http://www.imagestation.com/album/?i...5092709&idx=27
  22. #20
    Join Date
    Dec 2002
    Location
    Tucson, AZ
    Posts
    4,614
    Dude thats the alternator. You're on the wrong side of the motor!
    It's on the back side, lay on your back with your chest under the oil pan, look up behind the back of the motor above the passenger side axle, more or less on the other side of where the oil filter screws in. It's right there with a cord stuck in it.
    Seems you got that pic from my album. I meant for you to go to the last pic, which is of my custom oil distribution block. The leftmost sender in that block is the sender youre looking for, except yours is screwed right into your motor.
    - Greg -
Posting Permissions
  • You may not post replies
  • You may not edit your posts
