How To: Recognise and repair 5th gear pop-out in a B13/P10 transmission.
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: How To: Recognise and repair 5th gear pop-out in a B13/P10 transmission.
  1. #1
    G20 Junior Member
    Join Date
    Nov 2008
    Location
    Columbia, SC
    Posts
    87
    I've been asked to copy this here from the sr20-forum by junknstuff.
    Table of contents
    1) History of 5th gear pop-out and the Courtesy 5th gear pop-out "kit"
    2) How to recognize if a transmission has 5th gear pop-out by looking inside
    3) How to recognize if a transmission has 5th gear pop-out by driving the car
    4) How to replace 5th gear once the transmission is out of the car
    5) A total breakdown of the traditional 5th gear pop-out "kit" and what each part does
  2. Remove Advertisements
    G20.net
    Advertisements
  3. #2
    G20 Junior Member
    Join Date
    Nov 2008
    Location
    Columbia, SC
    Posts
    87
    In the beginning, there was nothing.
    Then we had SE-R owners coming out of the wood work with 5th gear pop-out. This became more common as the years and miles rolled on. Discussion on the SE-R mailing list centered around getting Nissan to fix the problem under warranty. The cause of the problem was blamed on poor engine mounts for the most part.
    Lawrence (Larry) Weeks eventually developed 5th gear pop-out himself (year unknown right now) and went about ordering new parts from Nissan and did an incredible job documenting the process. During this time the community learned that Nissan had redesigned the 5th gear for the input shaft to combat the 5th gear pop-out problem (yet never issued a recall or repair edict).
    In this description Larry lists the problem for 5th gear pop-out as the fault of the 5th gear synchronizer failing. This seems to have caused some confusion throughout the years as Larry isn't using the traditional naming of parts in this instance. The actual brass synchronizer does not fail, and does not cause this problem. He is referring to the 5th gear and coupling sleeve dog teeth as the "synchronizer". The failing of which is the cause. Technically a failing 5th gear synchronizer will certainly aggravate the problem, but even with a perfectly functioning synchronizer, you can/will develop 5th gear pop-out.
    Larry also started a poll to see who was getting 5th gear pop-out, what year car they owned, and at what mileage it presented itself. The entry form for the poll is still present, but the form doesn't submit properly, and the original results page is sadly lost (possibly forever). Edit: The archived results have been found!
    Apparently, since Larry was so thorough in his documentation and successfully remedied his 5th gear pop-out, Courtesy Nissan took his entire order (which included many extras not directly related to fixing the 5th gear problem) and labeled it the "5th gear pop-out repair kit" offering it for sale from then on.
    Here is Larry describing how it happened:
    Quote Originally Posted by Lawrence Weeks (10/18/2004 SE-R mailing list)
    Subject: Re: 5th gear pop-out refresher.
    Yeah, Courtesy copied my parts list in its entirety it appears. You
    don't really need all those parts. I just like replacing cheap parts
    "while I'm in there." All you *really* need are the fifth input gear
    and the coupling sleeve/hub combo. If you're really cheap, you could
    even maybe get by with only a new input gear, as the coupling sleeve
    can be flipped. I wouldn't recommend that though, the hub should be
    replaced. You don't need the two spring rings or the three little
    insert thingies. The baulk ring wouldn't hurt. Plus seals: axle, input
    shaft, case gasket. You don't need the shift rod pin and seal unless
    yours is leaking. Mine was, so it apparently made that list. Also,
    the fifth gear shift fork: don't need it, unless yours has a problem.
    The deal with the fifth gear is that Nissan changed the dimensions of
    the input gear, so it would mesh with more material. That is the only
    countermeasure I ever discovered. They also began specifying that
    the hub and coupling ring must be sold as a set, where previously
    they were sold separately.
    Something important to do when fixing this is to measure the freeplay
    with the retaining clip at the end of the input shaft with new parts
    installed. That clip is available in different thicknesses, and you
    may need a new one with new parts. No way to know which one though
    until you install new parts.
    Larry
    Here is a link to the e-mail in the SE-R mailing list archives: http://www.se-r-list.org/new-archive...18/018971.html
  4. #3
    G20 Junior Member
    Join Date
    Nov 2008
    Location
    Columbia, SC
    Posts
    87
    Once you have the case open (for those directions see section 4) you'll be looking at the gear stacks. I've labeled the 5th gear in this picture with purple.
    I have this gear and the assembly above it on my desk that I've taken pictures of to help us out.
    This is the 5th gear followed by the brass synchro and then the coupling sleeve. (From bottom to top).
    Here is the stack again as they sit in the transmission.
    Here is what it looks like with the coupling sleeve disengaged. My hand doing the job of the shift fork.
    This is what it looks like with 5th gear engaged.
    Here's what it looks like with the selector lifted off.
    And with the synchro removed.
    All three pieces separated.
    This is the two main pieces of the coupling sleeve and hub assembly. Normally two ring springs and three retainers hold it together and allow them to slide up and down a bit.
    Here they are together. The three open spots are where the three retainers go.
    Here are the dog teeth on the coupling sleeve that have been torn up causing 5th gear pop-out.
    Here they are again. Torn up. Chipped teeth.
    More carnage.
    Here is what the other side looks like that hasn't seen any use in it's life. This is what it should look like more or less.
    More pics of the good stuff.
    Here are the dog teeth on the 5th gear itself all torn up causing 5th gear pop-out.
    Another picture of the beat up dog teeth. You should see now that with all this material gone the teeth don't have much left to hold onto.
    Here is my brother's 5th gear that we replaced ahead of time before it could get 5th gear pop-out. It looks a lot better.
    Again.
    Good one on the left, bad on the right.
    Here is the bad one again. You'll notice the distance between the gear teeth and the dog teeth is very small. Maybe 1mm at most.
    The redesigned gear will have about 2mm between the gear teeth and the dog teeth. Basically they sit up higher. This means they penetrate deeper into the coupling sleeve and do not loose contact and slip or grind themselves up. Take a look back at the picture showing both gears next to each other. You'll see neither is the redesigned gear even though they both came out of 1994 transmissions.
    Here is a comparison of the redesigned gear (on the left) and the original style (on the right).
    Quote Originally Posted by www.se-r.net
    Note that the main difference is a increase in the width of the groove in the new gear. This is because the lower portion of the gear, the input teeth, has been made smaller. This makes the inset synchro teeth "taller" and lets them mate deeper into the synchronizer sleeve. Precisely, the overall height of the gears is unchanged at 1.162 inches (29.5148 mm). The height of the old input teeth portion is 0.588 inches (14.9352 mm), while the new, reduced height is 0.545 inches (13.843 mm). The height of the input gear teeth + synchro teeth is unchanged, at 0.778 inches (19.7612 mm).
    Here are more pictures I was able to take with the redesigned gear (on the left) and the original style (on the right).
    New style.
    Old style.
    If you have the gear with the "taller" dog teeth you're all set. Otherwise it's a time bomb. You'll know when you take it apart.
  5. Remove Advertisements
    G20.net
    Advertisements
  6. #4
    G20 Junior Member
    Join Date
    Nov 2008
    Location
    Columbia, SC
    Posts
    87
    If you're driving the car in 5th gear and the shift lever pops out of the 5th gear location at any time you have 5th gear pop-out. Seriously, what else did you expect me to say?
    Usually this starts to happen only under hard acceleration or engine braking while in 5th gear and it will get progressively worse until the transmission refuses to engage 5th gear at all.
  7. #5
    G20 Junior Member
    Join Date
    Nov 2008
    Location
    Columbia, SC
    Posts
    87
    Notes: When I say the "top" of the transmission in this post I'm referring to the transmission resting on the bellhousing/engine mating surface. The "top" usually points to the driver's side fender when the transmission is in the car.
    1) With the transmission bellhousing facing down unbolt the 6 bolts on the top of the transmission that hold the small circular plate onto the transmission.
    2) Unbolt the 12+ bolts holding the transmission case to the bellhousing.
    3) Remove the small circular plate from the top of the transmission. It will be held on by grey RTV. Be careful. Don't loose the rubber o-ring either.
    4) Use spreading C-clip pliers to remove the larger c-clip holding the outer bearing race on the output shaft to the top of the transmission case. This is a silver (not dark) c-clip down lower than the smaller c-clip you'll see on the end of the output shaft.
    5) Remove the transmission case from the bellhousing. It will be held on by grey RTV. Be careful. There will be spots where you can "pry" with a thick flathead screwdriver or pry bar. Be careful lifting the case off of the bellhousing as it will not come straight off. Look through the hole at the top of the case to get an idea of how you need to remove it. The two gear stacks and shift linkage should now be exposed. It should look like this (I like to call this the "back" of the transmission).
    The "front" will have the shift linkage assembly in front of the two gear stacks. While looking at the "back" of the gear stacks in this picture, the part you'll be dealing with most is in the upper right hand section of the picture. That is where you'll find the 5th gear.
    Here is another picture of the gear stacks from the "right".
    And the "left".
    6) Remove the long metal dowel that holds the all of the selector forks in place. This should be lifted by hand. It should come straight out very easily. Once it is removed the gear selector forks will be resting on their respective coupling sleeves and the shift linkage assembly only. The metal dowel in question can been seen left of center in this picture.
    Here it is removed (top in picture).
    7) Slide the 5th gear shift fork around the gear coupling sleeve (making sure to keep the fork prongs inside the groove in the selector ring) to remove the fork from the shift linkage assembly. Be very careful. There is a small friction cap inside the "handle" of the fork that you do not want to loose. Keep track of this friction cap. Make sure not to disturb the other shift forks when doing this. They too have friction caps and you will want to make sure they don't get dislodged.
    8) Remove the 5th gear retainment plate on the top of the input shaft gear stack. It has a C-clip holding it on that you'll need to remove as well.
    9) Mark the top of the 5th gear coupling sleeve and hub assembly with a sharpie marker so you will know which side was "up". (You will want to reassemble this upside down.)
    10) Remove the 5th gear coupling sleeve and hub assembly by sliding it off of the top of the input shaft gear stack. Be careful not to let it disassemble. It is held together by two ring springs and three retainers. Sort of a pain to put back together, but not too bad. If this doesn't come off easily because the bearing on the output shaft is preventing it from coming off you can lift the output shaft some and carefully spread the two gear stacks apart to get the wiggle room needed to remove it. If this fails you should disassemble the 5th gear coupling sleeve and hub assembly to remove it from the shaft. You do this by pulling the hub up and out of the coupling sleeve. Make sure not to loose the three retainers or the two ring springs.
    11) Remove the 5th gear synchronizer by sliding it off of the top of the input shaft gear stack.
    12) Remove the 5th gear by sliding it off of the top of the input shaft gear stack. This should be possible by hand but you might need a gear puller if you're the unlucky type.
    Now you're basically going to reassemble the transmission in reverse taking care to replace all of the parts you removed with new parts if you have them. Keep reading though, there are some important details you won't want to miss.
    13) Replace old 5th gear with new 5th gear by sliding the new 5th gear onto the input shaft.
    14) Replace the 5th gear synchronizer with a new one if you bought one, or re-use the old one. (A new one is recommended).
    15) Replace the 5th gear coupling sleeve and hub assembly by sliding it back onto the input shaft. Be sure to put it back on the opposite of how you took it off. This means what ever side was facing up before should face down. This is because this part will have worn out along with the 5th gear and you will want to use the "fresh" side. It has two sides, but only one is used.
    Alternatively you could buy a new coupling sleeve and hub assembly and avoid re-using the old assembly (you can't buy just the coupling sleeve anymore). If you buy a new coupling sleeve and hub assembly you will have to disassemble the 5th gear selector ring/collar and inner spline ring assembly to re-use your old spring rings and retainers. This is not very difficult. Also, if you buy the entire kit it comes with two new ring springs and three new retainers for this assembly. You'll want to assemble all these new parts to replace the old if you bought the kit. (I don't feel this is necessary at all.)
    16) Replace the 5th gear retainment plate on the top of the input shaft gear stack. Don't forget the c-clip.
    17) Slide the 5th gear shift fork back onto the gear coupling sleeve (making sure to keep the fork prongs inside the groove in the coupling sleeve) and rotate the fork to put it back into the shift linkage assembly. Be very careful. There is a small friction cap inside the "handle" of the fork that you need to make sure is present and does not fall or dislodge itself during this step. Make sure not to disturb the other shift forks when doing this. They too have friction caps and you will want to make sure they don't get dislodged.
    18) Reinstall the long metal dowel that holds the all of the selector forks in place. This should be fitted by hand. It should slide straight in easily aligning all of the shift forks back into place.
    Here it is in the top of this picture.
    19) Replace the oil spreader if it fell out. You may have noticed this piece in the transmission case.
    Or you may not have even noticed it. If it is still in place where it goes, leave it alone. If it has fallen out, it's not readily apparent where it goes back. See the two tabs on the left hand side of the spreader? Those two tabs mount into the two small, oval holes in the bottom left of this picture.
    See them right above the second bolt hole from the left? Good. That's where that thing goes.
    20) Clean all gasket surfaces. Clean the bellhousing mating surface and the transmission case mating surface of all Grey RTV material. Clean the small, circular cap of all Grey RTV and clean the side of the transmission case where this cap mounts. Be careful not to ruin the rubber o-ring if it is still in place.
    21) Apply grey RTV gasket sealant to the bellhousing mating surface. Be careful to make sure you apply the bead to the "inside" of the bolt holes.
    22) Replace the transmission case back onto the bellhousing making sure to tilt it and rotate it as it will not go straight down onto it. Look through the hole in the top to make sure you're avoiding everything and the oil spreader doesn't fall out as you do this.
    23) Torque down the transmission case. I like to use an "inside out" torque method, not a star pattern.
    24) Replace the C-clip that holds the outer race of the bearing on the top of the output shaft to the transmission case. If the output shaft is not tall enough and the groove in the bearing race is not showing you can lift the output shaft by hand (it should move easily) or pry it up with a screw driver to get the C-clip to seat.
    25) Apply grey RTV to the top of the transmission where the small circular cap mounts.
    26) Replace the small circular cap.
    27) Torque down the bolts on the cap using a star pattern.
    28) Take a break, grab a (root)beer and let the RTV cure. You are finished.
  8. #6
    G20 Junior Member
    Join Date
    Nov 2008
    Location
    Columbia, SC
    Posts
    87
    Breakdown of the traditional 5th gear pop-out "kit"
    Here is Courtesy Nissan's 5th gear pop-out kit for the 2.0L transmissions: SE-R 5th Gear Pop-Out Kit :: CourtesyParts
    Diagram of the parts you're buying: 5th Gear Parts :: Sentra / NX Parts (B13) 1991-1994 :: CourtesyParts.com
    Cost right now is $341.41 for a total of 13 items (some items come with multiple pieces).
    Here is Gspec's 5th gear pop-out kit: G Spec Performance - 5th Gear Pop out Kit
    Here is Greg's picture of what you're buying.
    Cost right now is $367.02 for a total of 16 items (some items come with multiple pieces).
    As of now, these are the parts they have in common:
    Driver's side axle seal.
    Passenger's side axle seal.
    Two (2) shift fork caps.
    Coupling sleeve and hub.
    5th gear shift fork.
    Three (3) 5th gear shift inserts. (I call them retainers for the ring springs in my descriptions)
    Two (2) 5th gear insert springs. (I call them ring springs in my descriptions)
    5th gear baulk ring. (I call it the 5th gear synchronizer in my descriptions)
    Input gear (5th).
    Case cover O-ring.
    Input shaft oil seal.
    These are the parts that are in the Courtesy Kit only:
    Striking rod oil seal.
    Rod retaining pin.
    These are the parts in the G-Spec kit only:
    Output shaft upper bearing retainment C-clip.
    Unknown circular seal (rear main seal?)
    Unknown dowel with key way.
    Reverse position switch.
    Neutral position switch.
    What each part does
    I know it can get confusing when parts aren't always called the same thing. Nissan has official names for their parts that make sense most of the time, but then cause confusion other times. Their naming convention for their synchronizers is a perfect example. They call their synchronizer a "baulk ring". That might make sense to someone, but to me and most others it is a terrible name. The part is typically referred to as a synchronizer, and that's what I've been calling it in my descriptions. I'm going to try and use the best name for a part I can. It might be the official Nissan name, or it might not be. It should be descriptive however, and leave no confusion. If you are confused, please let me know and I will make it less so.
    Driver's side axle seal - Creates a seal around the axle preventing gear oil from leaking out of the transmission case and road debris from entering the transmission case. This is a wear item but can be re-used if in good condition.
    Passenger's side axle seal - Same as above.
    Two (2) shift fork caps - The shift linkage has levers that lift the shift forks up and down. The shift fork caps provide a connection between the levers and the shift forks to reduce friction and allow pivoting. These are technically wear items but wear very slowly and shouldn't need replacing.
    Coupling sleeve and hub - These pieces transfer torque from the input shaft to the floating 5th gear on the input shaft. The coupling sleeve slides up and down with the shift fork. When the shift fork is raised up the sleeve raises and disengages the dog teeth on the input gear (5th). When the shift fork is moved down the sleeve moves down and engages the dog teeth on the input gear (5th). The dog teeth on the sleeve suffer heavy damage on transmissions with 5th gear pop-out so you will need to flip the sleeve over to use the unused "good" side or purchase a new one. This is one of the two main parts that are damaged when you have 5th gear pop-out.
    5th gear shift fork - This transfers the lever movement from the shift linkage to the coupling sleeve. In some rare cases this can be bent by an overly aggressive driver trying to keep their transmission in 5th gear when they have 5th gear pop-out. This piece should not need replacing except in the most extreme cases.
    Three (3) 5th gear shift inserts - These little pieces install into the coupling sleeve and hub facilitating in their sliding movement. These are technically wear items but wear very slowly and shouldn't need replacing.
    Two (2) 5th gear insert springs - These springs retain the three 5th gear shift inserts and help facilitate the sliding of the coupling sleeve and hub. These do not need replacing.
    5th gear baulk ring - This is the synchronizer. It is a wear item and is likely worn more than usual in a transmission with 5th gear pop-out. It should be replaced.
    Input gear (5th) - This is the input gear on the input shaft for 5th gear. When engaged with the coupling sleeve above it transfers torque from the input shaft to the output shaft via the 5th output gear. The dog teeth on it are heavily damaged in transmissions with 5th gear pop-out and it needs to be replaced. If your transmission has 5th gear pop-out you almost certainly have an old style 5th input gear and it should be replaced with the new style of 5th input gear.
    Case cover O-ring - This seals the transmission case where the small, round cap is bolted to the top of the transmission case. It prevents gear oil from leaking. If you are not very careful in disassembly you will likely ruin this piece so you should get a new one to replace it with.
    Input shaft oil seal - Creates a seal around the transmission input shaft on the bellhousing side to prevent gear oil from leaking into the bellhousing. This can be re-used but is good to replace "while you're in there".
    Striking rod oil seal - Creates a seal around the shift actuator rod (or striking rod) to prevent gear oil from leaking out of the bellhousing. This can be re-used but is good to replace "while you're in there". If you replace this you will need a new rod retaining pin.
    Rod retaining pin - This locates and holds the shift actuator lever arm onto the shift actuator rod (or striking rod). If you replace the striking rod oil seal you will need a new one of these as it is usually ruined in the removal process.
    Output shaft upper bearing retainment C-clip - This locates and holds the input shaft bearing towards the top of the gear stack in place on the top of the transmission case. The c-clip fit into a groove in the outer race of the bearing and rests on top of a circular ledge on the transmission case. When opening the transmission case this needs to be removed and ususally suffers not damage so it can be re-used and is not essential.
    Unknown circular seal (rear main seal?) - I need to ask greg what this is.
    Unknown dowel with key way - This might be the rod retaining pin. I need to ask Greg.
    Reverse position switch - This switch tells the ECU when the transmission is in reverse. This can be re-used but is good to replace "while you're in there" because they tend to leak with age.
    Neutral position switch - This switch tells the ECU when the transmission is in neutral. This can be re-used but is good to replace "while you're in there" because they tend to leak with age.
  9. #7
    G20 Junior Member
    Join Date
    Nov 2008
    Location
    Columbia, SC
    Posts
    87
    *reserved just in cases*
  10. #8
    G20 Senior Member Anime Gee's Avatar
    Join Date
    Feb 2003
    Location
    Canyon road!
    Posts
    599
    Thumbs up
    Good stuff. Thanks! ( ^o^)/
  11. #9
    G20 Junior Member
    Join Date
    Nov 2008
    Location
    Columbia, SC
    Posts
    87
    It still has a few placeholders that need filling in, but I'm working on it.
  12. #10
    no rainguard clips...FML junknstuff's Avatar
    Join Date
    Jan 2005
    Location
    san jose, ca
    Posts
    4,132
  13. #11
    T3h Sexy Beast trbobrk's Avatar
    Join Date
    Mar 2002
    Location
    Seattle, WA USA
    Posts
    20,507
    When your done editing it let the mods know so they can rehost the pics on Gnet server for perpetuity.
    Unfortunatly mine just started popping out last week. Oh well, I need a LSD box in there anyway.
  14. #12
    G20 Senior Member Ace`'s Avatar
    Join Date
    Apr 2008
    Location
    Miami, FL
    Posts
    691
    Also pm mods, or Modsif your reading this should definitly deserve a pin or be put in the FAQ, as this is a common problem
    nice stuff man
  15. #13
    G20 Member el_boogie28's Avatar
    Join Date
    Apr 2006
    Location
    NJ
    Posts
    404
    mine just started popping as well. thanks for the info!
  16. #14
    drunken master p10det's Avatar
    Join Date
    Dec 2003
    Location
    de
    Posts
    10,091
    the 5th imput gear in pic # 3 is clearly unafected and is not a popp out peace. the ring you are holding I 2 3 4 and 6 and a few others I have confirmed that it can be fliped over and reused as ther ar the same set of teeth on the oposit side. the center whre it mounts must remain it its position and can not be fliped. meaning the basic pop out fix is 2 parts.
    the fith imput bualk ring and the 5th imput gear. i have opened one sr tranny with no 5th gear to find a broken shift fork. that part is unly needed if you find damaged to it.
    if any one disagrees i can explian this
  17. #15
    G20 Junior Member
    Join Date
    Nov 2008
    Location
    Columbia, SC
    Posts
    87
    Updated the last section. Needs more but it's getting there.
  18. #16
    G20 Junior Member
    Join Date
    Nov 2008
    Location
    Columbia, SC
    Posts
    87
    Quote Originally Posted by p10det View Post
    the 5th input gear in pic # 3 is clearly unafected and is not a pop out piece.
    I have two 5th gears on my desk. One is in good condition (but not the redesigned piece) from my brother's car and the other is in bad condition and was from my transmission with 5th gear pop out. The picture you're referring to has the "good" 5th gear in it. You're right. It is in too good of a condition to have come from a transmission with 5th gear pop out. It came from my brother's transmission that didn't have 5th gear pop out. We were replacing his clutch, so I convinced him to get the redesigned 5th gear while we were at it.
    the ring you are holding I 2 3 4 and 6 and a few others I have confirmed that it can be flipped over and reused as there are the same set of teeth on the opposit side.
    Yep. It's been a known option for a while.
    the center where it mounts must remain in its position and can not be flipped.
    So you're saying the hub inside the coupling sleeve shouldn't (can't) be flipped? Got it. Good to know.
    Someone must have been convinced if they pushed on the shift lever with the strength of 10 men that the car would go into, and stay in 5th. Complete monkey I tell you.
    that part is only needed if you find damage to it.
    Agreed.
  19. #17
    Join Date
    Dec 2003
    Location
    de
    Posts
    10,091
    the center part of the hub I have not confirmed can not be fliped . I just never did cuase if you look at it it looks visually differnt. so I never measured . if figured install that part the same way incase it would change the hight of the gear are leave a gap beteen it and the clip at the top.
    was just something I did not want to try lol
  20. #18
    G20 Junior Member
    Join Date
    Nov 2008
    Location
    Columbia, SC
    Posts
    87
    I see your thinking... The one on my desk looks identical on both sides and symmetrical. No height difference. Sure looks like it could be flipped without any alignment issues.
    On that note, if you buy a new part, how are you supposed to tell which side is "up" and which is "down" if they look the same? Because mine looks the same on both sides with the exception of what looks like a casting relief artifact on one side.
  21. #19
    Join Date
    Dec 2003
    Location
    de
    Posts
    10,091
    the lines apear thicker on one side. I have installed new parts as well and installed the same way as the part I had removed. Light I said it might not matter but I had installed the parts in the fasion they came off and just fliped the outer in on my tranny years ago to confirm what parts are really needed for the repiar. if you look at the 4 lines u=you should be able to spot something. It has been a while since i worked on one but I remember noticing a slight differents and not take ing a chance with the center.
    like i said it might not matter But i only fliped the part I new would work
  22. #20
    G20 Junior Member
    Join Date
    Nov 2008
    Location
    Columbia, SC
    Posts
    87
    And there you have it. I see exactly what you're talking about. The four lines you're talking about probably look thicker on one side because it is "stubbier". It doesn't travel the entire length of the inside section on one side, but it does on the other side. Not sure how I missed that. I never paid any attention to that before when re-assembling. Hmmm...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
